Components List¶
After unpacking, please check that the number of components is correct and that all components are in good condition.
No. |
Quantity |
Component |
555 Timer IC |
Optocoupler (4N35) |
Shift Register (74HC595) |
L293D |
Accelerometer ADXL345 |
Rotary Encoder |
7 |
Potentiometer |
8 |
Resistor (220Ω) |
8 |
9 |
Resistor (1kΩ) |
8 |
10 |
Resistor (10kΩ) |
11 |
Resistor |
12 |
Resistor (1MΩ) |
13 |
Resistor |
14 |
Diode Rectifier |
15 |
Switch |
16 |
Button |
17 |
Power Supply |
18 |
LCD1602 |
19 |
Dot Matrix |
20 |
7-Segment |
21 |
DC Motor |
22 |
RGB LED |
23 |
LED (red) |
8 |
24 |
LED (white) |
25 |
LED (green) |
26 |
LED (yellow) |
27 |
NPN Transistor (S8050) |
28 |
PNP Transistor (S8550) |
29 |
Capacitor Ceramic 100nF |
30 |
Capacitor Ceramic 10nF |
31 |
Breadboard |
32 |
Active Buzzer |
33 |
Relay |
34 |
Fan |
35 |
Male-to-Male Jumper Wire |
65 |
36 |
Female-to-Male Dupont Wire |
20 |
37 |
5-Pin Anti-reverse Cable |
38 |
9V Battery Buckle |
39 |
M3*10 Screw |
40 |
M2.5*6 Screw |
41 |
M3*6 Screw |
42 |
RAB Holder |
43 |
T-Extension |
44 |
40-Pin GPIO |
