Lesson 16 LCD1602¶
Components¶
- 1 * Raspberry Pi
- 1 * Breadboard
- 1 * LCD1602
- 1 * Potentiometer
- 1 * T-Extension Board
- 1 * 40-Pin GPIO Cable
- Jumper wires
Principle¶
LCD1602
Generally, LCD1602 has parallel ports, that is, it would control several pins at the same time. LCD1602 can be categorized into eight-port and four-port connections. If the eight-port connection is used, then all the digital ports of the SunFounder Uno board are almost completely occupied. If you want to connect more sensors, there will be no ports available. Therefore, the four-port connection is used here for better application.
LCD1602 uses the standard 16-pin port, among which:
Pin 1 (GND): connected to Ground
Pin 2 (Vcc): connected to 5V power supply
Pin 3 (Vo): used to adjust the contrast of LCD1602; the level is lowest when it’s connected to a positive power supply, and highest when connected to ground (you can connect a 10K potentiometer to adjust its contrast when using LCD1602)
Pin 4 (RS): register select pin, controlling where in the LCD’s memory you are writing data to. You can select either the data register, which holds what goes on the screen, or an instruction register, where the LCD’s controller looks for instructions on what to do next.
Pin 5 (R/W): to read/write signals; it reads signals when supplied with high level (1), and writes when low level (0) (in this experiment, you only need to write data to LCD1602, so just connect this pin to ground)
Pin 6 (E): An enable pin that, when low-level energy is supplied, causes the LCD module to execute relevant instructions
Pin 7 (D0-D7): pins that read and write data
A and K: controlling LCD backlight; K connects to GND, and A to 3.3V. Turn the backlight on and you can see the characters displayed clear in a dim environment
LCD1602 has two operation modes: 4-bit and 8-bit. When the IOs of the MCU are insufficient, you can choose the 4-bit mode, under which only pins D4~D7 are used. After connecting the circuit, you can operate LCD1602 by the Raspberry Pi.
Experimental Procedures¶
Step 1: Build the circuit (please be sure the pins are connected correctly. Otherwise, characters will not be displayed properly):
LCD1602 |
T-Extension Board |
VDD |
5V |
VSS |
GND |
OV |
Connect to the middle pin of potentiometer |
RS |
B27 |
R/W |
GND |
E |
B22 |
D0-D3 |
Not connected |
D4 |
B25 |
D5 |
B24 |
D6 |
B23 |
D7 |
B18 |
A |
3.3V |
K |
GND |
After you run the code, characters may not appear on the LCD1602. You need to adjust the contrast of the screen (the gradual change from black to white) by spinning the potentiometer clockwise or anticlockwise, until the screen displays characters clearly.
For C Language Users:¶
Step 2: Get into the folder of code.
cd /home/pi/SunFounder_Super_Kit_V3.0_for_Raspberry_Pi/C
Step 3: Compile.
make 16_lcd1602
Step 4: Run.
sudo ./16_lcd1602
If it does not work after running, or there is an error prompt: “wiringPi.h: No such file or directory”, please refer to C code is not working?.
