4.1.7 Smart Fan
In this project, we will use motors, buttons and thermistors to make a manual + automatic smart fan whose wind speed is adjustable.
../_images/4.1.10_smart_fan_list.png
ITEMS IN THIS KIT
COMPONENT INTRODUCTION
PURCHASE LINK
GPIO Extension Board
Jumper Wires
Resistor
Power Supply Module
Thermistor
L293D
ADC0834
Button
DC Motor
Schematic Diagram
T-Board Name
physical
wiringPi
GPIO17
Pin 11
0
17
GPIO18
Pin 12
GPIO27
Pin 13
GPIO22
Pin 15
GPIO5
Pin 29
21
GPIO6
Pin 31
22
GPIO13
Pin 33
23
13
../_images/4.1.10_smart_fan_schematic.png
Experimental Procedures
Step 1: Build the circuit.
../_images/4.1.10_smart_fan_circuit.png
The power module can apply a 9V battery with the 9V Battery Buckle in the kit. Insert the jumper cap of the power module into the 5V bus strips of the breadboard.
../_images/4.1.10_smart_fan_battery.jpeg
Step 2: Get into the folder of the code.
cd ~/raphael-kit/python-pi5
Step 3: Run.
sudo python3 4.1.10_SmartFan_zero.py
As the code runs, start the fan by pressing the button. Every time you press, 1 speed grade is adjusted up or down. There are 5 kinds of speed grades: 0~4. When set to the 4th speed grade and you press the button, the fan stops working with a 0 wind speed.
Once the temperature goes up or down for more than 2℃, the speed automatically gets 1-grade faster or slower.
You can Modify/Reset/Copy/Run/Stop the code below. But before that, you need to go to source code path like raphael-kit/python-pi5. After modifying the code, you can run it directly to see the effect.
 from gpiozero import Motor, Button
 from time import sleep
import ADC0834
 import math
 # Initialize GPIO pins for the button and motor control
BtnPin = Button(22)
motor = Motor(forward=5, backward=6, enable=13)
# Initialize the ADC0834 module for temperature sensing
ADC0834.setup()
 # Initialize variables to track the motor speed level and temperatures
 level = 0
 currentTemp = 0
 markTemp = 0
 def temperature():
     Reads and calculates the current temperature from the sensor.
     Returns:
         float: The current temperature in Celsius.
    # Read analog value from the ADC0834 module
    # Convert analog value to voltage and then to resistance
    Vr = 5 * float(analogVal) / 255
    Rt = 10000 * Vr / (5 - Vr)
    # Calculate temperature in Celsius
    temp = 1 / (((math.log(Rt / 10000)) / 3950) + (1 / (273.15 + 25)))
     Cel = temp - 273.15
     return Cel
 def motor_run(level):
     Adjusts the motor speed based on the specified level.
     Args:
         level (int): Desired motor speed level.
     Returns:
         int: Adjusted motor speed level.
    # Stop the motor if the level is 0
     if level == 0:
         motor.stop()
         return 0
    # Cap the level at 4 for maximum speed
     if level >= 4:
         level = 4
    # Set the motor speed
     motor.forward(speed=float(level / 4))
     return level
 def changeLevel():
     Changes the motor speed level when the button is pressed and updates the reference temperature.
     global level, currentTemp, markTemp
     print("Button pressed")
    # Cycle through levels 0-4
     level = (level + 1) % 5
    # Update the reference temperature
     markTemp = currentTemp
 # Bind the button press event to changeLevel function
 BtnPin.when_pressed = changeLevel
 def main():
     Main function to continuously monitor and respond to temperature changes.
    # Set initial reference temperature
     markTemp = temperature()
        # Continuously read current temperature
         currentTemp = temperature()
        # Adjust motor level based on temperature difference
         if level != 0:
             if currentTemp - markTemp <= -2:
                 level -= 1
             elif currentTemp - markTemp >= 2:
                 if level < 4:
                     level += 1
        # Run the motor at the adjusted level
         level = motor_run(level)
 # Run the main function and handle KeyboardInterrupt
     main()
    # Stop the motor when the script is interrupted
     motor.stop()
Code Explanation
  1. Imports classes for managing a motor and a button, and the sleep function for introducing pauses. Additionally, it imports the ADC0834 library for temperature sensing and the math library for mathematical calculations.
    import ADC0834
    import math
  2. Sets up the button on GPIO pin 22 and configures the motor with specific GPIO pins for control. Initializes the ADC0834 module for temperature measurement. Also, initializes variables to monitor the motor speed level and temperatures.
    BtnPin = Button(22)
    ADC0834.setup()
    level = 0
    currentTemp = 0
    markTemp = 0
  3. Defines a function to read and calculate the temperature from the sensor, converting the readout to Celsius.
    def temperature():
        Returns:
        Cel = temp - 273.15
        return Cel
  4. Introduces a function to adjust the motor speed according to the specified level.
        Args:
        Returns:
        if level == 0:
            motor.stop()
            return 0
        if level >= 4:
            level = 4
        return level
  5. Implements a function to change the motor speed level manually using a button, and binds this function to the button’s press event.
    def changeLevel():
  6. The main function, designed to continually adjust the motor speed in response to temperature fluctuations, remains to be implemented.
    def main():
            if level != 0:
                    level -= 1
                    if level < 4:
                        level += 1
  7. Runs the main function and ensures the motor stops if the script is interrupted.
        main()
        motor.stop()
