Video 30: Using a Photoresistor to Detect Light on the Raspberry Pi¶
Learn how to incorporate a photoresistor into your Raspberry Pi projects to measure light intensity and control actions based on brightness.
Introduction to the photoresistor: Learn how a photoresistor’s resistance changes with light intensity.
Physics behind the photoresistor: Understand the solid-state physics principles underlying the photoresistor’s operation.
Building the circuit: Discover how to create a voltage divider circuit using a photoresistor and a load resistor.
Programming the Raspberry Pi: Write Python code to read analog values from the photoresistor using the ADC0834 module.
Testing the circuit: See how the circuit responds to changes in lighting conditions, demonstrating changes in resistance and voltage.
Practical applications: Explore potential uses of photoresistors in projects such as automatic lighting systems.
Video
