2.15 10-Axis IMU Sensor Module
The 10-Axis IMU (Inertial Measurement Unit) module combines multiple sensors to provide comprehensive motion and environmental data. It integrates a barometric pressure sensor (SPL06_001) for altitude measurement, a 6-axis motion sensor (SH3001) for acceleration and rotation, and a 3-axis magnetometer (QMC6310) for compass heading. This sophisticated module is ideal for robotics, navigation systems, and motion-tracking applications.
What You’ll Need
Here are the components required for this project:
COMPONENT INTRODUCTION
PURCHASE LINK
Jumper Wires
10 Axis IMU module
Raspberry Pi
Wiring Diagram
Connect the IMU module to Raspberry Pi as shown below:
../_images/2.15_10axis_bb.png
Ensure proper I2C connections:
  • VCC → 3.3V
  • GND → GND
  • SDA → GPIO 2 (SDA)
  • SCL → GPIO 3 (SCL)
Install the library
Install the 10-Axis library:
sudo pip install git+https://github.com/sunfounder/sunfounder-imu-python.git --break-system-packages
Calibrate the IMU
Run the calibration script to calibrate the IMU:
sudo python3 -m sunfounder_imu.calibrate
Then follow the instructions in the script to calibrate the IMU.
Run the example
All example code used in this tutorial is available in the ai-lab-kit directory. Follow these steps to run the example:
cd ~/ai-lab-kit/python/
sudo python3 2.15_10axis_imu.py
This Python script reads comprehensive motion and environmental data from the 10-Axis IMU module. When executed:
  1. The script initializes communication with all three integrated sensors via I2C.
  2. Each sensor is detected and its I2C address is displayed for verification.
  3. The main loop continuously reads and displays data including:
    • Altitude (from barometric pressure)
    • Compass heading (azimuth)
    • 3-axis acceleration
    • 3-axis angular velocity (gyroscope)
    • 3-axis magnetic field strength
    • Temperature and atmospheric pressure
  4. Data updates every 0.5 seconds, providing real-time motion tracking.
  5. The program runs until interrupted with Ctrl+C, then exits gracefully.
Below is the Python code for reading data from the 10-Axis IMU module:
Read data from all three sensors on the 10 Axis IMU module:
- SPL06_001: temperature, pressure, altitude
- SH3001: temperature, accelerometer, gyroscope
- QMC6310: compass heading
Gracefully exits when Ctrl+C is pressed.
from time import sleep
# Import Sunfounder sensor modules
from sunfounder_imu import IMU
def main():
    imu = IMU()
    sensors = imu.find_sensor()
    if len(sensors) == 0:
        print("No sensor found.")
        return
    for address, class_type in sensors.items():
        name = class_type.__name__
        print(f"Found sensor {name} at address 0x{address:02X}")
    sleep(3)
            data = imu.read()
            print(f"Altitude={data['altitude']:7.2f} m")
            print(f"Azimuth={data['azimuth']:7.2f} °")
            print(f"Acceleration:")
            print(f"  X={data['acceleration'].x:7.2f} m/s²")
            print(f"  Y={data['acceleration'].y:7.2f} m/s²")
            print(f"  Z={data['acceleration'].z:7.2f} m/s²")
            print(f"Gyroscrope:")
            print(f"  X={data['gyroscrope'].x:7.2f} °/s")
            print(f"  Y={data['gyroscrope'].y:7.2f} °/s")
            print(f"  Z={data['gyroscrope'].z:7.2f} °/s")
            print(f"Magenatic:")
            print(f"  X={data['magenatic'].x:7.2f} μT")
            print(f"  Y={data['magenatic'].y:7.2f} μT")
            print(f"  Z={data['magenatic'].z:7.2f} μT")
            print(f"Temperature={data['temperature']:7.2f} °C")
            print(f"Pressure={data['pressure']:7.2f} hPa")
            sleep(0.5)
        print("\nExiting program...")
if __name__ == "__main__":
    main()
Understanding the Code
  1. Imports and Setup:
    The script imports the necessary modules: sleep for timing delays and IMU class from the Sunfounder library to communicate with the sensor module.
  2. Sensor Initialization:
    imu = IMU()
        return
    Creates an IMU object and scans for connected sensors on the I2C bus. If no sensors are found, the program exits.
  3. Sensor Detection:
    Displays information about each detected sensor, including its type and I2C address for debugging purposes.
  4. Main Data Reading Loop:
        data = imu.read()
        # Display all sensor readings with formatted output
        sleep(0.5)
    • Calls imu.read() to get all sensor data in a single dictionary
    • Formats and displays each parameter with consistent decimal precision
    • Includes a 0.5-second delay to balance update rate and readability
  5. Graceful Exit:
    Catches the KeyboardInterrupt exception to allow clean program termination when Ctrl+C is pressed.
Troubleshooting
  1. No Sensors Found:
    • Cause: Incorrect wiring or I2C communication issues.
    • Solution:
      • Verify all connections: VCC, GND, SDA, SCL
      • Check if I2C is enabled on Raspberry Pi: sudo raspi-config → Interface Options → I2C
      • Run i2cdetect -y 1 to see if the sensors appear at their addresses
  2. Inconsistent or Erratic Readings:
    • Cause: Electrical interference or sensor calibration issues.
    • Solution:
      • Keep the module away from strong magnetic fields or motors
      • Ensure stable power supply with proper decoupling capacitors
      • Place the module on a stable surface during measurement
  3. Altitude Readings Incorrect:
    • Cause: Uncalibrated barometric pressure reference.
    • Solution: The altitude is calculated relative to sea level pressure. For accurate readings, calibrate with known altitude or update sea level pressure reference.
  4. Compass Heading Inaccurate:
    • Cause: Local magnetic interference or improper calibration.
    • Solution:
      • Perform magnetometer calibration by rotating the module in a figure-8 pattern
      • Keep away from metal objects, computers, and other magnetic sources
Extendable Ideas
  1. Motion Detection Alert: Trigger an alert when acceleration exceeds a threshold:
    acceleration_magnitude = (data['acceleration'].x**2 +
                              data['acceleration'].y**2 +
                              data['acceleration'].z**2)**0.5
    if acceleration_magnitude > 2.0:  # 2G threshold
        print("Motion detected!")
  2. Orientation Detection: Determine device orientation using combined sensor data:
    # Simple orientation detection using accelerometer
    if abs(data['acceleration'].z) > 9.0:
        print("Device is flat")
    elif data['acceleration'].y > 8.0:
        print("Device is upright")
  3. Data Logging: Record sensor data to a file for analysis:
    import csv
    with open('imu_data.csv', 'a') as f:
        writer = csv.writer(f)
        writer.writerow([data['temperature'], data['pressure'],
                        data['altitude'], data['azimuth']])
  4. Tilt-Compensated Compass: Improve heading accuracy using accelerometer data:
    # Basic tilt compensation (simplified)
    pitch = math.asin(-data['acceleration'].x / 9.81)
    roll = math.asin(data['acceleration'].y / (9.81 * math.cos(pitch)))
    # Apply compensation to magnetometer readings
Conclusion
This project demonstrates how to use a 10-Axis IMU module to obtain comprehensive motion and environmental data with a Raspberry Pi. By integrating pressure, acceleration, rotation, and magnetic field sensors, this module provides a complete inertial measurement solution suitable for advanced applications like drone stabilization, robotics navigation, and motion tracking systems. The foundation established here enables further exploration into sensor fusion algorithms and complex motion analysis.
