2.9 Feel the Magnetism
The most common type of reed switch contains a pair of magnetizable, flexible, metal reeds whose end portions are separated by a small gap when the switch is open.
A magnetic field from an electromagnet or a permanent magnet will cause the reeds to attract each other, thus completing an electrical circuit. The spring force of the reeds causes them to separate, and open the circuit, when the magnetic field ceases.
A common example of a reed switch application is to detect the opening of a door or windows, for a security alarm.
Schematic
sch_reed
By default, GP14 is low; and will go high when the magnet is near the reed switch.
The purpose of the 10K resistor is to keep the GP14 at a steady low level when no magnet is near.
wiring_reed
  • Open the 2.9_feel_the_magnetism.py file under the path of euler-kit/micropython or copy this code into Thonny, then click “Run Current Script” or simply press F5 to run it.
  • Don’t forget to click on the “MicroPython (Raspberry Pi Pico)” interpreter in the bottom right corner.
  • For detailed tutorials, please refer to Open and Run Code Directly.
import machine
import utime
reed = machine.Pin(14, machine.Pin.IN)
    if reed.value() == 1:
        print("There are magnets here!!")
        utime.sleep(1)
When the code is run, GP14 goes high when a magnet is near the reed switch, otherwise it goes low. Just like the button in the 2.5 Reading Button Value chapter.
Learn More
This time, we tried a flexible way of using switches: interrupt requests, or IRQs.: interrupt requests, or IRQs.
For example, you are reading a book page by page, as if a program is executing a thread. At this time, someone came to you to ask a question and interrupted your reading. Then the person is executing the interrupt request: asking you to stop what you are doing, answer his questions, and then let you return to reading the book after the end.
MicroPython interrupt request also works in the same way, it allows certain operations to interrupt the main program.
  • Open the 2.9_feel_the_magnetism_irq.py file under the path of euler-kit/micropython or copy this code into Thonny, then click “Run Current Script” or simply press F5 to run it.
import machine
import utime
reed_switch = machine.Pin(14, machine.Pin.IN)
def detected(pin):
    print("Magnet!")
reed_switch.irq(trigger=machine.Pin.IRQ_RISING, handler=detected)
Here first a callback function detected(pin) is defined, called the interrupt handler. It will be executed when an interrupt request is triggered. Then, an interrupt request is set up in the main program, which contains two parts: the trigger and the handler.
In this program, trigger is IRQ_RISING, which indicates that the value of the pin is raised from low to high (i.e., button press).
handler is detected , the callback function we defined before.
