FAQ
C code is not working?
  • Check your wiring for problems.
  • Check if the code is reporting errors, if so, refer to: Install and Check the WiringPi.
  • Has the code been compiled before running.
  • If all the above 3 conditions are OK, it may be that your wiringPi version (2.50) is not compatible with your Raspberry Pi 4B and above, refer to Install and Check the WiringPi to manually upgrade it to version 2.52.
If gpiozero doesn’t work.
Our Raspberry Pi 5 GPIO Python tutorial is based on the gpiozero library, and it has been thoroughly tested during the design process.
However, recent modifications to the Linux kernel on the Raspberry Pi OS [1] have changed the way GPIO system calls are handled, which has caused the original Python library to be unable to access GPIO on the Raspberry Pi 5. Our developers have reported this issue to the gpiozero library, and the gpiozero developers are aware of the issue and are actively working on an update [2].
In the meantime, we have found a temporary solution: by running the command below, the GPIO will function normally.
sudo ln -s gpiochip0 /dev/gpiochip4
This solution will remain effective until the gpiozero library releases an appropriate fix.