#include <stdio.h>
#include <stdlib.h>
#include <wiringPi.h>
#include <lcd.h>
const unsigned char Buf[] = "---SUNFOUNDER---";
const unsigned char myBuf[] = " sunfounder.com";
int main(void)
int fd;
int i;
if(wiringPiSetup() == -1){
exit(1);
fd = lcdInit(2,16,4, 2,3, 6,5,4,1,0,0,0,0); //see /usr/local/include/lcd.h
printf("%d", fd);
if (fd == -1){
printf("lcdInit 1 failed\n") ;
sleep(1);
lcdClear(fd);
lcdPosition(fd, 0, 0);
lcdPuts(fd, "Welcome To--->");
lcdPosition(fd, 0, 1);
lcdPuts(fd, " sunfounder.com");
sleep(1);
lcdClear(fd);
printf("\n");
printf("\n");
printf("========================================\n");
printf("| LCD1602 |\n");
printf("| ------------------------------ |\n");
printf("| D4 connect to GPIO6 |\n");
printf("| D5 connect to GPIO5 |\n");
printf("| D6 connect to GPIO4 |\n");
printf("| D7 connect to GPIO1 |\n");
printf("| RS connect to GPIO2 |\n");
printf("| RW connect to GND |\n");
printf("| CE connect to GPIO3 |\n");
printf("| |\n");
printf("| Control LCD1602 |\n");
printf("| |\n");
printf("| SunFounder|\n");
printf("\n");
printf("\n");
lcdClear(fd);
for(i=0; i<16; i++){
lcdPosition(fd, i, 0);
lcdPutchar(fd, *(myBuf+i));
delay(100);
for(i=0;i<sizeof(Buf)-1;i++){
lcdPosition(fd, i, 1);
lcdPutchar(fd, *(Buf+i));
delay(200);
sleep(0.5);
Code Explanation
#include <lcd.h>
// includes the lcd library, containing some functions for the LCD1602 display for convenient use
// An array to store the characters to be displayed on the LCD1602
// Another array to store the characters
// Initialize the LCD display, see /usr/local/include/lcd.h
/* lcdInit(rows, cols, bits, rs, strb, d0, d1, d2, d3, d4, d5, d6, d7) -
LCD1602 shows 2 rows and 16 columns. If the initialization succeeds, it
will return True. */
lcdClear(fd); // Clear the screen
// Locate the position of the cursor at Row 0 and Col 0 (in fact it's the first line and first column)
lcdPuts(fd, "Welcom To--->");
// Display the character "Welcom To--->"on the LCD1602
lcdPosition(fd, 0, 1); // Place the cursor at Col 0, Row 0.
while(1)
lcdClear(fd);
for(i=0; i<16; i++)
{ // i adds one in the loop. i means the number of columns, so i adds to 16 at most.
// Place the cursor at the first row, and moves left to right from the first character
// *(myBuf+i) is a pointer that points to contents in the myBuf[] array, and output the pointed data to lcd
delay(100);
lcdPosition(fd, i, 1); // Place the cursor at the second row, moves from the first character
lcdPutchar(fd, *(Buf+i)); // A pointer that points to data in the Buf[] array; output it to lcd
delay(200);
sleep(0.5);
For Python Users:¶
cd /home/pi/SunFounder_Super_Kit_V3.0_for_Raspberry_Pi/Python
Step 3: Run.
sudo python3 16_lcd1602.py
import RPi.GPIO as GPIO
from sys import version_info
from time import sleep
if version_info.major == 3:
raw_input = input
class LCD:
# commands
LCD_CLEARDISPLAY = 0x01
LCD_RETURNHOME = 0x02
LCD_ENTRYMODESET = 0x04
LCD_DISPLAYCONTROL = 0x08
LCD_CURSORSHIFT = 0x10
LCD_FUNCTIONSET = 0x20
LCD_SETCGRAMADDR = 0x40
LCD_SETDDRAMADDR = 0x80
# flags for display entry mode
LCD_ENTRYRIGHT = 0x00
LCD_ENTRYLEFT = 0x02
LCD_ENTRYSHIFTINCREMENT = 0x01
LCD_ENTRYSHIFTDECREMENT = 0x00
# flags for display on/off control
LCD_DISPLAYON = 0x04
LCD_DISPLAYOFF = 0x00
LCD_CURSORON = 0x02
LCD_CURSOROFF = 0x00
LCD_BLINKON = 0x01
LCD_BLINKOFF = 0x00
# flags for display/cursor shift
LCD_DISPLAYMOVE = 0x08
LCD_CURSORMOVE = 0x00
LCD_MOVERIGHT = 0x04
LCD_MOVELEFT = 0x00
# flags for function set
LCD_8BITMODE = 0x10
LCD_4BITMODE = 0x00
LCD_2LINE = 0x08
LCD_1LINE = 0x00
LCD_5x10DOTS = 0x04
LCD_5x8DOTS = 0x00
