3.5 Small Fan
Now we use the L293D to drive the DC motor to make it rotate clockwise and counterclockwise. Since the DC motor requires a relatively large current, for safety reasons, here we use a power module to supply power to the motor.
Schematic
sch_motor
In this circuit, you will see that the button is connected to the RUN pin. This is because the motor is operating with too much current, which may cause the Pico to disconnect from the computer, and the button needs to be pressed (for the Pico’s RUN pin to receive a low level) to reset.
L293D is a motor driver chip, EN is connected to 5V to make L293D work. 1A and 2A are the inputs connected to GP15 and GP14 respectively; 1Y and 2Y are the outputs connected to the two ends of the motor.
Y (output) is in phase with A (input), so if GP15 and GP14 are given different levels respectively, the direction of motor rotation can be changed.
wiring_motor
Since DC motors require a high current, we use a power supply module to power the motor here for safety reasons.
  • Open the 3.5_small_fan.py file under the path of euler-kit/micropython or copy this code into Thonny, then click “Run Current Script” or simply press F5 to run it.
  • Don’t forget to click on the “MicroPython (Raspberry Pi Pico)” interpreter in the bottom right corner.
  • For detailed tutorials, please refer to Open and Run Code Directly.
import machine
import utime
motor1A = machine.Pin(14, machine.Pin.OUT)
motor2A = machine.Pin(15, machine.Pin.OUT)
def clockwise():
    motor1A.high()
    motor2A.low()
def anticlockwise():
    motor1A.low()
    motor2A.high()
def stopMotor():
    motor1A.low()
    motor2A.low()
    clockwise()
    utime.sleep(1)
    stopMotor()
    utime.sleep(1)
    anticlockwise()
    utime.sleep(1)
    stopMotor()
    utime.sleep(1)
Once the program is running, the motor will rotate back and forth in a regular pattern.
  • If the motor is still spinning after you click the Stop button, you need to reset the RUN pin on the Pico with a wire to GND at this time, and then unplug this wire to run the code again.
  • This is because the motor is operating with too much current, which may cause the Pico to disconnect from the computer.
wiring_run_reset
