Lesson 11 How to Drive a DC Motor¶
Introduction¶
In this lesson, we will learn to how to use L293D to drive a DC motor and make it rotate clockwise and counterclockwise. Since the DC Motor needs a larger current, for safety purpose, here we use the Power Supply Module to supply motors.
Components¶
- 1 * Raspberry Pi
- 1 * Breadboard
- 1 * L293D
- 1 * DC motor
- 1 * Power Module
- Jumper wires
- 1 * T-Extension Board
- 1 * 40-Pin GPIO Cable
Principle¶
L293D
L293D is a 4-channel motor driver integrated by chip with high voltage and high current. It’s designed to connect to standard DTL, TTL logic level, and drive inductive loads (such as relay coils, DC, stepping motors) and power switching transistors etc. DC Motors are devices that turn DC electrical energy into mechanical energy. They are widely used in electrical drive for their superior speed regulation performance.
See the figure of pins below. L293D has two pins (Vcc1 and Vcc2) for power supply. Vcc2 is used to supply power for the motor, while Vcc1 to supply for the chip. Since a small-sized DC motor is used here, connect both pins to +5V.
The following is the internal structure of L293D. Pin EN is an enable pin and only works with high level; A stands for input and Y for output. You can see the relationship among them at the right bottom. When pin EN is High level, if A is High, Y outputs high level; if A is Low, Y outputs Low level. When pin EN is Low level, the L293D does not work.
In this experiment, it just needs to drive one motor, so here only half of the L293D will be used.
DC Motor
This is a 5V DC motor. It will rotate when you give the two terminals of the copper sheet one high and one low level. For convenience, you can weld the pins to it.
Operation Voltage: 1-6V
Free-run current (3V): 70m
A Free-run speed (3V): 13000RPM
Stall current (3V): 800mA
Shaft diameter: 2mm
Power Supply Module
In this experiment, it needs large currents to drive the motor especially when it starts and stops, which will severely interfere with the normal work of Raspberry Pi. Therefore, we separately supply power for the motor by this module to make it run safely and steadily.
You can just plug it in the breadboard to supply power. It provides a voltage of 3.3V and 5V, and you can connect either via a jumper cap included.
Schematic Diagram:
Principle: Plug the power supply module in breadboard, and insert the jumper cap to pin of 5V, then it will output voltage of 5V. Connect pin 1 of L293D to B27, and set it as high level. Connect pin2 to B18, and pin7 to B27, then set one pin high, while the other low. Thus you can change the motor’s rotation direction.
Experimental Procedures
Step 1: Build the circuit. Since the power supply module and T-cable are incompatible, we will not use the T-Cable in this experiment.
Note: The power module can apply a 9V battery with the 9V Battery Buckle in the kit. Insert the jumper cap of the power module into the 5V bus strips of the breadboard.
For C Language Users:¶
Step 2: Get into the folder of the code.
cd /home/pi/SunFounder_Super_Kit_V3.0_for_Raspberry_Pi/C
Step 3: Compile.
make 11_motor
Step 4: Run the executable file above.
sudo ./11_motor
If it does not work after running, or there is an error prompt: “wiringPi.h: No such file or directory”, please refer to C code is not working?.
#include <wiringPi.h>
#include <stdio.h>
#define MotorPin1 0
#define MotorPin2 1
#define MotorEnable 2
int main(void){
int i;
if(wiringPiSetup() == -1){ //when initialize wiring failed, print messageto screen
pinMode(MotorPin1, OUTPUT);
pinMode(MotorPin2, OUTPUT);
pinMode(MotorEnable, OUTPUT);
printf("\n");
printf("\n");
printf("========================================\n");
printf("| Motor |\n");
printf("| ------------------------------ |\n");
printf("| Motor pin 1 connect to GPIO0 |\n");
printf("| Motor pin 2 connect to GPIO1 |\n");
printf("| Motor enable connect to GPIO3 |\n");
printf("| |\n");
printf("| Controlling a motor |\n");
printf("| |\n");
printf("| SunFounder|\n");
printf("\n");
printf("\n");
printf("Clockwise\n");
digitalWrite(MotorEnable, HIGH);
digitalWrite(MotorPin1, HIGH);
digitalWrite(MotorPin2, LOW);
for(i=0;i<3;i++){
delay(1000);
printf("Stop\n");
digitalWrite(MotorEnable, LOW);
for(i=0;i<3;i++){
delay(1000);
printf("Anti-clockwise\n");
digitalWrite(MotorPin1, LOW);
digitalWrite(MotorPin2, HIGH);
for(i=0;i<3;i++){
delay(1000);
printf("Stop\n");
for(i=0;i<3;i++){
delay(1000);
Code Explanation
digitalWrite(MotorEnable, HIGH) // Enable the L239D
// Set a high level for 2A(pin 7); since 1,2EN(pin 1) is in high level, 2Y will output high level
digitalWrite(MotorPin2, LOW) /* Set a low level for 1A, then 1Y
will output low level, and the motor will rotate.*/
for(i=0;i<3;i++)
delay(1000);
} // this loop is to delay for 3*1000ms
// If 1,2EN (pin1) is in low level, L293D does not work. Motor stops rotating.
