4.1.8 Battery Indicator(MCP3008)
In this project, we will make a battery indicator device that can visually display the battery level on the LED Bargraph.
Warning
Do not use battery components that exceed 3.3V to avoid overloading, which may damage the chip or Raspberry Pi.
../_images/list2_Battery_Indicator1.png
ITEMS IN THIS KIT
COMPONENT INTRODUCTION
PURCHASE LINK
GPIO Extension Board
Jumper Wires
Resistor
LED Bar Graph
MCP3008
Schematic Diagram
T-Board Name
physical
wiringPi
SPICE0
Pin 24
10
8
SPIMOSI
Pin 19
12
10
SPIMISO
Pin 21
13
9
SPISCLK
Pin 23
14
11
GPIO25
Pin 22
GPIO12
Pin 32
26
12
GPIO16
Pin 36
27
16
GPIO20
Pin 38
28
20
GPIO21
Pin 40
29
21
GPIO5
Pin 29
21
GPIO6
Pin 31
22
GPIO13
Pin 33
23
13
GPIO19
Pin 35
24
19
GPIO26
Pin 37
25
26
../_images/schematic_battery_indicator_mcp30081.png
Experimental Procedures
Step 1: Build the circuit.
../_images/july24_3.1.5_battery_indicator_mcp30081.png
Step 2: Set up the SPI interface and install the spidev library (see SPI Configuration for detailed instructions). If you have already completed these steps, you can skip this.
Step 3: Go to the folder of the code.
cd ~/raphael-kit/python-pi5
sudo python3 4.1.11-2_Battery_indicator_zero.py
After the program runs, give the 3rd pin of MCP3008 and the GND a lead-out wire separately and then lead them to the two poles of a battery separately. You can see the corresponding LED on the LED Bargraph is lit up to display the power level (measuring range: 0-5V).
Warning
You can Modify/Reset/Copy/Run/Stop the code below. But before that, you need to go to source code path like raphael-kit/python-pi5. After modifying the code, you can run it directly to see the effect.
import LCD1602
from gpiozero import LED, Buzzer, Button
import spidev
import math
# Initialize joystick button, buzzer, and LED
Joy_BtnPin = Button(22)  # GPIO22, Pin15
buzzPin = Buzzer(23)     # GPIO23, Pin16
ledPin = LED(24)         # GPIO24, Pin18
# Set initial upper temperature threshold
upperTem = 40
# Initialize SPI for MCP3008 (Bus 0, CE0 -> GPIO8 / Pin24)
spi = spidev.SpiDev()
spi.open(0, 0)
# Initialize LCD (I2C address 0x27, backlight on)
LCD1602.init(0x27, 1)
def read_adc(channel):
    Read analog value from MCP3008
        return -1
    return value
def get_joystick_value():
    Reads the joystick values and returns a change value based on the joystick's position.
    x_val = read_adc(1)
    y_val = read_adc(2)
    if x_val > 800:
        return 1
    elif x_val < 200:
        return -1
    elif y_val > 800:
        return -10
    elif y_val < 200:
        return 10
        return 0
def upper_tem_setting():
    Adjusts and displays the upper temperature threshold on the LCD.
    global upperTem
    LCD1602.write(0, 0, 'Upper Adjust: ')
    change = int(get_joystick_value())
    upperTem += change
    strUpperTem = str(upperTem)
    LCD1602.write(0, 1, strUpperTem)
    LCD1602.write(len(strUpperTem), 1, '              ')
    time.sleep(0.1)
def temperature():
    Reads the current temperature from the sensor and returns it in Celsius.
    analogVal = read_adc(0)
    Vr = 3.3 * analogVal / 1023.0  # Voltage across the fixed resistor
    if Vr == 0:
        return 0  # Prevent division by zero
    Rt = 10000.0 * (3.3 - Vr) / Vr  # Adjusted formula: thermistor voltage is (3.3 - Vr)
    temp = 1 / (((math.log(Rt / 10000.0)) / 3950.0) + (1 / (273.15 + 25.0)))
    Cel = temp - 273.15
    return round(Cel, 2)
def monitoring_temp():
    Monitors and displays the current temperature and upper temperature threshold.