def __init__(self, pin_rs=27, pin_e=22, pins_db=[25, 24, 23, 18], GPIO = None):
# Emulate the old behavior of using RPi.GPIO if we haven't been given
# an explicit GPIO interface to use
if not GPIO:
self.GPIO = GPIO
self.pin_rs = pin_rs
self.pin_e = pin_e
self.pins_db = pins_db
self.used_gpio = self.pins_db[:]
self.used_gpio.append(pin_e)
self.used_gpio.append(pin_rs)
self.GPIO.setwarnings(False)
self.GPIO.setmode(GPIO.BCM)
self.GPIO.setup(self.pin_e, GPIO.OUT)
self.GPIO.setup(self.pin_rs, GPIO.OUT)
for pin in self.pins_db:
self.GPIO.setup(pin, GPIO.OUT)
self.write4bits(0x33) # initialization
self.write4bits(0x32) # initialization
self.write4bits(0x28) # 2 line 5x7 matrix
self.write4bits(0x0C) # turn cursor off 0x0E to enable cursor
self.write4bits(0x06) # shift cursor right
self.displaycontrol = self.LCD_DISPLAYON | self.LCD_CURSOROFF | self.LCD_BLINKOFF
self.displayfunction = self.LCD_4BITMODE | self.LCD_1LINE | self.LCD_5x8DOTS
self.displayfunction |= self.LCD_2LINE
""" Initialize to default text direction (for romance languages) """
self.displaymode = self.LCD_ENTRYLEFT | self.LCD_ENTRYSHIFTDECREMENT
self.write4bits(self.LCD_ENTRYMODESET | self.displaymode) # set the entry mode
self.clear()
def begin(self, cols, lines):
if (lines > 1):
self.numlines = lines
self.currline = 0
def home(self):
self.write4bits(self.LCD_RETURNHOME) # set cursor position to zero
self.delayMicroseconds(3000) # this command takes a long time!
def clear(self):
self.write4bits(self.LCD_CLEARDISPLAY) # command to clear display
self.delayMicroseconds(3000) # 3000 microsecond sleep, clearing the display takes a long time
def setCursor(self, col, row):
self.row_offsets = [ 0x00, 0x40, 0x14, 0x54 ]
if ( row > self.numlines ):
row = self.numlines - 1 # we count rows starting w/0
self.write4bits(self.LCD_SETDDRAMADDR | (col + self.row_offsets[row]))
def noDisplay(self):
# Turn the display off (quickly)
self.displaycontrol &= ~self.LCD_DISPLAYON
self.write4bits(self.LCD_DISPLAYCONTROL | self.displaycontrol)
def display(self):
# Turn the display on (quickly)
self.displaycontrol |= self.LCD_DISPLAYON
def noCursor(self):
# Turns the underline cursor on/off
self.displaycontrol &= ~self.LCD_CURSORON
def cursor(self):
# Cursor On
self.displaycontrol |= self.LCD_CURSORON
def noBlink(self):
# Turn on and off the blinking cursor
self.displaycontrol &= ~self.LCD_BLINKON
def noBlink(self):
def DisplayLeft(self):
# These commands scroll the display without changing the RAM
self.write4bits(self.LCD_CURSORSHIFT | self.LCD_DISPLAYMOVE | self.LCD_MOVELEFT)
def scrollDisplayRight(self):
self.write4bits(self.LCD_CURSORSHIFT | self.LCD_DISPLAYMOVE | self.LCD_MOVERIGHT);
def leftToRight(self):
# This is for text that flows Left to Right
self.displaymode |= self.LCD_ENTRYLEFT
self.write4bits(self.LCD_ENTRYMODESET | self.displaymode);
def rightToLeft(self):
# This is for text that flows Right to Left
self.displaymode &= ~self.LCD_ENTRYLEFT
def autoscroll(self):
# This will 'right justify' text from the cursor
self.displaymode |= self.LCD_ENTRYSHIFTINCREMENT
def noAutoscroll(self):
# This will 'left justify' text from the cursor
self.displaymode &= ~self.LCD_ENTRYSHIFTINCREMENT
def write4bits(self, bits, char_mode=False):
# Send command to LCD
self.delayMicroseconds(1000) # 1000 microsecond sleep
bits=bin(bits)[2:].zfill(8)
self.GPIO.output(self.pin_rs, char_mode)
self.GPIO.output(pin, False)
for i in range(4):
if bits[i] == "1":
self.GPIO.output(self.pins_db[::-1][i], True)
self.pulseEnable()
for i in range(4,8):
if bits[i] == "1":
