4.1.1 Camera
Here we will make a camera with a shutter, when you press the button, the camera shoots while the LED flashes.
Raphael Kit |
337 |
COMPONENT INTRODUCTION |
PURCHASE LINK |
Schematic Diagram
T-Board Name |
physical |
wiringPi |
BCM |
GPIO17 |
Pin 11 |
0 |
17 |
GPIO18 |
Pin 12 |
18 |
Experimental Procedures
Step 1: Build the circuit.
Step 2: Go into the Raspberry Pi Desktop. You may need a screen for a better experience, refer to: Connect your Raspberry Pi. Or access the Raspberry Pi desktop remotely, for a detailed tutorial please refer to Remote Desktop.
Step 3: Open a Terminal and get into the folder of the code.
cd ~/raphael-kit/python-pi5
Step 4: Run.
sudo python3 4.1.1_Camera_zero.py
After the code runs, press the button, the Raspberry Pi will flash the LED and take a picture. The photo will be named my_photo.jpg and stored in the ~ directory.
You can also open 4.1.1_Camera_zero.py in the ~/raphael-kit/python/ path with a Python IDE, click Run button to run, and stop the code with Stop button.
If you want to download the photo to your PC, please refer to FileZilla Software.
Warning
from gpiozero import LED, Button
import os
# Get the current user's login name and home directory
user = os.getlogin()
user_home = os.path.expanduser(f'~{user}')
# Initialize the camera
camera = Picamera2()
camera.start()
# Initialize a variable to track the camera's status
global status
status = False
# Set up LED and button with their GPIO pin numbers
led = LED(17)
button = Button(18)
def takePhotos(pin):
"""Function to set the camera's status to True when the button is pressed."""
global status
status = True
# Assign the function to be called when the button is pressed
button.when_pressed = takePhotos
# Main loop
# Check if the button has been pressed
if status:
# Blink the LED five times
for i in range(5):
led.on()
time.sleep(0.1)
led.off()
time.sleep(0.1)
# Capture and save a photo
camera.capture_file(f'{user_home}/my_photo.jpg')
print('Take a photo!')
# Reset the status
status = False
# Turn off the LED if not capturing
led.off()
# Wait for a short period before checking the button status again
time.sleep(1)
# Stop the camera and turn off the LED if a KeyboardInterrupt occurs
camera.stop_preview()
led.off()
Code Explanation
Imports necessary libraries for time handling, camera control, and GPIO component control.
#!/usr/bin/env python3 from picamera2 import Picamera2, Preview from gpiozero import LED, Button import time import os
Retrieves the current user’s login name and home directory for saving photos.
# Get the current user's login name and home directory user = os.getlogin() user_home = os.path.expanduser(f'~{user}')
Initializes the camera and starts it.
# Initialize the camera camera = Picamera2() camera.start()
Declares
statusas a global variable and initializes it toFalse.# Initialize a variable to track the camera's status global status status = False
Initializes an LED connected to GPIO pin 17 and a button connected to GPIO pin 18.
# Set up LED and button with their GPIO pin numbers led = LED(17) button = Button(18)
Defines a function
takePhotosthat sets the global variablestatustoTruewhen the button is pressed.def takePhotos(pin): """Function to set the camera's status to True when the button is pressed.""" global status status = True
Assigns the
takePhotosfunction to be called when the button is pressed.try: # Assign the function to be called when the button is pressed button.when_pressed = takePhotos ...
Continuously checks if the
statusisTrue. If so, it blinks the LED five times, captures a photo, and resetsstatus. If not, the LED remains off. There is a 1-second delay between each loop iteration.try: ... # Main loop while True: # Check if the button has been pressed if status: # Blink the LED five times for i in range(5): led.on() time.sleep(0.1) led.off() time.sleep(0.1) # Capture and save a photo camera.capture_file(f'{user_home}/my_photo.jpg') print('Take a photo!') # Reset the status status = False else: # Turn off the LED if not capturing led.off() # Wait for a short period before checking the button status again time.sleep(1)
Catches a KeyboardInterrupt (like Ctrl+C) and stops the camera preview and turns off the LED before exiting.
except KeyboardInterrupt: # Stop the camera and turn off the LED if a KeyboardInterrupt occurs camera.stop_preview() led.off() pass
