3.1.5 Battery Indicator(MCP3008)
In this project, we will make a battery indicator device that can visually display the battery level on the LED Bargraph.
Warning
Do not use battery components that exceed 3.3V to avoid overloading, which may damage the chip or Raspberry Pi.
../_images/list2_Battery_Indicator.png
ITEMS IN THIS KIT
COMPONENT INTRODUCTION
PURCHASE LINK
GPIO Extension Board
Jumper Wires
Resistor
LED Bar Graph
MCP3008
Schematic Diagram
T-Board Name
physical
wiringPi
SPICE0
Pin 24
10
8
SPIMOSI
Pin 19
12
10
SPIMISO
Pin 21
13
9
SPISCLK
Pin 23
14
11
GPIO25
Pin 22
GPIO12
Pin 32
26
12
GPIO16
Pin 36
27
16
GPIO20
Pin 38
28
20
GPIO21
Pin 40
29
21
GPIO5
Pin 29
21
GPIO6
Pin 31
22
GPIO13
Pin 33
23
13
GPIO19
Pin 35
24
19
GPIO26
Pin 37
25
26
../_images/schematic_battery_indicator_mcp3008.png
Experimental Procedures
Step 1: Build the circuit.
../_images/july24_3.1.5_battery_indicator_mcp3008.png
cd ~/raphael-kit/c/3.1.5-2/
Step 3: Compile the code.
gcc 3.1.5_BatteryIndicator.c -lwiringPi
After the program runs, give the 3rd pin of MCP3008 and the GND a lead-out wire separately and then lead them to the two poles of a battery separately. You can see the corresponding LED on the LED Bargraph is lit up to display the power level (measuring range: 0-5V).
#include <wiringPi.h>
#include <wiringPiSPI.h>
#include <stdio.h>
#define SPI_CHANNEL 0
#define SPI_SPEED   1000000  // 1MHz
#define VREF        3.3
int pins[10] = {6, 26, 27, 28, 29, 21, 22, 23, 24, 25};
int read_ADC(int channel)
    unsigned char buffer[3];
    buffer[0] = 1;  // Start bit
    buffer[1] = (8 + channel) << 4;  // Single-ended mode
    buffer[2] = 0;
    int value = ((buffer[1] & 3) << 8) | buffer[2];
    return value;
void LedBarGraph(int value) {
    for (int i = 0; i < 10; i++) {
        if (i < value)
        digitalWrite(pins[i], HIGH);
    else
        digitalWrite(pins[i],LOW);
int main(void)
    if (wiringPiSetup() == -1) {
        printf("setup wiringPi failed!\n");
        printf("SPI setup failed!\n");
        pinMode(pins[i], OUTPUT);
    while (1) {
        int analogVal = read_ADC(0);  // MCP3008 CH0
        if (analogVal < 0) continue;
        float voltage = analogVal * VREF / 1023.0;
        int level = analogVal * 10 / 1024;
        if (level > 10) level = 10;
        LedBarGraph(level);
        printf("ADC Value: %d\tVoltage: %.2f V\tLevel: %d\n", analogVal, voltage, level);
        delay(200);
Code Explanation
    buffer[1] = (8 + channel) << 4;  // Single-ended mode, CH0~CH7
    buffer[2] = 0;
    int value = ((buffer[1] & 3) << 8) | buffer[2];  // Combine 10-bit result
    return value;
This function reads analog values from the MCP3008 ADC chip using SPI. The channel parameter selects one of the 8 analog inputs (CH0–CH7). The MCP3008 returns a 10-bit digital value between 0 and 1023 representing the analog voltage.
        if (i < value)
            digitalWrite(pins[i], HIGH);  // Turn on LED (assumes active HIGH wiring)
        else
            digitalWrite(pins[i], LOW);   // Turn off LED
This function controls a 10-LED bar graph display. Each LED represents 1/10th of the voltage range. LEDs are turned on in order up to the specified level.
Note: This version assumes LED anodes are connected to GPIOs and cathodes to GND (i.e. active HIGH).
int main(void)
        digitalWrite(pins[i], HIGH);  // Initialize all LEDs to ON
    while (1) {
        int analogVal = read_ADC(0);  // Read voltage on CH0
        int level = analogVal * 10 / 1024;  // Map to 0–10 levels
        LedBarGraph(level);  // Display level on LEDs
        delay(200);  // Update rate: 5 Hz
Main program logic:
  • Initializes wiringPi and SPI communication.
  • Sets GPIO pins as outputs for controlling the 10-LED bar.
  • Continuously reads analog voltage via MCP3008 (CH0).
  • Converts the reading to a voltage using VREF = 3.3V.
  • Scales voltage to a 0–10 level bar graph and lights up LEDs.
  • Displays the raw ADC value, voltage (in volts), and LED level via serial console.
This acts as a visual battery level indicator or analog voltmeter.
