3.1.4 Smart Fan
In this project, we will use motors, buttons and thermistors to make a manual + automatic smart fan whose wind speed is adjustable.
../_images/list_Smart_Fan.png
ITEMS IN THIS KIT
COMPONENT INTRODUCTION
PURCHASE LINK
GPIO Extension Board
Jumper Wires
Resistor
Power Supply Module
Thermistor
L293D
ADC0834
Button
DC Motor
Schematic Diagram
T-Board Name
physical
wiringPi
GPIO17
Pin 11
0
17
GPIO18
Pin 12
GPIO27
Pin 13
GPIO22
Pin 15
GPIO5
Pin 29
21
GPIO6
Pin 31
22
GPIO13
Pin 33
23
13
../_images/Schematic_three_one4.png
Experimental Procedures
Step 1: Build the circuit.
../_images/image245.png
The power module can apply a 9V battery with the 9V Battery Buckle in the kit. Insert the jumper cap of the power module into the 5V bus strips of the breadboard.
../_images/image118.jpeg
Step 2: Get into the folder of the code.
cd ~/raphael-kit/c/3.1.4/
Step 3: Compile.
gcc 3.1.4_SmartFan.c -lwiringPi -lm
Step 4: Run the executable file above.
As the code runs, start the fan by pressing the button. Every time you press, 1 speed grade is adjusted up or down. There are 5 kinds of speed grades: 0~4. When set to the 4th speed grade and you press the button, the fan stops working with a 0 wind speed.
Once the temperature goes up or down for more than 2℃, the speed automatically gets 1-grade faster or slower.
#include <wiringPi.h>
#include <stdio.h>
#include <softPwm.h>
#include <math.h>
typedef unsigned char uchar;
typedef unsigned int uint;
#define ADC_CS      0
#define ADC_CLK     1
#define ADC_DIO     2
#define MotorPin1   21
#define MotorPin2   22
#define MotorEnable 23
#define BtnPin      3
    uchar i;
    uchar dat1=0, dat2=0;
    int sel = channel > 1 & 1;
    int odd = channel & 1;
    digitalWrite(ADC_CLK, 1);
    delayMicroseconds(2);
    digitalWrite(ADC_CLK, 0);
    pinMode(ADC_DIO, OUTPUT);
    digitalWrite(ADC_CS, 0);
    // Start bit
    digitalWrite(ADC_CLK,0);
    digitalWrite(ADC_DIO,1);    delayMicroseconds(2);
    digitalWrite(ADC_CLK,1);    delayMicroseconds(2);
    //Single End mode
    // ODD
    digitalWrite(ADC_DIO,odd);  delayMicroseconds(2);
    //Select
    digitalWrite(ADC_DIO,sel);    delayMicroseconds(2);
    for(i=0;i<8;i++)
        digitalWrite(ADC_CLK,0);    delayMicroseconds(2);
        pinMode(ADC_DIO, INPUT);
    for(i=0;i<8;i++)
    digitalWrite(ADC_CS,1);
int temperture(){
    unsigned char analogVal;
    cel = temp - 273.15;
    Fah = cel * 1.8 +32;
    int t=cel;
    return t;
int motor(int level){
    if(level==0){
        digitalWrite(MotorEnable,LOW);
    if (level>=4){
        level =4;
    digitalWrite(MotorEnable,HIGH);
    softPwmWrite(MotorPin1, level*25);
    return level;
void setup(){
        return;
    softPwmCreate(MotorPin1,  0, 100);
    softPwmCreate(MotorPin2,  0, 100);
    pinMode(MotorEnable,OUTPUT);
    pinMode(BtnPin,INPUT);
    pinMode(ADC_CS,  OUTPUT);
    pinMode(ADC_CLK, OUTPUT);
int main(void)
    setup();
    int currentState,lastState=0;
    int level = 0;
    int currentTemp,markTemp=0;
        currentState=digitalRead(BtnPin);
        currentTemp=temperture();
        if (currentTemp<=0){continue;}
        if (currentState==1&&lastState==0){
            level=(level+1)%5;
            markTemp=currentTemp;
            delay(500);
        lastState=currentState;
        if (level!=0){
            if (currentTemp-markTemp<=-2){
                level=level-1;
            if (currentTemp-markTemp>=2){
                level=level+1;
        level=motor(level);
Code Explanation
int temperture(){
    int t=cel;
    return t;
Temperture() works by converting thermistor values read by ADC0834 into temperature values. Refer to 2.2.2 Thermistor for more details.
    if(level==0){
        return 0;
    if (level>=4){
        level =4;
    return level;
This function controls the rotating speed of the motor. The range of the Level: 0-4 (level 0 stops the working motor). One level adjustment stands for a 25% change of the wind speed.
int main(void)
    setup();
    int level = 0;
            level=(level+1)%5;
            delay(500);
        if (level!=0){
                level=level-1;
                level=level+1;
        level=motor(level);
    return 0;
The function main() contains the whole program process as shown:
  1. Constantly read the button state and the current temperature.
  2. Every press makes level+1 and at the same time, the temperature is updated. The Level ranges 1~4.
  3. As the fan works ( the level is not 0), the temperature is under detection. A 2℃+ change causes the up and down of the level.
  4. The motor changes the rotating speed with the Level.
