Video 32: Understanding and Using a Keypad with the Raspberry PiΒΆ
Learn how to efficiently incorporate a keypad into your Raspberry Pi projects using passive row-column addressing for input reading.
Introduction: Learn how to integrate a keypad into your Raspberry Pi projects.
Passive Row-Column Addressing: Understand the concept of passive addressing for efficient keypad input reading.
Wiring Setup: Discover the wiring setup using rows and columns for the keypad.
GPIO Pins Configuration: Set up GPIO pins as outputs for rows and inputs for columns.
Key Labeling: Create a matrix to label the keys on the keypad for easier reference.
Implementation: Follow along with the coding process to incorporate the keypad into your projects.
Video
