3.1.7 Overheat Monitor(MCP3008)
You may want to make an overheat monitoring device that applies to various situations, ex., in the factory, if we want to have an alarm and the timely automatic turning off of the machine when there is a circuit overheating. In this project, we will use thermistor, joystick, buzzer, LED and LCD to make an smart temperature monitoring device whose threshold is adjustable.
../_images/list2_Overheat_Monitor.png
ITEMS IN THIS KIT
COMPONENT INTRODUCTION
PURCHASE LINK
GPIO Extension Board
Jumper Wires
Resistor
LED
Joystick Module
MCP3008
Transistor
I2C LCD1602
Thermistor
Buzzer
Schematic Diagram
T-Board Name
physical
wiringPi
SPICE0
Pin 24
10
8
SPIMOSI
Pin 19
12
10
SPIMISO
Pin 21
13
9
SPISCLK
Pin 23
14
11
GPIO22
Pin15
GPIO23
Pin16
GPIO24
Pin18
SDA1
Pin 3
SCL1
Pin 5
../_images/Schematic_three_one8.png
Experimental Procedures
Step 1: Build the circuit.
../_images/july24_3.1.8_overheat_monitor_mcp3008.png
cd ~/raphael-kit/c/3.1.7-2/
Step 3: Compile the code.
gcc 3.1.7_OverheatMonitor.c -lm -lwiringPi
As the code runs, the current temperature and the high-temperature threshold 40 are displayed on I2C LCD1602. If the current temperature is larger than the threshold, the buzzer and LED are started to alarm you.
Joystick here is for your pressing to adjust the high-temperature threshold. Toggling the Joystick in the direction of X-axis and Y-axis can adjust (turn up or down) the current high-temperature threshold. Press the Joystick once again to reset the threshold to initial value.
  • If there is an error prompt wiringPi.h: No such file or directory, please refer to Install and Check the WiringPi.
  • If you get Unable to open I2C device: No such file or directory error, you need to refer to I²C Configuration to enable I2C and check if the wiring is correct.
  • If the code and wiring are fine, but the LCD still does not display content, you can turn the potentiometer on the back to increase the contrast.
Code Explanation
#include <wiringPi.h>
#include <stdio.h>
#include <wiringPiI2C.h>
#include <wiringPiSPI.h>
#include <string.h>
#include <math.h>
typedef unsigned char uchar;
typedef unsigned int  uint;
#define Joy_BtnPin 3      // GPIO22 -> WiringPi 3
#define buzzPin    4      // GPIO23 -> WiringPi 4
#define LedPin     5      // GPIO24 -> WiringPi 5
#define SPI_CHANNEL 0
#define SPI_SPEED   1000000
int LCDAddr    = 0x27;
int BLEN       = 1;
int fd;
int upperTem   = 40;
// Global variable to store the last joystick change
int lastJoystickChange = 0;
int read_ADC(int channel) {
    unsigned char buffer[3];
    buffer[0] = 1;
    buffer[1] = (8 + channel) << 4;
    buffer[2] = 0;
    return ((buffer[1] & 0x03) << 8) | buffer[2];
void write_word(int data){
    int temp = data;
    if (BLEN)      temp |= 0x08;
    else           temp &= 0xF7;
    wiringPiI2CWrite(fd, temp);
void send_command(int comm){
    int buf = comm & 0xF0;
    buf |= 0x04; write_word(buf); delay(2); buf &= 0xFB; write_word(buf);
    buf = (comm & 0x0F) << 4;
void send_data(int data){
    int buf = data & 0xF0;
    buf |= 0x05; write_word(buf); delay(2); buf &= 0xFB; write_word(buf);
    buf = (data & 0x0F) << 4;
void lcd_init(){
    send_command(0x33); delay(5);
    send_command(0x32); delay(5);
    send_command(0x28); delay(5);
    send_command(0x0C); delay(5);
    send_command(0x01); wiringPiI2CWrite(fd, 0x08);
void lcd_clear(){
    send_command(0x01);
void write_lcd(int x, int y, const char data[]){
    int addr = 0x80 + 0x40 * y + x;
    send_command(addr);
    for (int i = 0; i < (int)strlen(data); i++)
        send_data(data[i]);
int get_joystick_value(){
    int x = read_ADC(1);
    int y = read_ADC(2);
    // Dead-band filtering to reduce small fluctuations
    if (x > 900)      return  1;   //    else if (x < 100) return -1;   //     else if (y > 900) return -10;  //     else if (y < 100) return  10;  //    else              return   0;
