3.5 Controlling a Small Fan (DC Motor)
In this lesson, we’ll learn how to control a DC motor (like a small fan) using the Raspberry Pi Pico 2 W and an TA6586 motor driver. The TA6586 allows us to control the direction of the motor rotation—both clockwise and counterclockwise. Since DC motors require more current than the Pico can provide directly, we’ll use an external power supply to safely power the motor.
PURCHASE LINK |
Pico 2 W Starter Kit |
450+ |
SN |
COMPONENT INTRODUCTION |
QUANTITY |
PURCHASE LINK |
Micro USB Cable |
Several |
7 |
8 |
Power Pack |
Schematic
You can open the file
3.5_small_fan.inounder the path ofpico-2w-kit-main/arduino/3.5_small_fan.Or copy this code into Arduino IDE.
Don’t forget to select the board(Raspberry Pi Pico) and the correct port before clicking the Upload button.
// Define the pins connected to the motor driver
const int motor1A = 14; // Motor control pin 1
const int motor2A = 15; // Motor control pin 2
// Initialize the motor control pins as OUTPUT
pinMode(motor1A, OUTPUT);
pinMode(motor2A, OUTPUT);
// Rotate the motor clockwise
clockwise();
delay(1000); // Keep the motor running clockwise for 1 second
// Stop the motor
stopMotor();
delay(1000); // Pause for 1 second
// Rotate the motor counterclockwise
anticlockwise();
delay(1000); // Keep the motor running counterclockwise for 1 second
// Stop the motor
stopMotor();
// Function to rotate the motor clockwise
void clockwise()
digitalWrite(motor1A, HIGH); // Set motor1A to HIGH
digitalWrite(motor2A, LOW); // Set motor2A to LOW
// This combination causes the motor to rotate in the clockwise direction
// Function to rotate the motor counterclockwise
void anticlockwise()
digitalWrite(motor1A, LOW); // Set motor1A to LOW
digitalWrite(motor2A, HIGH); // Set motor2A to HIGH
// This combination causes the motor to rotate in the counterclockwise direction
// Function to stop the motor
void stopMotor()
// Setting both pins LOW stops the motor
After uploading the code: the motor will rotate back and forth in a regular pattern.
Understanding the Code
Defining Control Pins:
const int motor1A = 14; // Motor control pin 1 const int motor2A = 15; // Motor control pin 2
Setting Pin Modes:
void setup() { pinMode(motor1A, OUTPUT); pinMode(motor2A, OUTPUT); }
Controlling Motor Direction:
Clockwise Rotation: Sets motor1 HIGH and motor2A LOW, causing the motor to rotate in the clockwise direction.
digitalWrite(motor1A, HIGH); // Set motor1A to HIGH digitalWrite(motor2A, LOW); // Set motor2A to LOW
Counterclockwise Rotation: Sets motor1A LOW and motor2A HIGH, causing the motor to rotate in the counterclockwise direction.
digitalWrite(motor1A, LOW); digitalWrite(motor2A, HIGH);
anticlockwise(); delay(1000);
Stopping the Motor:
Sets both inputs LOW, stopping the motor.
digitalWrite(motor1A, LOW); // Set motor1A to LOW digitalWrite(motor2A, LOW); // Set motor2A to LOW
Pause for 1 second
stopMotor(); delay(1000);
Further Exploration
Speed Control:
Use Pulse Width Modulation (PWM) to control the speed of the motor by connecting the EN1 pin to a PWM-capable GPIO pin and varying the duty cycle.
Sensor Integration:
Incorporate sensors (e.g., limit switches, encoders) to create more advanced motor control systems.
Safety Precautions
Power Supply:
Ensure that the external power supply voltage matches the motor’s voltage rating.
Do not power the motor directly from the Pico’s 3.3V pin.
Current Draw:
Motors can draw significant current, especially during startup or when stalled.
Ensure that your power supply can handle the motor’s current requirements.
Resetting the Pico:
In some cases, the motor’s current draw may cause voltage dips, leading the Pico to reset or disconnect.
If you encounter issues uploading code after running the motor, you can manually reset the Pico by connecting the RUN pin to GND momentarily.
Conclusion
In this lesson, you’ve learned how to control a DC motor using the Raspberry Pi Pico and the TA6586 motor driver. By controlling the inputs to the TA6586, you can change the direction of the motor’s rotation. This fundamental concept is essential in robotics, automation, and many other applications involving motors.
