4.15 Whack-a-Mole Game
In this lesson, you will build a Whack-a-Mole game using the Fusion HAT+. Four PWM-driven LEDs act as “moles,” fading smoothly in a 1-second cycle. Your goal is to hit the correct button when its corresponding LED lights up. A buzzer gives audio feedback:
  • Correct hole → short high-pitch beep
  • Wrong hole → GAME OVER (low beep)
An SSD1306 OLED display shows your current score during the game and a final score on game over.
This project combines PWM brightness shaping, button edge detection, timing loops, and a simple game state machine.
What You’ll Need
The following components are required for this project:
COMPONENT INTRODUCTION
PURCHASE LINK
Jumper Wires
LED
Button
Buzzer
OLED Display Module
Fusion HAT+
Raspberry Pi
Wiring Diagram
Refer to the wiring diagram for assembling the components:
../_images/4.15_whack_a_mole_bb.png
Setup Steps
  1. Install the required libraries:
    sudo pip3 install adafruit-circuitpython-ssd1306 --break
  2. Run the game from the ai-lab-kit directory:
    cd ~/ai-lab-kit/python/
    sudo python3 4.15_WhackAMole.py
  3. When the script runs:
    • One LED fades up/down (triangle wave).
    • Press only the lit LED’s button within the 1-second window:
      • Correct → score increases, next mole appears
      • Incorrect → buzzer plays error tone → GAME OVER
    • OLED shows only the current score (in-game)
    • OLED shows “GAME OVER” + final score upon losing
    • Press Ctrl+C to exit
Here is the full Python script for the Whack-a-Mole game:
# -*- coding: utf-8 -*-
Whack-a-Mole using fusion_hat:
- 4 PWM LEDs (smooth fade in/out; whole cycle = 1.0s)
- 4 buttons via fusion_hat.Pin (PULL_DOWN; pressed=1)
- Buzzer via fusion_hat.Buzzer(PWM(...)) for short feedback tone
- SSD1306 OLED shows only the current hit count during game
- If a non-lit button is pressed -> GAME OVER with final score
import random
from typing import List, Optional
# ---- fusion_hat GPIO / PWM / Buzzer ----
from fusion_hat.pwm import PWM
from fusion_hat.modules import Buzzer
# ---- OLED ----
from PIL import Image, ImageDraw, ImageFont
import adafruit_ssd1306
import board
# ===================== Port map (EDIT HERE) =====================
# 4 PWM LED ports of Fusion HAT+
LED_PORTS = ['P0', 'P1', 'P2', 'P3']
# 4 button pins (BCM numbering). Example here uses 17/4/27/22.
# Buttons are configured as PULL_DOWN, so pressed -> value==1
BTN_PINS = [17, 4, 27, 22]
# Buzzer on a PWM-capable Fusion HAT+ port
BUZZER_PORT = 'P4'
# ===================== OLED setup =====================
WIDTH, HEIGHT = 128, 64
i2c = board.I2C()
oled = adafruit_ssd1306.SSD1306_I2C(WIDTH, HEIGHT, i2c, addr=0x3C)
oled.fill(0)
oled.show()
image = Image.new("1", (WIDTH, HEIGHT))
draw = ImageDraw.Draw(image)
font = ImageFont.load_default()
def draw_score(score: int):
   """Render in-game screen: only the current score."""
   draw.rectangle((0, 0, WIDTH, HEIGHT), outline=0, fill=0)
   msg = f"Score: {score}"
   tw, th = font.getbbox(msg)[2:]
   draw.text(((WIDTH - tw) // 2, (HEIGHT - th) // 2), msg, font=font, fill=255)
   oled.image(image)
   oled.show()
def draw_game_over(score: int):
   """Render GAME OVER screen with final score."""
   title = "GAME OVER"
   tw, th = font.getbbox(title)[2:]
   draw.text(((WIDTH - tw) // 2, 8), title, font=font, fill=255)
   line = f"Score: {score}"
   lw, lh = font.getbbox(line)[2:]
   draw.text(((WIDTH - lw) // 2, 8 + th + 8), line, font=font, fill=255)
   oled.image(image)
   oled.show()
# ===================== Hardware objects =====================
# LEDs (PWM)
leds = [PWM(p) for p in LED_PORTS]
def led_set(idx: int, duty_pct: float):
   """Set LED brightness (0..100%)."""
   duty = max(0.0, min(100.0, float(duty_pct)))
   leds[idx].pulse_width_percent(duty)
def all_leds_off():
   for i in range(len(leds)):
      leds[i].pulse_width_percent(0)
# Buttons (Pin, PULL_DOWN => pressed=1)
buttons = [Pin(pin, mode=Mode.IN, pull=Pull.DOWN) for pin in BTN_PINS]
def read_buttons() -> List[int]:
   """Read all buttons; return their current logic levels (0/1)."""
   return [b.value() if callable(getattr(b, "value", None)) else int(b.value) for b in buttons]
# Buzzer (tonal)
tb = Buzzer(PWM(BUZZER_PORT))
def beep_hit():
   """Short bright tone for a correct hit."""
   tb.play('A5', 0.08)  # A5 ~ 880 Hz short chirp
   tb.off()
def beep_miss():
   """Lower/longer tone for a miss (game over)."""
   tb.play('E4', 0.25)  # E4 ~ 330 Hz
   tb.off()
# ===================== LED fade (1s total) =====================
def triangle01(u: float) -> float:
   Triangle wave in [0,1], rising 0->1 over first half, then 1->0.
   u in [0,1].
   return 2*u if u < 0.5 else 2*(1.0 - u)
def fade_led_with_button_check(active_idx: int,
                              prev_states: List[int],
                              duration: float = 1.0,
                              step: float = 0.01,
                              gamma: float = 1.8) -> (bool, Optional[List[int]]):
   Fade one LED (active_idx) with triangle brightness over 'duration' seconds.
