šŸ‘‰ Ready to explore and create with us? Click [here] and join today!
3.5 Controlling a Small Fan (DC Motor)
In this lesson, we’ll learn how to control a DC motor (like a small fan) using the Raspberry Pi Pico 2 W and an TA6586 motor driver. The TA6586 allows us to control the direction of the motor rotation—both clockwise and counterclockwise. Since the DC motor requires a relatively large current, for safety reasons, here we use a power module to supply power to the motor.
ITEMS IN THIS KIT
Pico 2 W Starter Kit
450+
Pico 2 W Kit
SN
COMPONENT
QUANTITY
Getting to Know Pico 2 W
Micro USB Cable
Jumper Wires
Several
TA6586 - Motor Driver Chip
DC Motor
Li-po Charger Module
Power Pack
Schematic
sch_motor
  • Since DC motors require a high current, we use a Li-po Charger module to power the motor here for safety reasons.
  • Make sure your Li-po Charger Module is connected as shown in the diagram. Otherwise, a short circuit will likely damage your Power Pack and circuitry.
wiring_motor
  • Open the 3.5_small_fan.py from pico-2w-kit-main/micropython or copy the code into Thonny, then click ā€œRunā€ or press F5.
  • Ensure the correct interpreter is selected: MicroPython (Raspberry Pi Pico).COMxx.
import machine
import utime
motor1A = machine.Pin(14, machine.Pin.OUT)
motor2A = machine.Pin(15, machine.Pin.OUT)
def clockwise():
    motor1A.high()
    motor2A.low()
def anticlockwise():
    motor1A.low()
    motor2A.high()
def stopMotor():
    motor1A.low()
    motor2A.low()
    clockwise()
    utime.sleep(1)
    stopMotor()
    utime.sleep(1)
    anticlockwise()
    utime.sleep(1)
    stopMotor()
    utime.sleep(1)
Once the program is running, the motor will rotate back and forth in a regular pattern.
Understanding the Code
  1. Initialize the Pins:
    motor1A and motor2A are connected to GP14 and GP15, controlling the direction of the motor.
  2. Define Functions:
    • rotate_clockwise(): Sets motor1A high and motor2A low to rotate the motor clockwise.
    • rotate_counterclockwise(): Sets motor1A low and motor2A high to rotate counterclockwise.
    • stop_motor(): Sets both motor1A and motor2A low to stop the motor.
  3. Main Loop:
    The motor rotates clockwise, stops, rotates counterclockwise, and stops again, each for one second, repeatedly.
        clockwise()
        utime.sleep(1)
        stopMotor()
        utime.sleep(1)
        anticlockwise()
        utime.sleep(1)
        stopMotor()
        utime.sleep(1)
Troubleshooting Tips
  • Motor Keeps Spinning After Stopping the Script:
    If the motor continues to run after stopping the program, you may need to reset the Pico. Use a wire or a button to momentarily connect the RUN pin to GND, which resets the Pico.
    wiring_run_reset
  • Pico Disconnects or Becomes Unresponsive:
    The motor may draw too much current, causing voltage fluctuations. Ensure you’re using a separate power supply for the motor and that all grounds are connected.
Conclusion
In this lesson, you’ve learned how to control a DC motor using the TA6586 motor driver and the Raspberry Pi Pico 2 W. You can now control the motor’s direction and create projects like a small fan or a motorized device.
Next Steps
  • Speed Control: Try using PWM (Pulse Width Modulation) to control the speed of the motor by connecting the EN1 pin to a PWM-capable GPIO pin.
  • Control Multiple Motors: Use the other channels of the TA6586 to control additional motors.
  • Sensor Integration: Incorporate sensors to control the motor based on input (e.g., temperature, light).