self.GPIO.output(self.pins_db[::-1][i-4], True)
self.pulseEnable()
def delayMicroseconds(self, microseconds):
seconds = microseconds / float(1000000) # divide microseconds by 1 million for seconds
sleep(seconds)
def pulseEnable(self):
self.GPIO.output(self.pin_e, False)
self.delayMicroseconds(1) # 1 microsecond pause - enable pulse must be > 450ns
self.GPIO.output(self.pin_e, True)
self.delayMicroseconds(1) # commands need > 37us to settle
def message(self, text):
# Send string to LCD. Newline wraps to second line
print ("message: %s"%text)
for char in text:
if char == '\n':
self.write4bits(0xC0) # next line
self.write4bits(ord(char),True)
def destroy(self):
print ("clean up used_gpio")
self.GPIO.cleanup(self.used_gpio)
def print_msg():
print ("========================================")
print ("| LCD1602 |")
print ("| ------------------------------ |")
print ("| D4 connect to GPIO25 |")
print ("| D5 connect to GPIO24 |")
print ("| D6 connect to GPIO23 |")
print ("| D7 connect to GPIO18 |")
print ("| RS connect to GPIO27 |")
print ("| CE connect to GPIO22 |")
print ("| RW connect to GND |")
print ("| |")
print ("| Control LCD1602 |")
print ("| |")
print ("| SunFounder|")
print ("========================================\n")
print ("Program is running...")
print ("Please press Ctrl+C to end the program...")
#raw_input ("Press Enter to begin\n")
def main():
global lcd
print_msg()
lcd = LCD()
line0 = " sunfounder.com"
line1 = "---SUNFOUNDER---"
lcd.clear()
lcd.message("Welcome to --->\n sunfounder.com")
sleep(3)
msg = "%s\n%s" % (line0, line1)
lcd.begin(0, 2)
lcd.clear()
for i in range(0, len(line0)):
lcd.setCursor(i, 0)
lcd.message(line0[i])
sleep(0.1)
for i in range(0, len(line1)):
lcd.setCursor(i, 1)
lcd.message(line1[i])
sleep(0.1)
sleep(1)
if __name__ == '__main__':
main()
lcd.clear()
lcd.destroy()
Code Explanation
class LCD: # Write an LCD class
''' Initialization function for the class, run when an object is created of the class.
A parameter needs to be transferred to the object when it's created; otherwise,
the default value in __init__ will be assigned. '''
self.used_gpio = self.pins_db[:] ''' Note down the used gpio to easily
clear IO setting after the stop. pins_db[:] writes all in the pins_db
list to the used_gpio list; if here use used_gpio = self.pins_db, it
means used_gpio call pins_db, in other words, any change of pins_db will
affect used_gpio. '''
self.displaymode = self.LCD_ENTRYLEFT # self.LCD_ENTRYSHIFTDECREMENT
self.write4bits(self.LCD_ENTRYMODESET # self.displaymode) # Set the entry mode
def begin(self, cols, lines): # Start the LCD
def setCursor(self, col, row): # Set the cursor location
def message(self, text): # Send strings to the LCD. The new line wraps to the second line
def destroy(self): # Clean up the used gpio
lcd = LCD(0, 2) # Create an lcd object
lcd.clear() # Clear the LCD display
for i in range(0, len(line0)): # i adds 1 each time within the length of the character line0
lcd.setCursor(i, 0) # Locate the cursor at character No. i, Row 0
lcd.message(line0[i]) # Display the character on the screen
sleep(0.1)
for i in range(0, len(line1)): # i adds 1 each time within the length of the character line0
lcd.setCursor(i, 1) # Locate the cursor at character No. i, Row 1
lcd.message(line1[i]) # Display the character on the LCD
You should see two lines of characters displayed on the LCD1602: ” Welcome to —> ” ,” sunfounder.com ” and “—SUNFOUNDER— “.
Further Exploration
In this experiment, the LCD1602 is driven in the 4-bit mode. You can try programming by yourself to drive it in the 8-bit mode.
