3.1.5 Battery Indicator
In this project, we will make a battery indicator device that can visually display the battery level on the LED Bargraph.
../_images/4.1.11_battery_indicator_list.png
Schematic Diagram
T-Board Name
physical
wiringPi
GPIO17
Pin 11
0
17
GPIO18
Pin 12
GPIO27
Pin 13
GPIO25
Pin 22
GPIO12
Pin 32
26
12
GPIO16
Pin 36
27
16
GPIO20
Pin 38
28
20
GPIO21
Pin 40
29
21
GPIO5
Pin 29
21
GPIO6
Pin 31
22
GPIO13
Pin 33
23
13
GPIO19
Pin 35
24
19
GPIO26
Pin 37
25
26
../_images/4.1.11_battery_indicator_schematic.png
Experimental Procedures
Step 1: Build the circuit.
../_images/4.1.11_battery_indicator_circuit.png
Step 3: Run the executable file.
sudo python3 3.1.5_BatteryIndicator.py
After the program runs, give the 3rd pin of ADC0834 and the GND a lead-out wire separately and then lead them to the two poles of a battery separately. You can see the corresponding LED on the LED Bargraph is lit up to display the power level (measuring range: 0-5V).
Warning
You can Modify/Reset/Copy/Run/Stop the code below. But before that, you need to go to source code path like davinci-kit-for-raspberry-pi/python-pi5. After modifying the code, you can run it directly to see the effect.
from gpiozero import LED
import ADC0834
# List of GPIO pins to which LEDs are connected
ledPins = [25, 12, 16, 20, 21, 5, 6, 13, 19, 26]
# Initialize LED objects for each pin in the list
leds = [LED(pin) for pin in ledPins]
# Setup ADC0834 module
ADC0834.setup()
def LedBarGraph(value):
    # Turn off all LEDs
    for i in range(10):
        leds[i].off()
    # Turn on LEDs up to the specified value
    for i in range(value):
        leds[i].on()
    # Main loop to continuously update LED bar graph
        # Read analog value from ADC0834
        # Convert analog value to LED bar graph level
        LedBarGraph(int(analogVal/25))
    # Turn off all LEDs when program is interrupted
    for i in range(10):
        leds[i].off()
Code Explanation
  1. This section imports the necessary libraries. gpiozero is for controlling the LEDs, ADC0834 for interfacing with the ADC module, and time for time-related operations.
    import ADC0834
  2. Defines the GPIO pins to which the LEDs are connected and initializes an array of LED objects for each pin. This allows for easy control of each LED in the array.
  3. Initializes the ADC0834 module for analog-to-digital conversion.
    ADC0834.setup()
  4. This function turns off all LEDs and then turns on a number of LEDs based on the input value, effectively creating a bar graph representation.
        # Turn off all LEDs
        for i in range(10):
            leds[i].off()
            leds[i].on()
  5. Continuously reads the analog value from the ADC0834 and updates the LED bar graph based on this value. The analog value is scaled down to a range of 0-10 for the 10 LEDs.
  6. Ensures all LEDs are turned off when the program is interrupted (e.g., by pressing Ctrl+C).
        for i in range(10):
            leds[i].off()
