4.5 Welcomeď
Have you ever noticed the automatic doors in convenience stores that open with a welcoming chime when someone approaches? This project replicates that functionality on a smaller scale. Using a PIR sensor, servo motor, LED, and buzzer, youâll create a miniature âautomatic doorâ system. When motion is detected, the system lights an LED, âopensâ the door using a servo, and plays a welcoming chime with a buzzer.
What Youâll Need
Below are the components required for this project:
COMPONENT INTRODUCTION |
PURCHASE LINK |
Raspberry Pi |
Circuit Diagram
Below is the circuit diagram for this project:
Wiring Diagram
Follow the wiring diagram to assemble the circuit:
Adjust the potentiometers on the PIR sensor module for optimal sensitivity and detection range. Rotate both potentiometers fully counterclockwise for best performance.
Running the Example
All example code used in this tutorial is available in the ai-lab-kit directory.
Follow these steps to run the example:
cd ~/ai-lab-kit/python/
sudo python3 4.5_Welcome.py
Below is the Python script for the project:
from fusion_hat.servo import Servo
from fusion_hat.modules import Buzzer
from fusion_hat.pwm import PWM
# GPIO pin setup
ledPin = Pin(17, Pin.OUT)
# Initialize a PIR Module object on GPIO pin 17
pirPin = Pin(22, mode=Mode.IN, pull=Pull.DOWN)
buzPin = Buzzer(PWM('P0'))
# Initialize servo with custom pulse widths
servoPin = Servo('P4')
# Musical tune for buzzer, with notes and durations
tune = [('C#4', 0.2), ('D4', 0.2), (None, 0.2),
('Eb4', 0.2), ('E4', 0.2), (None, 0.6),
('F#4', 0.2), ('G4', 0.2), (None, 0.6),
('Eb4', 0.2), ('E4', 0.2), (None, 0.2),
('F#4', 0.2), ('G4', 0.2), (None, 0.2),
('C4', 0.2), ('B4', 0.2), (None, 0.2),
('B4', 0.2), ('Bb4', 0.5), (None, 0.6),
('A4', 0.2), ('G4', 0.2), ('E4', 0.2),
('D4', 0.2), ('E4', 0.2)]
def setAngle(angle):
Move the servo to a specified angle.
:param angle: Angle in degrees (0-180).
servoPin.angle(angle) # Set servo position
time.sleep(0.001) # Short delay for servo movement
def doorbell():
Play a musical tune using the buzzer.
for note, duration in tune:
buzPin.play(note,float(duration)) # Play the note
buzPin.off() # Stop buzzer after playing the tune
def closedoor():
# Turn off LED and move servo to close door
ledPin.off()
for i in range(180, -1, -1):
setAngle(i) # Move servo from 180 to 0 degrees
time.sleep(0.001) # Short delay for smooth movement
time.sleep(1) # Wait after closing door
def opendoor():
# Turn on LED, open door (move servo), play tune, close door
ledPin.on()
for i in range(0, 181):
setAngle(i) # Move servo from 0 to 180 degrees
time.sleep(1) # Wait before playing the tune
doorbell() # Play the doorbell tune
closedoor() # Close the door after the tune
def loop():
# Main loop to check for motion and operate door
if pirPin.value()==1:
opendoor() # Open door if motion detected
time.sleep(0.1) # Short delay in loop
loop()
# Clean up GPIO on user interrupt (e.g., Ctrl+C)
buzPin.off()
ledPin.off()
This Python script integrates a PIR motion sensor, servo motor, LED, and buzzer to create an automated welcoming system. When executed:
Motion Detection: A PIR motion sensor connected to GPIO pin 22 detects motion.
Door Automation: When motion is detected:
The servo motor (on PWM 4) opens a door by moving from 0° to 180°.
The LED (on GPIO pin 17) turns on.
A welcoming chime is played through the buzzer (on PWM 0).
The servo motor closes the door by moving back from 180° to 0°.
The LED turns off.
Continuous Monitoring: The system continuously monitors for motion and triggers the above sequence whenever motion is detected.
Graceful Exit: On
Ctrl+C, the buzzer and LED are turned off, and the script exits cleanly.
Understanding the Code
Motion Detection: The PIR sensor detects motion and triggers the system.
Servo Control: The servo motor opens and closes the door using angles from 0° to 180°.
Buzzer Melody: A welcoming tune is played using the
Buzzer.Reset: After the chime, the system closes the door and turns off the LED, ready for the next event.
Troubleshooting
Motion Not Detected:
Cause: PIR sensor not wired correctly or environmental interference.
Solution:
Ensure the PIR sensor is connected to GPIO pin 22, power, and ground.
Adjust the sensorâs sensitivity and delay potentiometers if available.
Servo Not Moving:
Cause: Incorrect servo configuration or power supply issues.
Solution:
Verify the servo is connected to P4 and powered correctly.
Chime Not Playing:
Cause: Buzzer misconfiguration or incorrect tune format.
Solution:
Ensure the buzzer is connected to P0.
Verify the
tunelist contains valid note and duration pairs.
LED Not Turning On:
Cause: LED wiring or GPIO configuration issues.
Solution: Verify the LED is connected to GPIO pin 17 with an appropriate resistor.
Extendable Ideas
Adjustable Chime: Add more melodies or allow the user to select different chimes for different events.
Time-Based Operation: Disable the system during specific hours (e.g., at night):
from datetime import datetime if 8 <= datetime.now().hour < 22: # Operate only between 8 AM and 10 PM opendoor()
Data Logging: Log motion detection events and timestamps to a file for analysis:
with open("motion_log.txt", "a") as log_file: log_file.write(f"{time.strftime('%Y-%m-%d %H:%M:%S')} - Motion detected\n")
Voice Greetings: Replace the buzzer chime with pre-recorded voice messages using a speaker.
Conclusion
This project replicates the functionality of automatic doors in a fun and educational way. It introduces concepts like motion detection, servo control, and sound generation, making it a great entry point for IoT and automation projects. Try expanding it by adding features like remote notifications or cloud integration for real-time monitoring.
