3.1.8 Overheat Monitor(MCP3008)
You may want to make an overheat monitoring device that applies to various situations, ex., in the factory, if we want to have an alarm and the timely automatic turning off of the machine when there is a circuit overheating. In this project, we will use thermistor, joystick, buzzer, LED and LCD to make an smart temperature monitoring device whose threshold is adjustable.
../_images/list2_Overheat_Monitor1.png
Schematic Diagram
T-Board Name
physical
wiringPi
SPICE0
Pin 24
10
8
SPIMOSI
Pin 19
12
10
SPIMISO
Pin 21
13
9
SPISCLK
Pin 23
14
11
GPIO22
Pin15
GPIO23
Pin16
GPIO24
Pin18
SDA1
Pin 3
SCL1
Pin 5
../_images/schematic_over_monitor_mcp3008.png
Experimental Procedures
Step 1: Build the circuit.
../_images/july24_3.1.8_overheat_monitor_mcp30081.png
Step 2: Set up the SPI interface and install the spidev library (see SPI Configuration for detailed instructions). If you have already completed these steps, you can skip this.
Step 3: Go to the folder of the code.
sudo python3 3.1.8-2_OverheatMonitor_zero.py
As the code runs, the current temperature and the high-temperature threshold 40 are displayed on I2C LCD1602. If the current temperature is larger than the threshold, the buzzer and LED are started to alarm you.
Joystick here is for your pressing to adjust the high-temperature threshold. Toggling the Joystick in the direction of X-axis and Y-axis can adjust (turn up or down) the current high-temperature threshold. Press the Joystick once again to reset the threshold to initial value.
  • If you get the error FileNotFoundError: [Errno 2] No such file or directory: '/dev/i2c-1', you need to refer to I²C Configuration to enable the I2C.
  • If you get ModuleNotFoundError: No module named 'smbus2' error, please run sudo apt install python3-smbus2.
  • If the error OSError: [Errno 121] Remote I/O error appears, it means the module is miswired or the module is broken.
  • If the code and wiring are fine, but the LCD still does not display content, you can turn the potentiometer on the back to increase the contrast.
Warning
You can Modify/Reset/Copy/Run/Stop the code below. But before that, you need to go to source code path like davinci-kit-for-raspberry-pi/python. After modifying the code, you can run it directly to see the effect.
import LCD1602
from gpiozero import LED, Buzzer, Button
import spidev
import math
# Initialize joystick button, buzzer, and LED
Joy_BtnPin = Button(22)  # GPIO22, Pin15
buzzPin = Buzzer(23)     # GPIO23, Pin16
ledPin = LED(24)         # GPIO24, Pin18
# Set initial upper temperature threshold
upperTem = 40
# Initialize SPI for MCP3008 (Bus 0, CE0 -> GPIO8 / Pin24)
spi = spidev.SpiDev()
spi.open(0, 0)
# Initialize LCD (I2C address 0x27, backlight on)
LCD1602.init(0x27, 1)
def read_adc(channel):
    Read analog value from MCP3008 (0–7)
        return -1
    return value
def get_joystick_value():
    Reads the joystick values and returns a change value based on the joystick's position.
    x_val = read_adc(1)
    y_val = read_adc(2)
    if x_val > 800:
        return 1
    elif x_val < 200:
        return -1
    elif y_val > 800:
        return -10
    elif y_val < 200:
        return 10
        return 0
def upper_tem_setting():
    Adjusts and displays the upper temperature threshold on the LCD.
    global upperTem
    LCD1602.write(0, 0, 'Upper Adjust: ')
    change = int(get_joystick_value())
    upperTem += change
    strUpperTem = str(upperTem)
    LCD1602.write(0, 1, strUpperTem)
    LCD1602.write(len(strUpperTem), 1, '              ')
    time.sleep(0.1)
def temperature():
    Reads the current temperature from the sensor and returns it in Celsius.
    analogVal = read_adc(0)
    Vr = 3.3 * analogVal / 1023.0  # Voltage across the fixed resistor
    if Vr == 0:
        return 0  # Prevent division by zero
    Rt = 10000.0 * Vr / (3.3 - Vr)  # Adjusted formula: thermistor voltage is (3.3 - Vr)
    temp = 1 / (((math.log(Rt / 10000.0)) / 3950.0) + (1 / (273.15 + 25.0)))
    Cel = temp - 273.15
    return round(Cel, 2)
def monitoring_temp():
    Monitors and displays the current temperature and upper temperature threshold.
