3.3 RGB LED Strip
WS2812 is a intelligent control LED light source that the control circuit and RGB chip are integrated in a package of 5050 components. It internal include intelligent digital port data latch and signal reshaping amplification drive circuit. Also include a precision internal oscillator and a programmable constant current control part, effectively ensuring the pixel point light color height consistent.
The data transfer protocol use single NZR communication mode. After the pixel power-on reset, the DIN port receive data from controller, the first pixel collect initial 24bit data then sent to the internal data latch, the other data which reshaping by the internal signal reshaping amplification circuit sent to the next cascade pixel through the DO port. After transmission for each pixel,the signal to reduce 24bit. pixel adopt auto reshaping transmit technology, making the pixel cascade number is not limited the signal transmission, only depend on the speed of signal transmission.
Schematic
sch_ws2812
wiring_ws2812
Warning
One thing you need to pay attention to is current.
Although the LED Strip with any number of LEDs can be used in Pico, the power of its VBUS pin is limited. Here, we will use eight LEDs, which are safe. But if you want to use more LEDs, you need to add a separate power supply.
  • Open the 3.3_rgb_led_strip.py file under the path of euler-kit/micropython or copy this code into Thonny, then click “Run Current Script” or simply press F5 to run it.
  • Don’t forget to click on the “MicroPython (Raspberry Pi Pico)” interpreter in the bottom right corner.
  • For detailed tutorials, please refer to Open and Run Code Directly.
  • Here you need to use the library called ws2812.py, please check if it has been uploaded to Pico, for a detailed tutorial refer to Upload the Libraries to Pico.
import machine
from ws2812 import WS2812
ws = WS2812(machine.Pin(0),8)
ws[0] = [64,154,227]
ws[1] = [128,0,128]
ws[2] = [50,150,50]
ws[3] = [255,30,30]
ws[4] = [0,128,255]
ws[5] = [99,199,0]
ws[6] = [128,128,128]
ws[7] = [255,100,0]
ws.write()
Let’s select some favorite colors and display them on the RGB LED Strip!
How it works?
In the ws2812 library, we have integrated related functions into the WS2812 class.
You can use the RGB LED Strip with the following statement.
Declare a WS2812 type object, named “ws”, it is connected to “pin”, there are “number” RGB LEDs on the WS2812 strip.
ws = WS2812(pin,number)
ws is an array object, each element corresponds to one RGB LED on the WS2812 strip, for example, ws[0] is the first one, ws[7] is the eighth.
We can assign color values to each RGB LED, these values must be 24-bit color (represented with six hexadecimal digits) or list of 3 8-bit RGB.
For example, the red value is “0xFF0000” or “[255,0,0]”.
ws[i] = color value
Then use this statement to write the color for the LED Strip and light it up.
ws.write()
You can also directly use the following statement to make all LEDs light up the same color.
ws.write_all(color value)
Learn More
We can randomly generate colors and make a colorful flowing light.
  • Open the 3.3_rgb_led_strip_2.py file under the path of euler-kit/micropython or copy this code into Thonny, then click “Run Current Script” or simply press F5 to run it.
import machine
import utime
import urandom
def flowing_light():
    for i in range(7,0,-1):
        ws[i] = ws[i-1]
    ws[0] = int(urandom.uniform(0, 0xFFFFFF))
    ws.write()
    utime.sleep_ms(80)
    flowing_light()
    print(ws[0])
