2.15 Two Kinds of Transistors
This kit is equipped with two types of transistors, S8550 and S8050, the former is PNP and the latter is NPN. They look very similar, and we need to check carefully to see their labels. When a High level signal goes through an NPN transistor, it is energized. But a PNP one needs a Low level signal to manage it. Both types of transistor are frequently used for contactless switches, just like in this experiment.
img_NPN&PNP
Let’s use LED and button to understand how to use transistor!
Transistor
Way to connect NPN (S8050) transistor
sch_s8050
In this circuit, when the button is pressed, GP14 is high.
By programming GP15 to output high, after a 1k current limiting resistor (to protect the transistor), the S8050 (NPN transistor) is allowed to conduct, thus allowing the LED to light up.
wiring_s8050
Way to connect PNP(S8550) transistor
sch_s8550
In this circuit, GP14 is low by the default and will change to high when the button is pressed.
By programming GP15 to output low, after a 1k current limiting resistor (to protect the transistor), the S8550 (PNP transistor) is allowed to conduct, thus allowing the LED to light up.
The only difference you will notice between this circuit and the previous one is that in the previous circuit the cathode of the LED is connected to the collector of the S8050 (NPN transistor), while this one is connected to the emitter of the S8550 (PNP transistor).
wiring_s8550
  • Open the 2.15_transistor.py file under the path of euler-kit/micropython or copy this code into Thonny, then click “Run Current Script” or simply press F5 to run it.
  • Don’t forget to click on the “MicroPython (Raspberry Pi Pico)” interpreter in the bottom right corner.
  • For detailed tutorials, please refer to Open and Run Code Directly.
import machine
button = machine.Pin(14, machine.Pin.IN)
signal = machine.Pin(15, machine.Pin.OUT)
    button_status = button.value()
    if button_status== 1:
        signal.value(1)
    elif button_status == 0:
        signal.value(0)
Two kinds of transistors can be controlled with the same code. When we press the button, Pico will send a high-level signal to the transistor; when we release it, it will send a low-level signal. We can see that diametrically opposite phenomena have occurred in the two circuits.
  • The circuit using the S8050 (NPN transistor) will light up when the button is pressed, which means it is receiving a high-level conduction circuit;
  • The circuit that uses the S8550 (PNP transistor) will light up when it is released, which means it is receiving a low-level conduction circuit.
