SunFounder davinci-kit-for-raspberry-pi
latest
  • Component List
  • Introduction
  • Preparation
  • Libraries
  • GPIO Extension Board
  • Download the Code
  • 1 Output
    • 1.1.1 Blinking LED
    • 1.1.2 RGB LED
    • 1.1.3 LED Bar Graph
    • 1.1.4 7-segment Display
    • 1.1.5 4-Digit 7-Segment Display
    • 1.1.6 LED Dot Matrix
    • 1.1.7 I2C LCD1602
    • 1.2.1 Active Buzzer
    • 1.2.2 Passive Buzzer
    • 1.3.1 Motor
    • 1.3.2 Servo
    • 1.3.3 Stepper Motor
    • 1.3.4 Relay
  • 2 Input
  • 3 Extension
  • 4 IOT
  • Play with Nodejs
  • Play with Processing
  • Play with Scratch
  • Appendix
  • FAQ
  • Thank You
  • Docs »
  • 1 Output
  • Edit on GitHub
1 OutputΒΆ
1.1 Displays
  • 1.1.2 RGB LED
  • 1.1.7 I2C LCD1602
1.2 Sound
1.3 Drivers
  • 1.3.1 Motor
  • 1.3.2 Servo
  • 1.3.4 Relay
Next Previous
© Copyright 2021, SunFounder Revision 0e355ad9.
Built with Sphinx using a theme provided by Read the Docs.
Read the Docs v: latest
Versions
latest
Downloads
pdf
html
epub
On Read the Docs
Project Home
Builds
Free document hosting provided by Read the Docs.
