4.1.2 Automatic Capture Camera
When you are out, the little squirrels in the woods might visit your windowsill. Let’s make a automatic capture camera to leave pictures of these little cuties!
../_images/4.1.4_automatic_capture_list.png
ITEMS IN THIS KIT
COMPONENT INTRODUCTION
PURCHASE LINK
GPIO Extension Board
Jumper Wires
Resistor
Camera Module
PIR Motion Sensor Module
Schematic Diagram
T-Board Name
physical
wiringPi
GPIO17
Pin 11
0
17
../_images/4.1.4_automatic_capture_schematic.png
Experimental Procedures
Before this project, you need to make sure you complete 3.1.1 Photograph Module .
Step 1: Build the circuit.
../_images/4.1.4_automatic_capture_circuit.png
Step 2: Go into the Raspberry Pi Desktop. You may need a screen for a better experience, refer to: Connect your Raspberry Pi. Or access the Raspberry Pi desktop remotely, for a detailed tutorial please refer to Remote Desktop.
Step 3: Open a Terminal and get into the folder of the code.
cd ~/raphael-kit/python-pi5
Step 4: Run.
sudo python3 4.1.4_AutomaticCaptureCamera_zero.py
After the code runs, PIR will detect the surrounding environment, and if it senses the little squirrel passing by, the camera will take a photo. The photo interval is 3 seconds, and the total number of photos taken will be displayed through the print window.
There are two potentiometers on the PIR module: one is to adjust sensitivity and the other is to adjust the detection distance. To make the PIR module work better, you You need to turn both of them counterclockwise to the end.
../_images/4.1.4_PIR_TTE.png
You can also open 4.1.4_AutomaticCaptureCamera_zero.py in the ~/raphael-kit/python-pi5/ path with a Python IDE, click Run button to run, and stop the code with Stop button.
Warning
You can Modify/Reset/Copy/Run/Stop the code below. But before that, you need to go to source code path like raphael-kit/python-pi5. After modifying the code, you can run it directly to see the effect.
from gpiozero import MotionSensor
import os
# Retrieve the current user's login name and home directory
user = os.getlogin()
user_home = os.path.expanduser(f'~{user}')
# Initialize the camera
camera = Picamera2()
camera.start()
# Initialize the motion sensor on GPIO pin 17
pir = MotionSensor(17)
    i = 1  # Initialize the image count
        if pir.motion_detected:
            # Capture an image when motion is detected and save it with a unique number
            camera.capture_file(f'{user_home}/capture%s.jpg' % i)
            print('The number is %s' % i)  # Print the image count
            time.sleep(3)  # Wait for 3 seconds before next detection
            i += 1  # Increment the image count
            print('waiting')  # Print 'waiting' when no motion is detected
            time.sleep(0.5)  # Check for motion every 0.5 seconds
    # Stop the camera and turn off the LED if a KeyboardInterrupt occurs
    camera.stop_preview()
Code Explanation
  1. Imports the Picamera2 and Preview classes for camera control, the MotionSensor class for motion detection, and standard libraries time and os for time handling and operating system interactions.
    import os
  2. Retrieves the current user’s login name and home directory for saving captured images.
  3. Initializes the camera and starts it.
    camera.start()
  4. Initializes a PIR motion sensor connected to GPIO pin 17.
  5. Initializes a counter i to track the number of images captured. In an infinite loop, checks if motion is detected. If motion is detected, captures an image, saves it with a unique name based on the counter i, prints the image number, and waits for 3 seconds before checking for motion again. The counter i is incremented after each capture.
  6. If no motion is detected, prints waiting and checks for motion every 0.5 seconds.
  7. Catches a KeyboardInterrupt (like Ctrl+C) to stop the camera preview and exit the script gracefully.