    Activates buzzer and LED if the temperature exceeds the upper limit.
    global upperTem
    Cel = temperature()
    LCD1602.write(0, 0, 'Temp: ')
    LCD1602.write(0, 1, 'Upper: ')
    LCD1602.write(6, 0, str(Cel))
    LCD1602.write(7, 1, str(upperTem))
    time.sleep(0.1)
    if Cel >= upperTem:
        buzzPin.on()
        ledPin.on()
        buzzPin.off()
        ledPin.off()
# Main execution loop
    lastState = 1
    stage = 0
        currentState = Joy_BtnPin.value
            stage = (stage + 1) % 2
            time.sleep(0.1)
            LCD1602.clear()
        lastState = currentState
        if stage == 1:
            upper_tem_setting()
            monitoring_temp()
    LCD1602.clear()
    spi.close()
Code Explanation
  1. This section imports the required libraries. LCD1602 is for LCD display via I2C, gpiozero provides support for the LED, Buzzer, and Button, spidev is used to communicate with the MCP3008 ADC, and standard time and math libraries are used for delays and temperature calculations.
    import LCD1602
    import spidev
    import math
  2. Initializes hardware components connected to GPIO pins:
    • Button(22) connects to the joystick button.
    • Buzzer(23) and LED(24) serve as output indicators for high temperature.
  3. Sets the default upper temperature threshold and initializes both SPI for MCP3008 and the LCD1602 display.
    upperTem = 40
    spi.open(0, 0)
    spi.max_speed_hz = 1000000
  4. This function reads the analog value from a specified channel (0–7) on the MCP3008 using SPI protocol and returns a 10-bit value.
            return -1
        return value
  5. The joystick’s position is evaluated by reading channels 1 and 2 of the MCP3008. Depending on X or Y direction, different values are returned for threshold adjustments.
        x_val = read_adc(1)
        y_val = read_adc(2)
        if x_val > 800:
            return 1
        elif x_val < 200:
            return -1
        elif y_val > 800:
            return -10
        elif y_val < 200:
            return 10
            return 0
  6. Adjusts the upper temperature threshold using the joystick. Displays the current threshold on the LCD and ensures clean formatting.
        global upperTem
        upperTem += change
        time.sleep(0.1)
  7. This function reads the analog value from MCP3008 channel 0 (connected to a thermistor), calculates voltage, resistance, and ultimately the temperature in Celsius using the Steinhart–Hart approximation.
    def temperature():
        if Vr == 0:
        Cel = temp - 273.15
  8. Continuously reads the current temperature, compares it with the upper threshold, and displays both on the LCD. If the temperature exceeds the threshold, the buzzer and LED are turned on.
        global upperTem
        Cel = temperature()
        time.sleep(0.1)
        if Cel >= upperTem:
            buzzPin.on()
            ledPin.on()
            buzzPin.off()
            ledPin.off()
  9. The main execution loop alternates between setting mode and monitoring mode using a joystick button. A press toggles the mode. In setting mode, the upper threshold is adjusted; in monitoring mode, temperature is continuously checked.
        lastState = 1
        stage = 0
                time.sleep(0.1)
                LCD1602.clear()
            if stage == 1:
                upper_tem_setting()
                monitoring_temp()
  10. Ensures that the LCD is cleared and SPI communication is properly closed when the program exits via keyboard interruption.
        LCD1602.clear()
        spi.close()
