Video 25: Measure Temperature and Humidity with the DHT-11 SensorΒΆ
In this tutorial, learn how to connect a DHT11 temperature and humidity sensor to a Raspberry Pi and read data from it using Python.
Introduction: Join us in this Raspberry Pi tutorial series sponsored by SunFounder.
Components Needed: Gather your Raspberry Pi, jumper cables, DHT11 sensor, and a 10k resistor.
Wiring Instructions: Follow detailed instructions to correctly wire the components together to avoid damaging the sensor.
Python Library Installation: Learn how to install the required Python library for interacting with the DHT11 sensor.
Code Implementation: Write Python code to read temperature and humidity data from the sensor and print it to the terminal.
Code Execution: See the code in action as it interprets the sensor readings.
Future Projects: Explore potential projects combining components from the SunFounder kit.
Video