void upper_tem_setting(){
    write_lcd(0,0, "Upper Adjust:");
    int change = get_joystick_value();
    // Only respond to actual direction change
    if (change != 0 && change != lastJoystickChange) {
        upperTem += change;
        lastJoystickChange = change;
    else if (change == 0) {
        // Allow next change after returning to center
    // Display current upperTem
    char str[6];
    snprintf(str, sizeof(str), "%d", upperTem);
    write_lcd(0,1, str);
    // Clear remaining LCD characters
    write_lcd(strlen(str),1, "            ");
    delay(100);
double temperature(){
    int raw = read_ADC(0);
    double Vr = 3.3 * ((double)raw / 1023.0);
    double Rt = 10000.0 * Vr / (3.3 - Vr);
    double tempK = 1.0 / ((log(Rt/10000.0)/3950.0) + 1.0/(273.15+25.0));
    return tempK - 273.15;
void monitoring_temp(){
    char str[6];
    double cel = temperature();
    snprintf(str, sizeof(str), "%.2f", cel);
    write_lcd(0,0, "Temp: ");
    write_lcd(6,0, str);
    write_lcd(0,1, "Upper: ");
    write_lcd(7,1, str);
    delay(100);
    if (cel >= upperTem) {
        digitalWrite(buzzPin, HIGH);
        digitalWrite(LedPin,  HIGH);
    } else {
        digitalWrite(buzzPin, LOW);
        digitalWrite(LedPin,  LOW);
void setup_all(){
    lcd_init();
    if (wiringPiSetup() == -1 ||
        wiringPiSPISetup(SPI_CHANNEL, SPI_SPEED) == -1) {
        printf("Setup failed!\n");
        return;
    pinMode(Joy_BtnPin, INPUT);
    pullUpDnControl(Joy_BtnPin, PUD_UP);
    pinMode(buzzPin, OUTPUT);
    pinMode(LedPin,  OUTPUT);
int main(void){
    setup_all();
    int lastBtnState = HIGH;
    int stage = 0;
    while (1) {
        int curBtn = digitalRead(Joy_BtnPin);
        // Switch mode when button changes from LOW to HIGH (button released)
        if (curBtn == HIGH && lastBtnState == LOW) {
            stage = (stage + 1) % 2;
            lastJoystickChange = 0;  // Clear debounce status
            delay(100);
            lcd_clear();
        lastBtnState = curBtn;
        if (stage == 1)
            upper_tem_setting();
        else
            monitoring_temp();
Code Explanation
    buffer[0] = 1;
    buffer[2] = 0;
Reads a 10-bit analog value from MCP3008 channel (CH0–CH7) using SPI and returns an integer from 0 to 1023.
int get_joystick_value() {
    if (x > 900)      return 1;   // Right
    else if (x < 100) return -1;  // Left
    else if (y > 900) return -10; // Up
    else if (y < 100) return 10;  // Down
    else              return 0;
Reads joystick X and Y analog values from CH1 and CH2. Returns an integer indicating movement direction based on thresholds.
void upper_tem_setting() {
        upperTem += change;
    char str[6];
    delay(100);
Allows user to adjust the upper temperature threshold using the joystick. Prevents repeated changes if direction is held.
double temperature() {
Reads analog value from CH0 connected to the thermistor. Uses the Steinhart–Hart equation to calculate Celsius temperature.
void monitoring_temp() {
    char str[6];
    delay(100);
    } else {
Continuously reads the current temperature and displays it along with the threshold. If the temperature exceeds the threshold, the buzzer and LED are activated.
void setup_all() {
    lcd_init();
    if (wiringPiSetup() == -1 || wiringPiSPISetup(SPI_CHANNEL, SPI_SPEED) == -1) {
        return;
Initializes LCD, SPI, GPIO pins for joystick button, buzzer, and LED. Also sets pull-up for the joystick button.
int main(void) {
    setup_all();
    int stage = 0;
    while (1) {
            delay(100);
            lcd_clear();
        if (stage == 1)
        else
            monitoring_temp();
Main loop switches between two modes:
  1. Temperature monitoring.
  2. Upper limit adjustment using the joystick.
The mode switches when the joystick button is released (rising edge trigger).
