3.1.10 Alarm Bell
In this project, we will make a manual alarm device. You can replace the toggle switch with a thermistor or a photosensitive sensor to make a temperature alarm or a light alarm.
../_images/4.1.15_alarm_bell_list.png
Schematic Diagram
T-Board Name
physical
wiringPi
GPIO17
Pin 11
0
17
GPIO18
Pin 12
GPIO27
Pin 13
GPIO22
Pin 15
../_images/4.1.15_alarm_bell_schematic.png
Experimental Procedures
Step 1: Build the circuit.
../_images/4.1.15_alarm_bell_circuit.png
Step 2: Change directory.
Step 3: Run.
sudo python3 3.1.10_AlarmBell.py
After the program starts, the toggle switch will be toggled to the right, and the buzzer will give out alarm sounds. At the same time, the red and green LEDs will flash at a certain frequency.
Warning
You can Modify/Reset/Copy/Run/Stop the code below. But before that, you need to go to source code path like davinci-kit-for-raspberry-pi/python-pi5.
from gpiozero import LED, Button, TonalBuzzer
import threading
# Initialize TonalBuzzer on GPIO pin 22
BeepPin = TonalBuzzer(22)
# Initialize LEDs on GPIO pins 17 and 27
ALedPin = LED(17)
BLedPin = LED(27)
# Initialize Button on GPIO pin 18
switchPin = Button(18)
# Global flag to control the buzzer and LED states
flag = 0
def ledWork():
    Control LED blinking pattern based on the flag state.
    When flag is set, alternately blink ALedPin and BLedPin.
        if flag:
            # Alternate blinking of LEDs
            ALedPin.on()
            time.sleep(0.5)
            ALedPin.off()
            BLedPin.on()
            time.sleep(0.5)
            BLedPin.off()
            # Turn off both LEDs if flag is not set
            ALedPin.off()
            BLedPin.off()
# Define the musical tune as a list of notes and their durations
tune = [
    ('C4', 0.1), ('E4', 0.1), ('G4', 0.1),
    (None, 0.1),
    ('E4', 0.1), ('G4', 0.1), ('C5', 0.1),
    (None, 0.1),
    ('C5', 0.1), ('G4', 0.1), ('E4', 0.1),
    (None, 0.1),
    ('G4', 0.1), ('E4', 0.1), ('C4', 0.1),
    (None, 0.1)
def buzzerWork():
    Play a tune using the buzzer based on the flag state.
    The tune is played only when the flag is set.
        for note, duration in tune:
            if flag == 0:
                break
            print(note)  # Output the current note to the console
            BeepPin.play(note)  # Play the current note
            time.sleep(duration)  # Pause for the duration of the note
        BeepPin.stop()  # Stop the buzzer after playing the tune
def main():
    Monitor button press to update the flag state.
    Sets the flag when the button is pressed.
    global flag
        flag = 1 if switchPin.is_pressed else 0
    # Initialize and start threads for buzzer and LED control
    tBuzz = threading.Thread(target=buzzerWork)
    tBuzz.start()
    tLed = threading.Thread(target=ledWork)
    tLed.start()
    main()
    # Stop the buzzer and turn off LEDs on program interruption
    BeepPin.stop()
    ALedPin.off()
    BLedPin.off()
Code Explanation
  1. This segment includes the import of essential libraries for implementing delays and threading. It also imports the LED, Button, and TonalBuzzer classes from the gpiozero library, crucial for controlling GPIO devices on a Raspberry Pi.
    import threading
  2. Sets up a buzzer on GPIO pin 22, two LEDs on GPIO pins 17 and 27, and initializes a button on GPIO pin 18. A global flag is also defined to manage the state of the buzzer and LEDs.
    ALedPin = LED(17)
    BLedPin = LED(27)
    flag = 0
  3. This function controls the blinking of the LEDs based on the flag’s state. If the flag is set (1), it alternates between turning on and off each LED. If not set (0), both LEDs are turned off.
    def ledWork():
            if flag:
                ALedPin.on()
                time.sleep(0.5)
                ALedPin.off()
                BLedPin.on()
                time.sleep(0.5)
                BLedPin.off()
                ALedPin.off()
                BLedPin.off()
  4. The tune is defined as a sequence of notes (frequency) and durations (seconds).
    tune = [
        (None, 0.1),
        (None, 0.1),
        (None, 0.1),
        (None, 0.1)
  5. Plays a predefined tune when the flag is set. The tune stops if the flag is unset during its play.
    def buzzerWork():
                if flag == 0:
                    break
  6. Continuously checks the state of the button to set or unset the flag.
    def main():
        global flag
  7. Threads for buzzerWork and ledWork are started, allowing them to run concurrently with the main function.
        tBuzz.start()
        tLed.start()
        main()
  8. Stops the buzzer and turns off LEDs when the program is interrupted, ensuring a clean exit.
        BeepPin.stop()
        ALedPin.off()
        BLedPin.off()
