7.2 Room Temperature Meter
Using a thermistor and an I2C LCD1602, we can create a room temperature meter.
This project is very simple, it is based on 2.13 Thermometer with I2C LCD1602 to display the temperature.
Schematic
sch_room_temp
wiring_room_temp
  • Open the 7.2_room_temperature_meter.py file under the path of euler-kit/micropython or copy this code into Thonny, then click “Run Current Script” or simply press F5 to run it.
  • Don’t forget to click on the “MicroPython (Raspberry Pi Pico)” interpreter in the bottom right corner.
  • For detailed tutorials, please refer to Open and Run Code Directly.
from lcd1602 import LCD
import machine
import utime
import math
thermistor = machine.ADC(28)
lcd = LCD()
    temperature_value = thermistor.read_u16()
    Vr = 3.3 * float(temperature_value) / 65535
    Rt = 10000 * Vr / (3.3 - Vr)
    temp = 1/(((math.log(Rt / 10000)) / 3950) + (1 / (273.15+25)))
    Cel = temp - 273.15
    #Fah = Cel * 1.8 + 32
    #print ('Celsius: %.2f C  Fahrenheit: %.2f F' % (Cel, Fah))
    #utime.sleep_ms(200)
    string = " Temperature is \n    " + str('{:.2f}'.format(Cel))+ " C"
    lcd.message(string)
    utime.sleep(1)
    lcd.clear()
The LCD will display the temperature value in the current environment after the program runs.
