Python Video Course
Dive into the Raspberry Pi universe with our concise Python Video Course, perfect for both beginners and hobbyists. Starting with an introduction to the Raspberry Pi’s capabilities, this series guides you through Python programming basics, including GPIO pin control and sensor integration. Progress through interactive projects, exploring key components like LEDs and LCD displays. This course equips you with essential skills for programming and hardware interfacing, making complex concepts accessible through practical execution. Join us to unlock the potential of Raspberry Pi in the digital world.
Warning
These videos are part of another kit of ours called the Raphael Kit. However, some of the content can also be used in this suite, resulting in breaks in certain lesson serial numbers.
Projects
- Video 1: First Boot
- Video 2: Mastering Linux Essentials and Command Line Basics on Raspberry Pi
- Video 3: Python Essentials in One Session
- Video 4: Understanding and Using GPIO Pins
- Video 5: Understanding Binary Numbers
- Video 6: Understanding GPIO Inputs, Pull Up and Pull Down Resistors
- Video 7: GPIO Inputs from Button Switch
- Video 8: Using a Button as a Toggle Switch for LED Control
- Video 9: Using GPIO Pins for PWM to Simulate Analog Output
- Video 10: Making a Dimmable LED with Two Push Buttons
- Video 11: Understanding and Using a RGB LED
- Video 12: Pushbutton Control of RGB LED
- Video 13: Set Color of RGB LED with Push Buttons
- Video 14: Installing Visual Python on the Raspberry Pi
- Video 15: Analog Input on the Raspberry Pi Using the ADC0834
- Video 16: Creating a Potentiometer Controlled Dimmable LED
- Video 17: Mixing Any Color on an RGB LED
- Video 18: Using a Joystick With the Raspberry Pi
- Video 19: Simple Control of Servo From Raspberry Pi
- Video 20: Controlling Position of a Servo With a Potentiometer
- Video 21: Using a HC-SR04 Ultrasonic Sensor For Echolocation
- Video 22: Measuring Distance with the HC-SR04 Ultrasonic Sensor
- Video 23: Measuring the Speed of Sound with an Ultrasonic Sensor
- Video 24: Using a PIR Motion Sensor with the Raspberry Pi
- Video 25: Measure Temperature and Humidity with the DHT-11 Sensor
- Video 26: Using an LCD1602 LCD Display with I2C
- Video 27: Build a Temperature and Humidity System with LCD Display
- Video 28: Understanding and Using Active and Passive Buzzers
- Video 29: Build a Programmable Temperature Sensing Alarm
- Video 30: Using a Photoresistor to Detect Light on the Raspberry Pi
- Video 31: Alarm for Detecting Motion in the Dark
- Video 32: Understanding and Using a Keypad with the Raspberry Pi
- Video 33: How to Incorporate a Keypad into a Raspberry Pi Project
- Video 34: Creating a Python Class and Library for Reading a Keypad
- Video 35: Create Mobile Raspberry Pi Projects with Keypad and LCD
- Video 36: Monitoring User Input from Keypad Using Threading
- Video 37: Motion Detection Alarm System With LCD and Keypad
- Video 38: Raspberry Pi Security System
- Video 39: Raspberry Pi Security System
- Video 40: Remotely Run Your Security Project Using Putty
- Video 41: How to Set Up a Remote Desktop on Raspberry Pi Using VNC
- Video 42: How to Send Data to the PC over WiFi or Ethernet Using UDP
- Video 43: How to Build a Simple Client Server System with Raspberry Pi
- Video 44: Building an Improved Client Server Connection to the Pi
- Video 69: Using the MFRC522 RFID Module and Tag on Raspberry Pi
- Video 70: Using the MFRC522 RFID Module and Tag on Raspberry Pi
