Power Supply Module¶
When we need a large current to drive a component, which will severely interfere with the normal work of Raspberry Pi. Therefore, we separately supply power for the component by this module to make it run safely and steadily.
You can just plug it in the breadboard to supply power. It provides a voltage of 3.3V and 5V, and you can connect either via a jumper cap included.
../_images/power_supply.png
Features and specifications
  • Input voltage: 6.5 - 12V
  • Two Independent Channel
  • Output voltage: 5V, 3.3V (adjustable via jumpers. 0V, 3.3V, and 5V configuration)
  • Output current: Maximum output current 700mA
  • Onboard berg male header for GND, 5V, 3.3V output
  • ON-OFF Switch available.
  • USB (Type-A) input available.
  • DC Barrel Jack input available.
  • Onboard power LED
  • Dimension: 53mm x 33mm (L x W)
Example
