๐ Ready to explore and create with us? Click [here] and join today!
4.1.8 Battery Indicator๏
Introduction๏
In this project, we will make a battery indicator device that can visually display the battery level on the LED Bargraph.
Warning
Do not use battery components that exceed 3.3V to avoid overloading, which may damage the chip or Raspberry Pi.
Required Components๏
Itโs definitely convenient to buy a whole kit, hereโs the link:
Raphael Kit |
337 |
COMPONENT INTRODUCTION |
PURCHASE LINK |
Schematic Diagram๏
T-Board Name |
physical |
wiringPi |
BCM |
GPIO17 |
Pin 11 |
0 |
17 |
GPIO18 |
Pin 12 |
18 |
GPIO27 |
Pin 13 |
27 |
GPIO25 |
Pin 22 |
25 |
GPIO12 |
Pin 32 |
26 |
12 |
GPIO16 |
Pin 36 |
27 |
16 |
GPIO20 |
Pin 38 |
28 |
20 |
GPIO21 |
Pin 40 |
29 |
21 |
GPIO5 |
Pin 29 |
21 |
GPIO6 |
Pin 31 |
22 |
GPIO13 |
Pin 33 |
23 |
13 |
GPIO19 |
Pin 35 |
24 |
19 |
GPIO26 |
Pin 37 |
25 |
26 |
Experimental Procedures๏
Step 1: Build the circuit.
cd ~/raphael-kit/python-pi5
Step 3: Run the executable file.
sudo python3 4.1.11_BatteryIndicator_zero.py
After the program runs, give the 3rd pin of ADC0834 and the GND a lead-out wire separately and then lead them to the two poles of a battery separately. You can see the corresponding LED on the LED Bargraph is lit up to display the power level (measuring range: 0-5V).
Warning
If there is an error prompt RuntimeError: Cannot determine SOC peripheral base address, please refer to If gpiozero doesnโt work.
You can Modify/Reset/Copy/Run/Stop the code below. But before that, you need to go to source code path like raphael-kit/python-pi5. After modifying the code, you can run it directly to see the effect.
from gpiozero import LED
import spidev
# List of GPIO pins to which LEDs are connected
ledPins = [25, 12, 16, 20, 21, 5, 6, 13, 19, 26]
# Initialize LED objects for each pin in the list
leds = [LED(pin) for pin in ledPins]
# Setup SPI for MCP3008
spi = spidev.SpiDev()
spi.open(0, 0) # Open SPI bus 0, device (CE0)
spi.max_speed_hz = 1000000 # Set SPI speed to 1 MHz
def read_adc(channel=0):
Reads analog value from MCP3008 channel (default CH0).
Returns a 10-bit value .
return -1
value = ((r[1] & 0x03) << 8) | r[2]
return value
def LedBarGraph(value):
# Turn off all LEDs
for i in range(10):
leds[i].on()
# Turn on LEDs up to the specified value
for i in range(min(value, 10)):
leds[i].off()
# Main loop to continuously update LED bar graph
analogVal = read_adc(0) # Read from CH0
LedBarGraph(int(analogVal / 102.4))
time.sleep(0.1)
# Turn off all LEDs when program is interrupted
for i in range(10):
leds[i].off()
spi.close()
Code Explanation๏
This section imports the necessary libraries. gpiozero is used for controlling GPIO pins (specifically LEDs), spidev is used to interface with the MCP3008 ADC over SPI, and time is used for delays.
#!/usr/bin/env python3 from gpiozero import LED import spidev import time
Defines the GPIO pins to which the LEDs are connected and creates a list of LED objects. These are used to represent a bar graph.
# List of GPIO pins to which LEDs are connected ledPins = [25, 12, 16, 20, 21, 5, 6, 13, 19, 26] # Initialize LED objects for each pin in the list leds = [LED(pin) for pin in ledPins]
Initializes SPI communication for the MCP3008 ADC on SPI bus 0 using CE0. The speed is set to 1 MHz.
# Setup SPI for MCP3008 spi = spidev.SpiDev() spi.open(0, 0) # Open SPI bus 0, device (CE0) spi.max_speed_hz = 1000000 # Set SPI speed to 1 MHz
Reads a 10-bit analog value (0โ1023) from the specified MCP3008 channel. Channel 0 is used by default.
def read_adc(channel=0): """ Reads analog value from MCP3008 channel (default CH0). Returns a 10-bit value . """ if channel < 0 or channel > 7: return -1 r = spi.xfer2([1, (8 + channel) << 4, 0]) value = ((r[1] & 0x03) << 8) | r[2] return value
This function turns on all LEDs first (reset state), then turns off a number of LEDs based on the scaled input value. It creates a reverse bar graph effect (more value = fewer LEDs lit).
def LedBarGraph(value): # Turn off all LEDs for i in range(10): leds[i].on() # Turn on LEDs up to the specified value for i in range(min(value, 10)): leds[i].off()
Continuously reads the analog value from MCP3008 CH0 and updates the LED bar graph. The analog value is divided by 102.4 to scale it from 0โ1023 to a 0โ10 LED level.
try: # Main loop to continuously update LED bar graph while True: analogVal = read_adc(0) # Read from CH0 LedBarGraph(int(analogVal / 102.4)) time.sleep(0.1)
Ensures all LEDs are turned off and SPI is closed when the program is interrupted (e.g., by pressing Ctrl+C).
except KeyboardInterrupt: # Turn off all LEDs when program is interrupted for i in range(10): leds[i].off() spi.close()
