7.7 Guess Number
Guessing Numbers is a fun party game where you and your friends input numbers (0-99). With each input of the number, the range will shrink until a player answers the riddle correctly. Then the player is defeated and punished.
As an example, if the lucky number is 51, which the players cannot see, and the player 1 inputs 50, the prompt changes to 50 - 99; if the player 2 inputs 70, the range changes to 50 - 70; if the player 3 inputs 51, the player is unlucky. In this case, numbers are inputted through the keypad, and outcomes are displayed on a LCD screen.
Schematic
sch_guess_number
This circuit is based on 4.2 4x4 Keypad with the addition of an I2C LCD1602 to display the pressed keys.
wiring_game_guess_number
To make the wiring easier, in the above diagram, the column row of the matrix keyboard and the 10K resistors are inserted into the holes where G10 ~ G13 are located at the same time.
  • Open the 7.7_game_guess_number.py file under the path of euler-kit/micropython or copy this code into Thonny, then click “Run Current Script” or simply press F5 to run it.
  • Don’t forget to click on the “MicroPython (Raspberry Pi Pico)” interpreter in the bottom right corner.
  • For detailed tutorials, please refer to Open and Run Code Directly.
from lcd1602 import LCD
import machine
import urandom
# keypad function
characters = [["1","2","3","A"],["4","5","6","B"],["7","8","9","C"],["*","0","#","D"]]
pin = [21,20,19,18]
row = []
for i in range(4):
    row.append(None)
    row[i] = machine.Pin(pin[i], machine.Pin.OUT)
pin = [13,12,11,10]
col = []
for i in range(4):
    col.append(None)
    col[i] = machine.Pin(pin[i], machine.Pin.IN)
def readKey():
    key = []
    for i in range(4):
        row[i].high()
        for j in range(4):
            if(col[j].value() == 1):
                key.append(characters[i][j])
        row[i].low()
    if key == [] :
        return None
        return key
# init/reset number
# reset the result as False for lcd show
def init_new_value():
global pointValue,upper,count,lower
pointValue = int(urandom.uniform(0, 99))
print(pointValue)
upper = 99
lower = 0
count = 0
return False
# lcd show message
# If target, show game over.
# If not target, or not detected, show guess number.
def lcd_show(result):
    lcd.clear()
    if result == True:
        string ="GAME OVER!\n"
        string +="Point is "+ str(pointValue)
    else :
        string ="Enter number: " + str(count) +"\n"
        string += str(lower)+ " < Point < " + str(upper)
    lcd.message(string)
    return
# detect number & reflesh show message
# if not target, reflesh number (upper or lower) and return False
# if target, return True
def number_processing():
    global upper,count,lower
    if count > pointValue:
        if count < upper:
            upper = count
    elif count < pointValue:
        if count > lower:
            lower = count
    elif count == pointValue:
        return True
    count = 0
    return False
## start
lcd = LCD()
string = "Welcome!\n"
string = "Press A to Start!"
lcd.message(string)
result=init_new_value()
# read key & display
last_key = None
    current_key = readKey()
    if current_key == last_key:
        continue
    last_key = current_key
    if current_key != None:
        # print(current_key)
        if current_key ==["A"]: # reset number
        elif current_key==["D"]: # check
            result=number_processing()
        elif current_key[0] in list(["1","2","3","4","5","6","7","8","9","0"]) and count < 10: #check validity & limit digits
            count = count * 10 + int(current_key[0])
        lcd_show(result) # show
    time.sleep(0.1)
  • After the code runs, press A to start the game. A random number point is produced but not displayed on the LCD, and what you need to do is to guess it.
  • The number you have typed appears at the end of the first line till the final calculation is finished. (Press D to start the comparation.)
  • The number range of point is displayed on the second line. And you must type the number within the range.
  • When you type a number, the range narrows; if you got the lucky number luckily or unluckily, there will appear GAME OVER!
