4.1.3 Magnetic Induction Alarm System
When you get a precious vase, you can make a magnetic induction alarm system for it, no matter who moves it, you can hear the alarm in time.
../_images/4.1.6_magneticalarmsystem_list.png
ITEMS IN THIS KIT
COMPONENT INTRODUCTION
PURCHASE LINK
GPIO Extension Board
Jumper Wires
Resistor
Buzzer
Transistor
Reed Switch Module
Schematic Diagram
T-Board Name
physical
wiringPi
GPIO17
Pin 11
0
17
GPIO27
Pin 13
../_images/4.1.6_magneticalarmsystem_schematic.png
Experimental Procedures
Step 1: Build the circuit.
../_images/4.1.6_magneticalarmsystem_circuit.png
Step 2: Get into the folder of the code.
cd ~/raphael-kit/python-pi5
Step 3: Run.
sudo python3 4.1.6_MagneticAlarmSystem_zero.py
If the reed switch is affected by the magnet (for example, the reed switch is placed on the base and the magnet is placed in the vase), the object is safe. At this time, the reed switch is in the closed state, and the buzzer is silent. After removing the magnet (such as the vase being stolen), the reed switch is not affected by the magnetic, the switch opens, and the buzzer sounds an alarm.
Warning
You can Modify/Reset/Copy/Run/Stop the code below. But before that, you need to go to source code path like raphael-kit/python-pi5. After modifying the code, you can run it directly to see the effect.
from gpiozero import Buzzer, Button
# Initialize the buzzer on GPIO pin 27
buzzer = Buzzer(27)
# Initialize the reed switch on GPIO pin 17 with pull-up resistor enabled
reed_switch = Button(17, pull_up=True)
        # Check if the reed switch is pressed
        if reed_switch.is_pressed:
            # Turn off the buzzer if reed switch is pressed
            buzzer.off()
            # If reed switch is not pressed, beep the buzzer
            buzzer.on()
            time.sleep(0.1)  # Buzzer on for 0.1 seconds
            buzzer.off()
            time.sleep(0.1)  # Buzzer off for 0.1 seconds
    # Turn off the buzzer when the program is interrupted (e.g., keyboard interrupt)
    buzzer.off()
Code Explanation
  1. This imports the necessary classes Buzzer and Button from the gpiozero library, and the time module from Python’s standard library.
  2. The Buzzer object is linked to GPIO pin 27, and a Button (acting as a reed switch) is connected to GPIO pin 17 with the pull_up=True argument, enabling the internal pull-up resistor.
    buzzer = Buzzer(27)
  3. The try block contains an infinite loop (while True) checking the state of the reed switch. If pressed (is_pressed), the buzzer is turned off. Otherwise, the buzzer beeps (0.1 seconds on, 0.1 seconds off).
                buzzer.off()
                buzzer.on()
                buzzer.off()
  4. The except block handles a KeyboardInterrupt (like a Ctrl+C in the terminal) to turn off the buzzer safely.
        buzzer.off()
