4.1.13 Morse Code Generatorο
Introductionο
In this project, weβll make a Morse code generator, where you type in a series of English letters in the Raspberry Pi to make it appear as Morse code.
Required Componentsο
Raphael Kit |
337 |
COMPONENT INTRODUCTION |
PURCHASE LINK |
Schematic Diagramο
T-Board Name |
physical |
wiringPi |
BCM |
GPIO17 |
Pin 11 |
0 |
17 |
GPIO22 |
Pin 15 |
22 |
Experimental Proceduresο
Step 1: Build the circuit. (Pay attention to poles of the buzzer: The one with + label is the positive pole and the other is the negative.)
Step 2: Open the code file.
cd ~/raphael-kit/python-pi5
Step 3: Run.
sudo python3 4.1.16_MorseCodeGenerator_zero.py
After the program runs, type a series of characters, and the buzzer and the LED will send the corresponding Morse code signals.
Warning
If there is an error prompt RuntimeError: Cannot determine SOC peripheral base address, please refer to If gpiozero doesnβt work.
from gpiozero import Buzzer, LED
# Initialize Buzzer and LED to GPIO pins
BeepPin = Buzzer(22)
ALedPin = LED(17)
# Morse code representation for characters
MORSECODE = {
'A': '01', 'B': '1000', 'C': '1010', 'D': '100', 'E': '0', 'F': '0010', 'G': '110',
'H': '0000', 'I': '00', 'J': '0111', 'K': '101', 'L': '0100', 'M': '11', 'N': '10',
'O': '111', 'P': '0110', 'Q': '1101', 'R': '010', 'S': '000', 'T': '1',
'U': '001', 'V': '0001', 'W': '011', 'X': '1001', 'Y': '1011', 'Z': '1100',
'1': '01111', '2': '00111', '3': '00011', '4': '00001', '5': '00000',
'6': '10000', '7': '11000', '8': '11100', '9': '11110', '0': '11111',
'?': '001100', '/': '10010', ',': '110011', '.': '010101', ';': '101010',
'!': '101011', '@': '011010', ':': '111000',
def on():
""" Turn on the buzzer and LED. """
BeepPin.on()
ALedPin.on()
def off():
""" Turn off the buzzer and LED. """
BeepPin.off()
ALedPin.off()
def beep(dt): # dt for delay time.
Produce a beep sound and LED flash for the specified duration.
:param dt: Duration for the beep and flash.
on()
time.sleep(dt)
off()
time.sleep(dt)
def morsecode(code):
Convert the input code into Morse code and signal it using the buzzer and LED.
:param code: The text to be converted to Morse code.
pause = 0.25
for letter in code:
for tap in MORSECODE[letter]:
if tap == '0':
beep(pause / 2) # Short beep for dot
if tap == '1':
beep(pause) # Long beep for dash
time.sleep(pause) # Pause between letters
def destroy():
""" Clean up resources on script termination. """
print("")
BeepPin.off()
ALedPin.off()
code = input("Please input the messenger:")
code = code.upper() # Convert to uppercase for Morse code lookup
print(code)
morsecode(code)
destroy()
Code Explanation
This code imports the Buzzer and LED classes from the gpiozero library. These classes are essential for controlling the corresponding GPIO devices on the Raspberry Pi.
#!/usr/bin/env python3 from gpiozero import Buzzer, LED import time
Initializes the buzzer on GPIO pin 22 and the LED on GPIO pin 17, facilitating the control of these components.
# Initialize Buzzer and LED to GPIO pins BeepPin = Buzzer(22) ALedPin = LED(17)
Defines the
MORSEstructure, a dictionary containing Morse code representations for characters A-Z, numbers 0-9, and symbols like β?β, β/β, β:β, β,β, β.β, β;β, β!β, β@β, with0signifying a dot and1indicating a dash.# Morse code representation for characters MORSECODE = { 'A': '01', 'B': '1000', 'C': '1010', 'D': '100', 'E': '0', 'F': '0010', 'G': '110', 'H': '0000', 'I': '00', 'J': '0111', 'K': '101', 'L': '0100', 'M': '11', 'N': '10', 'O': '111', 'P': '0110', 'Q': '1101', 'R': '010', 'S': '000', 'T': '1', 'U': '001', 'V': '0001', 'W': '011', 'X': '1001', 'Y': '1011', 'Z': '1100', '1': '01111', '2': '00111', '3': '00011', '4': '00001', '5': '00000', '6': '10000', '7': '11000', '8': '11100', '9': '11110', '0': '11111', '?': '001100', '/': '10010', ',': '110011', '.': '010101', ';': '101010', '!': '101011', '@': '011010', ':': '111000', }
The function
on()starts the buzzer and the LED. The functionoff()is used to turn off the buzzer and the LED.def on(): """ Turn on the buzzer and LED. """ BeepPin.on() ALedPin.on() def off(): """ Turn off the buzzer and LED. """ BeepPin.off() ALedPin.off()
Define a function
beep()to make the buzzer and the LED emit sounds and blink in a certain interval ofdt.def beep(dt): # dt for delay time. """ Produce a beep sound and LED flash for the specified duration. :param dt: Duration for the beep and flash. """ on() time.sleep(dt) off() time.sleep(dt)
The function
morsecode()is used to process the Morse code of input characters by making the β1β of the code keep emitting sounds or lights and the β0βshortly emit sounds or lights, ex., input βSOSβ, and there will be a signal containing three short three long and then three short segments β Β· Β· Β· - - - Β· Β· Β· β.def morsecode(code): """ Convert the input code into Morse code and signal it using the buzzer and LED. :param code: The text to be converted to Morse code. """ pause = 0.25 for letter in code: for tap in MORSECODE[letter]: if tap == '0': beep(pause / 2) # Short beep for dot if tap == '1': beep(pause) # Long beep for dash time.sleep(pause) # Pause between letters
Defines a function named
destroythat turns off both the buzzer and the LED. This function is intended to be called when the script is terminated to ensure that the GPIO pins are not left in an active state.def destroy(): """ Clean up resources on script termination. """ print("") BeepPin.off() ALedPin.off()
When you type the relevant characters with the keyboard,
upper()will convert the input letters to their capital form.printf()then prints the clear text on the computer screen, and themorsecod()function causes the buzzer and the LED to emit Morse code.try: while True: code = input("Please input the messenger:") code = code.upper() # Convert to uppercase for Morse code lookup print(code) morsecode(code) except KeyboardInterrupt: destroy()