// Reverse the current flow of the motor, then the motor will rotate reversely.
For Python Users:¶
cd /home/pi/SunFounder_Super_Kit_V3.0_for_Raspberry_Pi/Python
Step 3: Run.
sudo python3 11_motor.py
import RPi.GPIO as GPIO
from sys import version_info
if version_info.major == 3:
raw_input = input
# Set up pins
MotorPin1 = 17
MotorPin2 = 18
MotorEnable = 27
def print_message():
print ("========================================")
print ("| Motor |")
print ("| ------------------------------ |")
print ("| Motor pin 1 connect to GPIO17 |")
print ("| Motor pin 2 connect to GPIO18 |")
print ("| Motor enable connect to GPIO27 |")
print ("| |")
print ("| Controlling a motor |")
print ("| |")
print ("| SunFounder|")
print ("======================================\n")
print ("Program is running...")
print ("Please press Ctrl+C to end the program...")
#raw_input ("Press Enter to begin\n")
def setup():
GPIO.setmode(GPIO.BCM)
# Set pins to output
GPIO.setup(MotorPin1, GPIO.OUT)
GPIO.setup(MotorPin2, GPIO.OUT)
GPIO.setup(MotorEnable, GPIO.OUT, initial=GPIO.LOW)
# Define a motor function to spin the motor
# direction should be
# 1(clockwise), 0(stop), -1(counterclockwise)
def motor(direction):
# Clockwise
if direction == 1:
# Set direction
GPIO.output(MotorPin1, GPIO.HIGH)
GPIO.output(MotorPin2, GPIO.LOW)
# Enable the motor
GPIO.output(MotorEnable, GPIO.HIGH)
print ("Clockwise")
# Counterclockwise
if direction == -1:
# Set direction
GPIO.output(MotorPin1, GPIO.LOW)
GPIO.output(MotorPin2, GPIO.HIGH)
# Enable the motor
print ("Counterclockwise")
# Stop
if direction == 0:
# Disable the motor
GPIO.output(MotorEnable, GPIO.LOW)
print ("Stop")
def main():
print_message()
# Define a dictionary to make the script more readable
# CW as clockwise, CCW as counterclockwise, STOP as stop
directions = {'CW': 1, 'CCW': -1, 'STOP': 0}
# Clockwise
motor(directions['CW'])
time.sleep(5)
# Stop
motor(directions['STOP'])
time.sleep(5)
# Anticlockwise
motor(directions['CCW'])
time.sleep(5)
# Stop
time.sleep(5)
def destroy():
# Stop the motor
# Release resource
GPIO.cleanup()
if __name__ == '__main__':
setup()
main()
# When 'Ctrl+C' is pressed, the child program
# destroy() will be executed.
destroy()
Code Explanation
# Set pin1 and pin2 for motor’s rotation direction as output pin
GPIO.setup(MotorEnable, GPIO.OUT)
# Set pins for motor’s working condition as output pin
# Set the motor low level for initial state
GPIO.output(MotorEnable, GPIO.HIGH) # Set the motor in high level
# Set pin1 in high level and pin2 in low level
GPIO.output(MotorPin2, GPIO.LOW) # Make the motor rotate clockwise
time.sleep(5) # rotate for 5 seconds
GPIO.output(MotorEnable, GPIO.LOW) # Stop the motor
time.sleep(5) #wait for 5 seconds
#Code for motor counter-clockwise rotation is similar to sketch above
Now, you should see the motor blade rotating.
Further Exploration
You can use buttons to control the clockwise and counterclockwise rotation of the motor blade based on the previous lessons. Also you can apply the PWM technology to control the rotation.
