2.5 Reading Button Value
In this lesson, we’ll learn how to read input from a pushbutton using the Raspberry Pi Pico 2 W. So far, we’ve used the GPIO pins mainly for output, like lighting up LEDs. Now, we’ll use a GPIO pin as an input to detect when a button is pressed. This is a fundamental skill for creating interactive projects.
ITEMS IN THIS KIT
Pico 2 W Starter Kit
450+
Pico 2 W Kit
SN
COMPONENT
QUANTITY
Getting to Know Pico 2 W
Micro USB Cable
Jumper Wires
Several
Resistor
1(10KΩ)
Button
Circuit Diagram
sch_button
As long as one side of the button pin is connected to 3.3v, and the other side pin is connected to GP14, then when the button is pressed, GP14 will be high. However, when the button is not pressed, GP14 is in a suspended state and may be high or low. In order to get a stable low level when the button is not pressed, GP14 needs to be reconnected to GND through a 10K pull-down resistor.
  • Button Not Pressed: The GP14 pin is connected to GND through the resistor, so it reads LOW (0).
  • Button Pressed: The GP14 pin is connected to 3.3V through the button, so it reads HIGH (1).
Wiring Diagram
A four-pin button is shaped like an H. Its left two pins or right two pins are connected, which means that when it crosses the central gap, it connects two half rows with the same row number. (For example, in my circuit, E23 and F23 are already connected, as are E25 and F25).
Until the button is pressed, the left and right pins are independent of each other and current cannot flow from one side to the other.
wiring_button
Writing the Code
We’ll write a simple program that prints a message when the button is pressed.
  • Open the 2.5_read_button_value.py from pico-2w-kit-main/micropython or copy the code into Thonny, then click “Run” or press F5.
  • Ensure the correct interpreter is selected: MicroPython (Raspberry Pi Pico).COMxx.
import machine
import utime
# Initialize GP14 as an input pin
button = machine.Pin(14, machine.Pin.IN)
    if button.value() == 1:
        print("Button pressed!")
        utime.sleep(0.2)  # Debounce delay
When the code is running, you will observe the following phenomenon:
  • Not Pressed: No message should appear.
  • Pressed: “Button pressed!” should appear in the console each time you press the switch.
Understanding the Code
  1. Import Modules:
    • machine: Provides access to the hardware functions.
    • utime: Allows us to use time-related functions like delays.
  2. Set Up the Button Pin:
    • button = machine.Pin(14, machine.Pin.IN): Initializes GPIO pin 14 as an input.
  3. Main Loop:
    • while True: Creates an infinite loop.
    • if button.value() == 1: Checks if the button is pressed.
    • button.value() returns 1 when the pin reads high (button pressed).
    • print("Button pressed!"): Prints a message to the console.
    • utime.sleep(0.2): Waits for 200 milliseconds to debounce the button.
Alternate Wiring: Pull-Up Resistor
You can also wire the button using a pull-up resistor configuration.
  1. Connect a 10kΩ resistor between GP14 and the 3.3V rail. This pulls the pin high when the button is not pressed.
    sch_button_pullup
    wiring_button_pullup
    • Button Not Pressed: The GP14 pin is connected to 3.3V through the resistor, so it reads HIGH (1).
    • Button Pressed: The GP14 pin is connected to GND through the button, so it reads LOW (0).
  2. Modified Code for Pull-Up Configuration.
    import machine
    import utime
        if button.value() == 0:
            utime.sleep(0.2)
Using Internal Pull-Up/Pull-Down Resistors
The Raspberry Pi Pico 2 W allows you to enable internal pull-up or pull-down resistors, eliminating the need for external resistors.
Using internal resistors simplifies wiring and saves space by eliminating the need for additional external resistors on the breadboard.
  • Enabling Internal Pull-Down Resistor:
    import machine
    import utime
    # Initialize GP14 as an input with an internal pull-down resistor
    button = machine.Pin(14, machine.Pin.IN, machine.Pin.PULL_DOWN)
            utime.sleep(0.2)
  • Enabling Internal Pull-Up Resistor:
    import machine
    import utime
    # Initialize GP14 as an input with an internal pull-up resistor
    button = machine.Pin(14, machine.Pin.IN, machine.Pin.PULL_UP)
            utime.sleep(0.2)
Experimenting Further
  • Multiple Buttons: Connect additional buttons to other GPIO pins and modify the code to handle multiple inputs.
  • LED Control: Combine button input with LED output to toggle the LED state when the button is pressed.
import machine
import utime
led = machine.Pin(15, machine.Pin.OUT)
led_state = False
        led_state = not led_state  # Toggle LED state
        led.value(led_state)
        utime.sleep(0.2)
Conclusion
Reading input from a button is a fundamental skill in microcontroller programming. It allows you to make your projects interactive and responsive to user input. Understanding how to use pull-up and pull-down resistors ensures reliable and stable readings from your input devices.
