2.9 Photoresistor
A photoresistor, also known as a light-dependent resistor (LDR), is a component that detects light intensity. Its resistance decreases as the light intensity increases, making it useful in devices like automatic night lamps and ambient light controllers.
This project demonstrates how to use a photoresistor with Fusion HAT+ to adjust an LED’s brightness based on ambient light levels. The working principle is similar to a potentiometer, except the input is light instead of manual adjustment.
What You’ll Need
Here are the components required for this project:
COMPONENT INTRODUCTION
PURCHASE LINK
Jumper Wires
Resistor
LED
Photoresistor
Fusion HAT+
Raspberry Pi
Circuit Diagram
Below are the schematic diagrams illustrating how to connect the components:
../_images/2.2.1_sch.png
Wiring Diagram
Build the circuit as shown in the diagram below:
../_images/2.2.1_bb.png
Ensure that:
  • The photoresistor is connected to the Fusion HAT+ to convert analog signals into digital values.
  • The LED is connected to a GPIO pin for PWM control.
  • All connections are secure, and power and ground connections are properly set.
Running the Example
All example code used in this tutorial is available in the ai-lab-kit directory. Follow these steps to run the example:
cd ~/ai-lab-kit/python/
sudo python3 2.9_Photoresistor.py
This Python script continuously reads the photoresistor’s value, maps it to a suitable range for setting the LED brightness, and adjusts the LED’s brightness accordingly. The script also includes a graceful exit mechanism to turn off the LED when interrupted by the user. When executed:
  1. The Fusion HAT+ continuously reads photoresistor values from its input channel (ranging from 0 to 4095).
  2. The analog value, representing light intensity or another variable input, is printed to the console as result =  <value>.
  3. The script maps the analog value to a PWM signal to adjust the brightness of the LED.
  4. The LED brightness dynamically changes based on the ADC input, with updates every 0.2 seconds.
  5. The program runs indefinitely until interrupted with Ctrl+C, at which point the LED turns off.
Below is the Python code used in this project:
from fusion_hat.adc import ADC
from fusion_hat.pwm import PWM
# Initialize a PWM LED
led = PWM('P0')
# Set up the potentiometer
photoresistor = ADC('A0')
      # Get the current reading from the ADC port
      result = photoresistor.read()
      print('result = %d ' %result)
      # Map the ADC value to a range suitable for setting LED brightness
      value = MAP(result, 0, 4095, 0, 100)
      # Set the LED brightness
      led.pulse_width_percent(value)
      # Wait for 1 seconds before reading again
      time.sleep(0.2)
# Graceful exit when 'Ctrl+C' is pressed
   led.pulse_width_percent(0)  # Turn off the LED
Understanding the Code
  1. Imports:
    The script imports necessary modules for reading analog values and controlling the LED brightness.
  2. Initialization:
    led = PWM('P0')
    The LED connected to GPIO pin P0 is initialized, and the A0 is set up to read analog values from the photoresistor.
  3. Mapping Function:
    The MAP function converts ADC values (0-4095) to a range suitable for PWM control (0 to 100).
  4. Main Loop:
       time.sleep(0.2)
    • Continuously reads light intensity values from the photoresistor.
    • Adjusts the LED brightness proportionally to the detected light intensity.
    • Includes a short delay to reduce CPU usage and allow visible changes in LED brightness.
  5. Graceful Exit:
    The program ensures the LED is turned off when the script is interrupted (e.g., via Ctrl+C).
Troubleshooting
  1. LED Does Not Light Up:
    • Cause: Incorrect GPIO connection or LED wiring.
    • Solution: Verify the LED is connected to P0 with a resistor to prevent damage.
  2. ADC Values Always Zero or Maximum:
    • Cause: Incorrect wiring.
    • Solution: Check the ADC pin and ensure it is connected to photoresistor.
  3. LED Brightness Not Changing:
    • Cause: ADC values are not correctly mapped to the PWM range.
    • Solution: Ensure the mapping function correctly scales the ADC value to the PWM range (0 to 100).
Extendable Ideas
  1. Threshold-Based Behavior: Turn the LED on or off when the analog value crosses a threshold:
    if result > 128:
       led.on()
       led.off()
  2. Data Logging: Log the ADC values and LED brightness to a file for analysis:
    with open("adc_log.txt", "a") as log_file:
        log_file.write(f"Light Intensity: {result}\n")
Conclusion
This experiment demonstrates how to use a photoresistor and Fusion HAT+ to control an LED’s brightness based on ambient light intensity. By understanding the principles of analog-to-digital conversion and PWM control, you can expand this project to develop more complex light-responsive systems, such as automated lighting or smart devices.
