4.1.9 Traffic Light
In this project, we will use LED lights of three colors to realize the change of traffic lights and a four-digit 7-segment display will be used to display the timing of each traffic state.
../_images/4.1.12_traffic_light_list.png
ITEMS IN THIS KIT
COMPONENT INTRODUCTION
PURCHASE LINK
GPIO Extension Board
Jumper Wires
Resistor
LED
4-Digit 7-Segment Display
74HC595
Schematic Diagram
T-Board Name
physical
wiringPi
GPIO17
Pin 11
0
17
GPIO27
Pin 13
GPIO22
Pin 15
SPIMOSI
Pin 19
12
10
GPIO18
Pin 12
GPIO23
Pin 16
GPIO24
Pin 18
GPIO25
Pin 22
SPICE0
Pin 24
10
8
SPICE1
Pin 26
11
7
../_images/4.1.12_traffic_light_schematic.png
Experimental Procedures
Step 1: Build the circuit.
../_images/4.1.12_traffic_light_circuit.png
Step 2: Change directory.
cd ~/raphael-kit/python-pi5
Step 3: Run.
sudo python3 4.1.12_TrafficLight_zero.py
As the code runs, LEDs will simulate the color changing of traffic lights. Firstly, the red LED lights up for 60s, then the green LED lights up for 30s; next, the yellow LED lights up for 5s. After that, the red LED lights up for 60s once again. In this way, this series of actions will be executed repeatedly. Meanwhile, the 4-digit 7-segment display displays the countdown time continuously.
You can Modify/Reset/Copy/Run/Stop the code below. But before that, you need to go to source code path like raphael-kit/python-pi5. After modifying the code, you can run it directly to see the effect.
from gpiozero import OutputDevice, LED
import threading
# Setup GPIO pins for 74HC595 shift register
SDI = OutputDevice(24)   # Serial Data Input
RCLK = OutputDevice(23)  # Register Clock
SRCLK = OutputDevice(18) # Shift Register Clock
# Setup GPIO pins for digit selection on 7-segment display
placePin = [OutputDevice(pin) for pin in (10, 22, 27, 17)]
# Segment codes for numbers 0-9 on 7-segment display
# Setup GPIO pins for traffic light LEDs
ledPinR = LED(25) # Red LED
ledPinG = LED(8)  # Green LED
ledPinY = LED(7)  # Yellow LED
# Duration settings for traffic lights
greenLight = 30
yellowLight = 5
redLight = 60
# Traffic light color names
lightColor = ("Red", "Green", "Yellow")
# Initialize state variables
colorState = 0
counter = 60
timer1 = None
def setup():
    """ Initialize the traffic light system and start the timer. """
    global timer1
    timer1 = threading.Timer(1.0, timer)
    timer1.start()
def clearDisplay():
    """ Clear the 7-segment display. """
    for _ in range(8):
        SDI.on()
        SRCLK.on()
        SRCLK.off()
    RCLK.on()
    RCLK.off()
def hc595_shift(data):
    """ Shift data to the 74HC595 shift register for digit display. """
    for i in range(8):
        SDI.value = 0x80 & (data << i)
        SRCLK.on()
        SRCLK.off()
    RCLK.on()
    RCLK.off()
def pickDigit(digit):
    """ Select a specific digit to display on the 7-segment display. """
    for pin in placePin:
        pin.off()
    placePin[digit].on()
def timer():
    """ Handle the timing for traffic light changes. """
    global counter, colorState, timer1
    timer1.start()
    counter -= 1
    if counter == 0:
        counter = [greenLight, yellowLight, redLight][colorState]
        colorState = (colorState + 1) % 3
    print(f"counter : {counter}    color: {lightColor[colorState]}")
def lightup():
    """ Update the traffic light LED based on the current state. """
    global colorState
    ledPinR.off()
    ledPinG.off()
    ledPinY.off()
    [ledPinR, ledPinG, ledPinY][colorState].on()
def display():
    """ Display the current counter value on the 7-segment display. """
    global counter
    for i in range(4):
        digit = counter // (10 ** (3 - i)) % 10
        if i == 0 and digit == 0:
            continue
        clearDisplay()
        pickDigit(3 - i)
        hc595_shift(number[digit])
def loop():
    """ Main loop to continuously update display and lights. """
        display()
        lightup()
def destroy():
    """ Clean up resources when the script is terminated. """
    global timer1
    timer1.cancel()
    ledPinR.off()
    ledPinG.off()
    ledPinY.off()
    setup()
    loop()
    destroy()
Code Explanation
  1. Imports the OutputDevice and LED classes from the gpiozero library, enabling control of general output devices and specifically LEDs. Imports Python’s threading module, which will be used for creating and handling threads for concurrent execution.
    import threading
  2. Initializes GPIO pins connected to the shift register’s Serial Data Input (SDI), Register Clock Input (RCLK), and Shift Register Clock Input (SRCLK).
  3. Initializes the pins for each digit of the 7-segment display and defines the binary codes for displaying numbers 0-9.
  4. Initializes GPIO pins for the Red, Green, and Yellow LEDs used in the traffic light simulation. Sets the duration (in seconds) for each color state in the traffic light system. Defines the names of the traffic light colors for reference.
    greenLight = 30
    yellowLight = 5
    redLight = 60
  5. Initializes variables for tracking the current color state, a counter for timing, and a placeholder for a timer object.
    colorState = 0
    counter = 60
    timer1 = None
  6. Initializes the traffic light system and starts the timer thread.
    def setup():
        global timer1
        timer1.start()
  7. Functions to control the 7-segment display. clearDisplay turns off all segments, hc595_shift shifts data into the shift register, and pickDigit activates a specific digit on the display.
    def clearDisplay():
        for _ in range(8):
            SDI.on()
            SRCLK.on()
            SRCLK.off()
        RCLK.on()
        RCLK.off()
        for i in range(8):
            SRCLK.on()
            SRCLK.off()
        RCLK.on()
        RCLK.off()
            pin.off()
  8. Manages the timing for traffic light changes and updates the counter and color state.
    def timer():
        timer1.start()
        counter -= 1
        if counter == 0:
  9. Updates the state of the traffic light LEDs based on the current color state.
    def lightup():
        global colorState
        ledPinR.off()
        ledPinG.off()
        ledPinY.off()
  10. Calculates the digit to be displayed on each segment of the 7-segment display and updates it accordingly.
    def display():
        global counter
        for i in range(4):
                continue
            clearDisplay()
            pickDigit(3 - i)
  11. The main loop that continuously updates the display and the traffic light LEDs.
    def loop():
            display()
            lightup()
  12. Cleans up resources when the script is terminated, such as turning off LEDs and stopping the timer thread.
    def destroy():
        global timer1
        timer1.cancel()
        ledPinR.off()
        ledPinG.off()
        ledPinY.off()