    Activates buzzer and LED if the temperature exceeds the upper limit.
    global upperTem
    Cel = temperature()
    LCD1602.write(0, 0, 'Temp: ')
    LCD1602.write(0, 1, 'Upper: ')
    LCD1602.write(6, 0, str(Cel))
    LCD1602.write(7, 1, str(upperTem))
    time.sleep(0.1)
    if Cel >= upperTem:
        buzzPin.on()
        ledPin.on()
        buzzPin.off()
        ledPin.off()
# Main execution loop
    lastState = 1
    stage = 0
        currentState = Joy_BtnPin.value
            stage = (stage + 1) % 2
            time.sleep(0.1)
            LCD1602.clear()
        lastState = currentState
        if stage == 1:
            upper_tem_setting()
            monitoring_temp()
    LCD1602.clear()
    spi.close()
Code Explanation
This Python program runs on a Raspberry Pi. It uses an MCP3008 analog-to-digital converter to read temperature data from an analog sensor. A joystick is used to adjust the temperature threshold, and an LCD1602 display shows the current temperature and threshold. A buzzer and LED are triggered when the temperature exceeds the threshold.
  1. Import Required Libraries
    import RPi.GPIO as GPIO
    import spidev
    import math
    import LCD1602
    • RPi.GPIO is used for controlling GPIO pins.
    • spidev communicates with MCP3008 using SPI.
    • math is needed for temperature conversion calculations.
    • LCD1602 controls the LCD display.
  2. GPIO Setup
    JOY_BTN_PIN = 22
    BUZZER_PIN = 23
    LED_PIN = 24
    GPIO.setmode(GPIO.BCM)
    GPIO.setup(JOY_BTN_PIN, GPIO.IN, pull_up_down=GPIO.PUD_UP)
    GPIO.setup(BUZZER_PIN, GPIO.OUT)
    GPIO.setup(LED_PIN, GPIO.OUT)
    • Assigns pins for joystick button, buzzer, and LED using BCM numbering.
    • Configures the joystick button with a pull-up resistor and sets output pins LOW initially.
  3. SPI and LCD Initialization
    upperTem = 40  # Default temperature threshold
    spi.open(0, 0)
    • Initializes SPI communication for the MCP3008.
    • Sets up the I2C LCD1602 at address 0x27.
  4. Read ADC Channel
            return -1
        return value
    • Sends SPI commands to MCP3008 to read analog voltage from the selected channel (0–7).
    • Returns a 10-bit result between 0 and 1023.
  5. Joystick Direction Input
        x_val = read_adc(1)
        y_val = read_adc(2)
        if x_val > 800:
            return 1
        elif x_val < 200:
            return -1
        elif y_val > 800:
            return -10
        elif y_val < 200:
            return 10
            return 0
    • Reads horizontal (X) and vertical (Y) joystick movement and translates that into a change in threshold:
      • Up/Down adjusts by 10.
      • Left/Right adjusts by 1.
  6. Adjust Temperature Threshold
        global upperTem
        upperTem += change
        time.sleep(0.1)
    • Allows the user to change the upperTem threshold via joystick.
    • Updates LCD to display the current threshold value.
  7. Calculate Temperature from Analog Sensor
    def temperature():
        if Vr == 0:
            return 0
        tempK = 1.0 / (((math.log(Rt / 10000.0)) / 3950.0) + (1.0 / (273.15 + 25.0)))
        Cel = tempK - 273.15
    • Converts voltage reading to resistance, then uses the Steinhart-Hart equation to compute the temperature in Celsius.
  8. Monitoring Mode
        global upperTem
        Cel = temperature()
        time.sleep(0.1)
        if Cel >= upperTem:
            GPIO.output(BUZZER_PIN, GPIO.HIGH)
            GPIO.output(LED_PIN, GPIO.HIGH)
            GPIO.output(BUZZER_PIN, GPIO.LOW)
            GPIO.output(LED_PIN, GPIO.LOW)
    • Displays the current temperature and threshold.
    • Activates buzzer and LED if the current temperature exceeds the threshold.
  9. Main Loop
        lastState = GPIO.input(JOY_BTN_PIN)
        stage = 0
            currentState = GPIO.input(JOY_BTN_PIN)
            if currentState == GPIO.HIGH and lastState == GPIO.LOW:
                time.sleep(0.1)
                LCD1602.clear()
            if stage == 1:
                upper_tem_setting()
                monitoring_temp()
    • Uses joystick button press to toggle between:
      • stage 0: temperature monitoring
      • stage 1: threshold adjustment
  10. Cleanup on Exit
finally:
    LCD1602.clear()
    GPIO.cleanup()
    spi.close()
  • Ensures GPIO and LCD are reset on program termination (e.g., Ctrl+C).
