6.2 Measuring Temperature and Humidity with DHT11
In this lesson, we’ll learn how to use a DHT11 temperature and humidity sensor with the Raspberry Pi Pico 2 W. The DHT11 is a basic, low-cost digital sensor that can measure ambient temperature and humidity, providing a calibrated digital output.
Pico 2 W Starter Kit |
450+ |
SN |
COMPONENT |
QUANTITY |
Micro USB Cable |
Several |
Understanding the DHT11 Sensor
The DHT11 sensor uses a capacitive humidity sensor and a thermistor to measure the surrounding air. It outputs a digital signal on the data pin, and it’s fairly simple to use, but requires precise timing to read data.
Temperature Range: 0–50 °C with ±2 °C accuracy
Humidity Range: 20–80% RH with ±5% accuracy
Sampling Rate: 1 Hz (once every second)
Schematic
Writing the Code
Let’s write a MicroPython program to read temperature and humidity values from the DHT11 sensor.
Open the
6.2_temperature_humidity.pyfrompico-2w-kit-main/micropythonor copy the code into Thonny, then click “Run” or press F5.Ensure the correct interpreter is selected: MicroPython (Raspberry Pi Pico).COMxx.
Here you need to use the library called
dht.py, please check if it has been uploaded to Pico, for a detailed tutorial refer to 1.4 Upload the Libraries to Pico.
from machine import Pin
import utime
import dht
# Initialize the DHT11 sensor
sensor = dht.DHT11(Pin(16))
# Trigger measurement
sensor.measure()
# Read values
temperature = sensor.temperature # In Celsius
humidity = sensor.humidity # In Percent
# Print values
print("Temperature: {}°C Humidity: {}%".format(temperature, humidity))
except OSError as e:
print("Failed to read sensor.")
# Wait before the next reading
utime.sleep(2)
Once the code is running, the temperature and humidity readings will display in the Thonny Shell.
Temperature: 29.3°C Humidity: 60.0%
Temperature: 29.2°C Humidity: 60.0%
Temperature: 29.1°C Humidity: 60.0%
Understanding the Code
Import Modules:
machine.Pin: For controlling the GPIO pins.utime: Contains time-related functions.dht: The library for DHT sensors.
Initialize the Sensor:
sensor = dht.DHT11(Pin(16)) Creates an instance of the DHT11 sensor connected to GP16.
Main Loop:
sensor.measure(): Triggers the sensor to take a measurement.sensor.temperature: Reads the temperature in Celsius.sensor.humidity: Reads the humidity percentage.Exception Handling: Catches any errors that occur during reading.utime.sleep(2): Waits 2 seconds between readings.
while True: try: sensor.measure() temperature = sensor.temperature humidity = sensor.humidity print("Temperature: {}°C Humidity: {}%".format(temperature, humidity)) except OSError as e: print("Failed to read sensor.") utime.sleep(2)
Experimenting Further
Convert Temperature to Fahrenheit:
temperature_f = temperature * 9 / 5 + 32 print("Temperature: {}°F Humidity: {}%".format(temperature_f, humidity))
Display Readings on an LCD:
Integrate an LCD display to show the readings without a computer.
Set Up Alerts:
Use an LED or buzzer to alert when temperature or humidity exceeds certain thresholds.
Troubleshooting Tips
Incorrect Readings:
Ensure the sensor is connected properly.
Check for loose wires or poor connections.
Failed to Read Sensor:
This may happen occasionally due to timing issues. The code includes a try-except block to handle this.
Pull-Up Resistor:
If the sensor doesn’t work, ensure that a pull-up resistor is connected between VCC and Data pins if your sensor requires it.
Conclusion
In this lesson, you’ve learned how to use the DHT11 temperature and humidity sensor with the Raspberry Pi Pico 2. Monitoring environmental conditions is a fundamental aspect of many projects, from weather stations to home automation systems.
