3.1 Photograph Module
This project introduces you to using the Raspberry Pi camera module to capture a photograph. The camera module can take high-quality still images and videos, making it a versatile tool for projects ranging from photography to computer vision.
What You’ll Need
Below are the components required for this project:
COMPONENT INTRODUCTION
PURCHASE LINK
Camera Module
Fusion HAT+
Raspberry Pi
Experimental Procedures
  1. To use camera module conveniently, Assemble the Pan-tilt (For Camera) is recommended.
    Assembling the pan-tilt may obscure some pins, so it is recommended to assemble it only when using the camera, or place it on the outside after assembly.
    ../_images/gimbal_assemble.png
  2. Access the Raspberry Pi Desktop:
  3. Open a Terminal and go to the code folder:
    cd ~/ai-lab-kit/python
  4. Run the script to start the camera:
    sudo python3 3.1_Photograph.py
  5. After the script starts, press the Fusion HAT+ USR button to take photos.
    ../_images/3.1_user_button1.png
    • Each press captures a picture.
    • Photos are saved in ~/user/Pictures as my_photo.jpg.
    • Press Ctrl+C to stop the script.
    ../_images/3.1_take_photo.jpg
QT preview requires a desktop environment. If the preview cannot be started (for example, over SSH), the camera can still capture and save photos normally.
Below is the Python code used for this project:
import os, time, pwd
from fusion_hat.user_button import UserButton
u = os.getenv("SUDO_USER")
home = pwd.getpwnam(u).pw_dir if u else os.path.expanduser("~")
os.makedirs(f"{home}/Pictures", exist_ok=True)
photo = f"{home}/Pictures/my_photo.jpg"
camera = Picamera2()
camera.configure(camera.create_preview_configuration())
def shot():
   camera.capture_file(photo)
   print(f"Saved: {photo}")
UserButton().set_on_click(shot)
# Start preview only when a GUI display is available
preview_started = False
if os.getenv("DISPLAY"):
      camera.start_preview(Preview.QT)
      preview_started = True
   except Exception as e:
      print(f"Preview disabled: {e}")
camera.start()
print("Press USR to take photo. Ctrl+C to exit.")
   while True: time.sleep(0.1)
finally:
   try: camera.stop()
   except: pass
   if preview_started:
      try: camera.stop_preview()
      except: pass
   try: camera.close()
   except: pass
Understanding the Code
  1. Imports and Purpose
    These modules provide:
    • os and pwd: used to correctly locate the real user’s home directory, even when the program is run with sudo.
    • time: keeps the program running in a loop.
    • Picamera2 and Preview: control the Raspberry Pi camera and preview modes.
    • UserButton: reads the Fusion HAT+ USR button.
  2. Resolving the Save Path
    This section determines where photos are saved:
    • If the script is run with sudo, SUDO_USER is used to find the original user’s home directory.
    • Otherwise, the current user’s home directory is used.
    • A Pictures folder is created if it does not already exist.
    • All photos are saved as my_photo.jpg (each new photo overwrites the last).
  3. Camera Initialization
    The camera object is created and configured with a default preview setup. This configuration works both with and without a visible preview window.
  4. Photo Capture Function
    def shot():
    This function is called whenever the USR button is pressed. It captures a photo and saves it to the predefined path, then prints the save location.
  5. USR Button Binding
    The Fusion HAT+ USR button is linked to the shot function. Each button press triggers a photo capture.
  6. Conditional Preview Start
    • The program checks whether a graphical display is available.
    • If a display exists, it attempts to start a QT preview window.
    • If no display is available (for example, when running over SSH), the preview is skipped without stopping the program.
  7. Camera Start and Main Loop
    camera.start()
            time.sleep(0.1)
    The camera is started, and the program enters an infinite loop to keep running and listening for button presses.
  8. Clean Exit and Resource Cleanup
    finally:
        try: camera.stop()
        except: pass
        if preview_started:
            except: pass
        try: camera.close()
        except: pass
    When Ctrl+C is pressed:
    • The camera is stopped.
    • The preview is stopped only if it was successfully started.
    • The camera resources are released cleanly.
    This ensures the program exits without error messages, regardless of whether a preview window was used.
Troubleshooting
  1. No Preview Window
    • Cause: Camera not enabled, missing display, or Picamera2 not installed.
    • Fix: Run on a system with a display (not pure SSH), and test Picamera2 with a simple script.
  2. USR Button Not Working
    • Cause: Fusion HAT+ not seated correctly, button not detected, or wrong photo folder checked.
    • Fix: Reconnect HAT, run script with sudo, and check photos under ~/Pictures.
  3. Photos Saved to Wrong Location
    • Cause: Running with sudo may confuse home directories.
    • Fix: Script already handles this; print REAL_USER or PICTURES_DIR if unsure.
  4. Preview Freezes
    • Cause: Camera in use by another app or low system resources.
    • Fix: Close other apps, update the system, or reboot the Pi.
Conclusion
This script lets you capture photos using the Fusion HAT+ USR button and save them automatically to ~/Pictures. The setup is ideal for simple camera projects and can be extended for timelapses, DIY camera builds, or classroom demos.
