2.2 Display the Level¶
The first project is simply to make the LED blink. For this project, let’s use the LED Bar Graph, which contains 10 LEDs in a plastic enclosure, generally used to display power or volume levels.
Schematic
In the LED Bar Graph, there are 10 LEDs, each of which can be controlled individually. Each LED’s anode is connected to GP6*GP15, and its cathode to a 220ohm resistor, and then to GND.
Open the
2.2_display_the_level.py
file under the path ofeuler-kit/micropython
or copy this code into Thonny, then click “Run Current Script” or simply press F5 to run it.Don’t forget to click on the “MicroPython (Raspberry Pi Pico)” interpreter in the bottom right corner.
For detailed tutorials, please refer to Open and Run Code Directly.
import machine
import utime
pin = [6,7,8,9,10,11,12,13,14,15]
led= []
for i in range(10):
led.append(None)
led[i] = machine.Pin(pin[i], machine.Pin.OUT)
for i in range(10):
led[i].toggle()
utime.sleep(0.2)
On the LED Bar Graph, you’ll see LEDs lighting up and then turning off in sequence when the program is running.
How it works?
The LED Bar consists of ten LEDs that are controlled by ten pins, which means that we must define these pins.
The process would be too tedious if we defined them one by one. So, here we use Lists
Python lists are one of the most versatile data types that allow us to work with multiple elements at once, and created by placing elements inside square brackets [], separated by commas.
A list pin
is defined by this line of code, which contains the ten elements 6,7,8,9,10,11,12,13,14,15
We can use the index operator [] to access an item in a list. In Python, indices start at 0. So, a list having 10 elements will have an index from 0 to 9.
Using this list as an example, pin[0]
is 6
and pin[4]
is 10
Next, declare an empty list led
that will be used to define ten LED objects.
led = []
Due to the length of the list, which is 0, direct operations on the array, such as printing led[0]**, won’t work. There are new items we need to add.
led.append(None)
As a result of this append()
method, the list led
has its first item, of length 1, and led[0]
becomes a valid element despite its current value of None
(which stands for null).
Our next step is to define led[0]
, the LED connected to pin 6, as the first LED object.
led[0] = machine.Pin(6, machine.Pin.OUT)
The first LED object has now been defined.
As you can see, we have created the ten pin numbers as a list pin, which we can substitute into this line to make it easier to do bulk operations.
led[0] = machine.Pin(pin[0], machine.Pin.OUT)
Use a for
statement to have all 10 pins execute the above statement.
import machine
led= []
for i in range(10):
led.append(None)
Use another for
loop to make the ten LEDs on the LED Bar switch states one by one.
for i in range(10):
led[i].toggle()
utime.sleep(0.2)
The code is finished by putting the above piece of code in a while loop.
import machine
import utime
led= []
for i in range(10):
led.append(None)
for i in range(10):
led[i].toggle()
utime.sleep(0.2)
