Lesson 8 4N35¶
Introduction¶
The 4N35 is an optocoupler for general purpose application. It consists of gallium arsenide infrared LED and a silicon NPN phototransistor. When the input signal is applied to the LED in the input terminal, the LED lights up. After receiving the light signal, the light receiver then converts it into electrical signal and outputs the signal directly or after amplifying it into a standard digital level. Thus, the transition and transmission of electricity-light-electricity is completed. Since light is the media of the transmission, meaning the input terminal and the output one are isolated electrically, this process is also be known as electrical isolation.
Components¶
- 1 * Raspberry Pi
- 1 * 4N35
- 1 * LED
- 1 * 220 Ohm Resistor
- 1* 1k Ohm Resistor
- Some jump wires
- 1 * T-Extension Board
- 1 * 40-Pin GPIO Cable
Principle¶
4N35
What an optocoupler does is to break the connection between signal source and signal receiver, so as to stop electrical interference. In other words, it is used to prevent interference from external electrical signals. 4N35 can be used in AV conversion audio circuits. Broadly it is widely used in electrical insulation for a general optocoupler.
See the internal structure of 4N35 above. Pin 1 and 2 are connected to an infrared LED. When the LED is electrified, it’ll emit infrared rays. To protect the LED from burning, usually a resistor (about 1K) is connected to pin 1. Then the NPN phototransistor is power on when receiving the rays. This can be done to control the load connected to the phototransistor. Even when the load short circuit occurs, it won’t affect the control board, thus realizing good electrical isolation.
The Schematic Diagram:¶
Principle: In this experiment, use an LED as the load connected to the NPN phototransistor. Connect pin 2 of 4N35 to pin B17, pin 1 connects a 1K current-limiting resistor and then a 3.3V. Connect pin 4 to GND, and pin 5 to the cathode of the LED. Then hook the anode of the LED to 3.3V after connecting with a 220 Ohm resistor. When in program, a LOW level is given to pin B17, the infrared LED will emit infrared rays. Then the phototransistor receives infrared rays and gets electrified, and the LED cathode is LOW, thus turning on the LED. Also you can control the LED by circuits only – connect pin 2 to ground and it will brighten.
Step 1: Build the circuit.
For C Language Users:¶
Step 2: Open the code file.
cd /home/pi/SunFounder_Super_Kit_V3.0_for_Raspberry_Pi/C
Step 3: Compile the Code.
make 08_4N35
Step 4: Run the executable file above.
sudo ./08_4N35
If it does not work after running, or there is an error prompt: “wiringPi.h: No such file or directory”, please refer to C code is not working?.
#include <wiringPi.h>
#include <stdio.h>
#define _4N35Pin 0
int main(void)
// When initialize wiring failed, print messageto screen
if(wiringPiSetup() == -1){
pinMode(_4N35Pin, OUTPUT);
printf("\n");
printf("\n");
printf("========================================\n");
printf("| 4N35 |\n");
printf("| ------------------------------ |\n");
printf("| LED connect to 4N35 pin5; |\n");
printf("| gpio0 connect to 4N35 pin2; |\n");
printf("| |\n");
printf("| 4N35 to contral led blinking. |\n");
printf("| |\n");
printf("| SunFounder|\n");
printf("========================================");
printf("\n");
printf("\n");
// LED on
digitalWrite(_4N35Pin, LOW);
printf("...LED on\n");
delay(500);
// LED off
digitalWrite(_4N35Pin, HIGH);
printf("LED off...\n");
delay(500);
Code Explanation
digitalWrite(_4N35Pin, LOW); /* set the I/O port as low level (0V), thus
the optocoupler is energized, and the pin connected to LED conducts to
the 0V. Then the LED lights up.*/
delay(500);
// optocoupler is a kind of electronic device and there is no limitation on its on-off frequency.
digitalWrite(_4N35Pin, HIGH); /* set I/O port as high level (3.3V), thus
the optocoupler is not energized ,and the pin connected to LED cannot
conduct to the 0V. Then the LED goes out.*/
For Python Users:¶
cd /home/pi/SunFounder_Super_Kit_V3.0_for_Raspberry_Pi/Python
Step 3: Run.
sudo python3 08_4N35.py
import RPi.GPIO as GPIO
from sys import version_info
if version_info.major == 3:
raw_input = input
# Set #17 as 4N35 pin
Pin_4N35 = 17
# Define a function to print message at the beginning
def print_message():
print ("========================================")
print ("| 4N35 |")
print ("| ------------------------------ |")
print ("| LED connect to 4N35 pin5; |")
print ("| gpio17 connect to 4N35 pin2; |")
print ("| |")
print ("| 4N35 to contral led blinking. |")
print ("| |")
print ("| SunFounder|")
print ("======================================\n")
print ("Program is running...")
print ("Please press Ctrl+C to end the program..")
#raw_input ("Press Enter to begin\n")
# Define a setup function for some setup
def setup():
GPIO.setmode(GPIO.BCM)
# Set Pin_4N35's mode to output,
# and initial level to High(3.3v)
GPIO.setup(Pin_4N35, GPIO.OUT, initial=GPIO.HIGH)
# Define a main function for main process
def main():
# Print messages
print_message()
print ("...LED ON")
# Turn on LED
GPIO.output(Pin_4N35, GPIO.LOW)
time.sleep(0.5)
print ("LED OFF...")
# Turn off LED
GPIO.output(Pin_4N35, GPIO.HIGH)
time.sleep(0.5)
# Define a destroy function for clean up everything after
# the script finished
def destroy():
# Turn off LED
# Release resource
GPIO.cleanup()
if __name__ == '__main__':
setup()
main()
# When 'Ctrl+C' is pressed, the child program
# destroy() will be executed.
destroy()
Code Explanation
GPIO.output(Pin_4N35, GPIO.LOW) # set the pins of optocoupler as low
#level, thus the optocoupler is energized, and the pin connected to LED
#conducts to the 0V.Then the LED lights up.
time.sleep(0.5) #wait for 0.5 second. The on-off frequency of the
#optocoupler can be changed by modifying this parameter.
GPIO.output(Pin_4N35, GPIO.HIGH) # set the pins of optocoupler as high
#level, thus the optocoupler is disconnected, and the pin connected to
#LED break the connection to the 0V. Then the LED goes out.
time.sleep(0.5)
You will see the LED blinks.
