3.1.4 Smart Fan(MCP3008)
In this project, we will use motors, buttons and thermistors to make a manual + automatic smart fan whose wind speed is adjustable.
../_images/list2_Smart_Fan.png
ITEMS IN THIS KIT
COMPONENT INTRODUCTION
PURCHASE LINK
GPIO Extension Board
Jumper Wires
Resistor
Power Supply Module
Thermistor
L293D
MCP3008
Button
DC Motor
Schematic Diagram
T-Board Name
physical
wiringPi
SPICE0
Pin 24
10
8
SPIMOSI
Pin 19
12
10
SPIMISO
Pin 21
13
9
SPISCLK
Pin 23
14
11
GPIO22
Pin 15
GPIO5
Pin 29
21
GPIO6
Pin 31
22
GPIO13
Pin 33
23
13
../_images/schematic_3.1.4_smart_fan_mcp3008.png
Experimental Procedures
Step 1: Build the circuit.
../_images/july24_3.1.4_smart_fan_mcp3008.png
The power module can apply a 9V battery with the 9V Battery Buckle in the kit. Insert the jumper cap of the power module into the 5V bus strips of the breadboard.
../_images/image118.jpeg
Step 2: Get into the folder of the code.
cd ~/raphael-kit/c/3.1.4-2/
Step 3: Compile.
gcc 3.1.4_SmartFan.c -o SmartFan -lwiringPi -lm
Step 4: Run the executable file above.
./SmartFan
As the code runs, start the fan by pressing the button. Every time you press, 1 speed grade is adjusted up or down. There are 5 kinds of speed grades: 0~4. When set to the 4th speed grade and you press the button, the fan stops working with a 0 wind speed.
Once the temperature goes up or down for more than 2℃, the speed automatically gets 1-grade faster or slower.
#include <wiringPi.h>
#include <wiringPiSPI.h>
#include <stdio.h>
#include <softPwm.h>
#include <math.h>
#define SPI_CHANNEL 0
#define SPI_SPEED   1000000
#define MotorPin1   21
#define MotorPin2   22
#define MotorEnable 23
#define BtnPin      3
int read_ADC(int channel)
    unsigned char buffer[3];
    buffer[0] = 1;                      // Start bit
    buffer[1] = (8 + channel) << 4;     // Single-ended mode and channel
    buffer[2] = 0;
    int result = ((buffer[1] & 3) << 8) | buffer[2];
    return result;
int temperture()
    int analogVal = read_ADC(0);
    double Vr = 3.3 * analogVal / 1023.0;  // Use 3.3V as Vref for MCP3008
    double Rt = 10000.0 * Vr / (3.3 - Vr);
    double temp = 1 / (((log(Rt / 10000.0)) / 3950.0) + (1 / (273.15 + 25.0)));
    double cel = temp - 273.15;
    double Fah = cel * 1.8 + 32;
    printf("Celsius: %.2f C  Fahrenheit: %.2f F\n", cel, Fah);
    return (int)cel;
int motor(int level)
    if (level == 0) {
        digitalWrite(MotorEnable, LOW);
    if (level >= 4) {
        level = 4;
    digitalWrite(MotorEnable, HIGH);
    softPwmWrite(MotorPin1, level * 25);
    return level;
void setup()
    if (wiringPiSetup() == -1) {
        printf("wiringPi setup failed!\n");
        return;
        printf("SPI setup failed!\n");
        return;
    softPwmCreate(MotorPin1, 0, 100);
    softPwmCreate(MotorPin2, 0, 100);
    pinMode(MotorEnable, OUTPUT);
    pinMode(BtnPin, INPUT);
int main(void)
    setup();
    int currentState, lastState = 0;
    int level = 0;
    int currentTemp, markTemp = 0;
    while (1) {
        currentState = digitalRead(BtnPin);
        currentTemp = temperture();
        if (currentTemp <= 0) continue;
        if (currentState == 1 && lastState == 0) {
            level = (level + 1) % 5;
            markTemp = currentTemp;
            delay(500);
        lastState = currentState;
        if (level != 0) {
            if (currentTemp - markTemp <= -2) {
                level = level - 1;
            if (currentTemp - markTemp >= 2) {
                level = level + 1;
        level = motor(level);
Code Explanation
    buffer[2] = 0;
    return result;
This function is used to read analog input from MCP3008 on the specified channel. It sends a 3-byte SPI command and returns a 10-bit digital value between 0–1023.
int temperture()
    return (int)cel;
The temperture() function reads the thermistor analog signal via MCP3008, calculates voltage, resistance, then converts to Celsius and Fahrenheit using the thermistor formula (Steinhart–Hart approximation).
    if (level == 0) {
    if (level >= 4) {
        level = 4;
    return level;
This motor() function controls fan speed via PWM. Level ranges from 0–4, where 0 turns the fan off and each level increases the duty cycle by 25%.
void setup()
        return;
        return;
The setup() function initializes WiringPi, sets up SPI, configures PWM and GPIO pins needed for motor control and button input.
int main(void)
    setup();
    int level = 0;
    while (1) {
            delay(500);
        if (level != 0) {
                level = level - 1;
                level = level + 1;
The main() function contains the program loop:
  1. Constantly checks button state and reads current temperature.
  2. On button press, fan level increases (cycles 0–4) and saves temperature.
  3. If temperature changes by ±2°C, it auto-adjusts fan speed accordingly.
  4. Calls motor(level) to update PWM output based on current level.