   While fading, poll buttons at 'step' interval:
      - If matching button pressed (rising edge) -> immediately turn off LED, return (True, new_states).
      - If non-matching button pressed (rising edge) -> game over: return (False, new_states) and let caller handle.
   If no press -> return (None, new_states) to continue game.
   Returns:
      (hit, states)
      hit=True  -> correct hit
      hit=False -> wrong button (game over)
      hit=None  -> no button pressed in this cycle
   t0 = time.monotonic()
   states = prev_states[:]
      t = time.monotonic() - t0
      if t > duration:
            break
      # Triangle brightness 0..1 then 1..0
      u = triangle01(t / duration)
      # Gamma correction for perceived linearity
      level = u ** gamma
      duty = 3 + 97 * level   # keep a tiny floor so LED is visible at the start
      led_set(active_idx, duty)
      # Poll buttons and detect rising edges
      curr = read_buttons()
      for i, (p, c) in enumerate(zip(states, curr)):
            if p == 0 and c == 1:  # rising edge = just pressed
               if i == active_idx:
                  # Correct hit
                  all_leds_off()
                  beep_hit()
                  return True, curr
                  # Wrong hole -> game over
                  all_leds_off()
                  beep_miss()
                  return False, curr
      states = curr
      time.sleep(step)
   # Finished fade with no press
   all_leds_off()
   return None, states
# ===================== Game loop =====================
def pick_next(prev_idx: Optional[int]) -> int:
   """Pick a random index different from prev_idx."""
   choices = list(range(4))
   if prev_idx in choices:
      choices.remove(prev_idx)
   return random.choice(choices)
def main():
   random.seed(time.time())
   score = 0
   last_idx = None
   states = read_buttons()  # baseline for edge detection
   draw_score(score)
      # Choose which LED lights next
      idx = pick_next(last_idx)
      last_idx = idx
      # Run a 1.0s fade cycle, checking button presses
      hit, states = fade_led_with_button_check(idx, states, duration=1.0, step=0.01, gamma=1.8)
      if hit is False:
            # Wrong button pressed -> Game Over
            draw_game_over(score)
            break
      elif hit is True:
            # Correct hit -> score++
            score += 1
            draw_score(score)
            # No press during this mole -> no score change; continue
   # stop all outputs
   all_leds_off()
if __name__ == "__main__":
      main()
      all_leds_off()
      oled.fill(0)
      oled.show()
      tb.off()
      print("\nExited.")
Understanding the Code
  1. LED Fade Animation
    Each LED performs a 1-second triangle-wave fade:
    • Brightness rises from 0 → 100%
    • Then falls from 100% → 0
    • Gamma correction (u ** gamma) improves visual linearity
                                  step: float = 0.01,
  2. Button Edge Detection
    read_buttons() reads all four buttons. A rising edge (previous=0, current=1) means “button just pressed.”
    • If pressed button matches lit LED → correct hit
    • Else → wrong hit → GAME OVER
  3. Buzzer Feedback
    • A5 short chirp = success
    • E4 longer tone = miss / game over
    # Buzzer (tonal)
    def beep_hit():
       tb.off()
    def beep_miss():
       tb.off()
  4. Game Loop
    • Randomly picks one of four LEDs (never the same twice in a row)
    • Runs a fade cycle, checking button presses
    • Updates score or ends the game
       last_idx = idx
  5. OLED Display
    • Shows only the score during play
    • Shows GAME OVER + final score when game ends
       oled.image(image)
       oled.show()
Troubleshooting
  • Buttons do not register presses
    • Ensure buttons are wired correctly using BCM pin numbering
    • Confirm PULL_DOWN is applied so pressed state = 1
    • Check for correct ground wiring
  • LEDs flicker instead of fading smoothly
    • Reduce step time for smoother updates (e.g., 0.005)
    • Ensure PWM ports support proper duty cycle updates
  • Game ends immediately without pressing anything
    • A floating button pin may read as 1
    • Ensure pull-down resistors are correctly configured
  • Score does not increase
    • Verify the LED index matches the button index
    • Ensure LED ports and button pins are in correct order
Try It Yourself
  1. Variable Speed Mode
    Gradually shorten the fade duration to make the game more challenging.
  2. Multi-LED Mode
    Light up two LEDs at once—player must hit either one.
  3. Lives System
    Allow 3 mistakes before game over.
  4. High-Score Storage
    Save the highest score to a file and display it at startup.
  5. Animated Title Screen
    Add a splash screen before the game starts.
These ideas can turn Whack-a-Mole into a full arcade experience!
