.. note::
**Why Join?**
- **Expert Support**: Solve post-sale issues and technical challenges with help from our community and team.
- **Learn & Share**: Exchange tips and tutorials to enhance your skills.
- **Exclusive Previews**: Get early access to new product announcements and sneak peeks.
- **Special Discounts**: Enjoy exclusive discounts on our newest products.
- **Festive Promotions and Giveaways**: Take part in giveaways and holiday promotions.
👉 Ready to explore and create with us? Click [|link_sf_facebook|] and join today!
.. _3.1.8_py_pi5_mcp3008:
3.1.8 Overheat Monitor(MCP3008)
.. note::
:width: 25%
:align: left
Depending on your kit version, please identify whether you have **ADC0834** or **MCP3008** and proceed with the matching section.
You may want to make an overheat monitoring device that applies to
various situations, ex., in the factory, if we want to have an alarm and
the timely automatic turning off of the machine when there is a circuit
overheating. In this project, we will use thermistor, joystick, buzzer,
LED and LCD to make an smart temperature monitoring device whose
threshold is adjustable.
.. image:: ../python_pi5/img/list2_Overheat_Monitor.png
:width: 800
:align: center
Schematic Diagram
SPICE0 Pin 24 10 8
SPIMOSI Pin 19 12 10
SPIMISO Pin 21 13 9
SPISCLK Pin 23 14 11
GPIO22 Pin15 3 22
GPIO23 Pin16 4 23
GPIO24 Pin18 5 24
SDA1 Pin 3
SCL1 Pin 5
.. image:: ../python_pi5/img/schematic_over_monitor_mcp3008.png
:align: center
Experimental Procedures
**Step 1:** Build the circuit.
.. image:: ../python_pi5/img/july24_3.1.8_overheat_monitor_mcp3008.png
**Step 2:** Set up the SPI interface and install the ``spidev`` library (see :ref:`spi_configuration` for detailed instructions). If you have already completed these steps, you can skip this.
**Step 3**: Go to the folder of the code.
.. raw:: html
.. code-block::
**Step 4**: Run the executable file.
.. raw:: html
.. code-block::
sudo python3 3.1.8-2_OverheatMonitor_zero.py
As the code runs, the current temperature and the high-temperature
threshold **40** are displayed on **I2C LCD1602**. If the current
temperature is larger than the threshold, the buzzer and LED are started
to alarm you.
**Joystick** here is for your pressing to adjust the high-temperature
threshold. Toggling the **Joystick** in the direction of X-axis and
Y-axis can adjust (turn up or down) the current high-temperature
threshold. Press the **Joystick** once again to reset the threshold to
initial value.
.. note::
* If you get the error ``FileNotFoundError: [Errno 2] No such file or directory: '/dev/i2c-1'``, you need to refer to :ref:`i2c_config` to enable the I2C.
* If you get ``ModuleNotFoundError: No module named 'smbus2'`` error, please run ``sudo apt install python3-smbus2``.
* If the error ``OSError: [Errno 121] Remote I/O error`` appears, it means the module is miswired or the module is broken.
* If the code and wiring are fine, but the LCD still does not display content, you can turn the potentiometer on the back to increase the contrast.
.. warning::
If there is an error prompt ``RuntimeError: Cannot determine SOC peripheral base address``, please refer to :ref:`faq_soc`
**Code**
.. note::
You can **Modify/Reset/Copy/Run/Stop** the code below. But before that, you need to go to source code path like ``davinci-kit-for-raspberry-pi/python``. After modifying the code, you can run it directly to see the effect.
.. raw:: html
.. code-block:: python
import LCD1602
from gpiozero import LED, Buzzer, Button
import spidev
import math
# Initialize joystick button, buzzer, and LED
Joy_BtnPin = Button(22) # GPIO22, Pin15
buzzPin = Buzzer(23) # GPIO23, Pin16
ledPin = LED(24) # GPIO24, Pin18
# Set initial upper temperature threshold
upperTem = 40
# Initialize SPI for MCP3008 (Bus 0, CE0 -> GPIO8 / Pin24)
spi = spidev.SpiDev()
spi.open(0, 0)
spi.max_speed_hz = 1000000 # 1 MHz
# Initialize LCD (I2C address 0x27, backlight on)
LCD1602.init(0x27, 1)
def read_adc(channel):
Read analog value from MCP3008 (0–7)
return -1
return value
def get_joystick_value():
Reads the joystick values and returns a change value based on the joystick's position.
x_val = read_adc(1)
y_val = read_adc(2)
if x_val > 800:
return 1
elif x_val < 200:
return -1
elif y_val > 800:
return -10
elif y_val < 200:
return 10
return 0
def upper_tem_setting():
Adjusts and displays the upper temperature threshold on the LCD.
global upperTem
LCD1602.write(0, 0, 'Upper Adjust: ')
change = int(get_joystick_value())
upperTem += change
strUpperTem = str(upperTem)
LCD1602.write(0, 1, strUpperTem)
LCD1602.write(len(strUpperTem), 1, ' ')
time.sleep(0.1)
def temperature():
Reads the current temperature from the sensor and returns it in Celsius.
analogVal = read_adc(0)
Vr = 3.3 * analogVal / 1023.0 # Voltage across the fixed resistor
if Vr == 0:
return 0 # Prevent division by zero
Rt = 10000.0 * Vr / (3.3 - Vr) # Adjusted formula: thermistor voltage is (3.3 - Vr)
temp = 1 / (((math.log(Rt / 10000.0)) / 3950.0) + (1 / (273.15 + 25.0)))
Cel = temp - 273.15
return round(Cel, 2)
def monitoring_temp():
Monitors and displays the current temperature and upper temperature threshold.
Activates buzzer and LED if the temperature exceeds the upper limit.
global upperTem
Cel = temperature()
LCD1602.write(0, 0, 'Temp: ')
LCD1602.write(0, 1, 'Upper: ')
LCD1602.write(6, 0, str(Cel))
LCD1602.write(7, 1, str(upperTem))
time.sleep(0.1)
if Cel >= upperTem:
buzzPin.on()
ledPin.on()
buzzPin.off()
ledPin.off()
# Main execution loop
lastState = 1
stage = 0
currentState = Joy_BtnPin.value
stage = (stage + 1) % 2
time.sleep(0.1)
LCD1602.clear()
lastState = currentState
if stage == 1:
upper_tem_setting()
monitoring_temp()
LCD1602.clear()
spi.close()
Code Explanation
#. This section imports the required libraries. ``LCD1602`` is for LCD display via I2C, ``gpiozero`` provides support for the LED, Buzzer, and Button, ``spidev`` is used to communicate with the MCP3008 ADC, and standard ``time`` and ``math`` libraries are used for delays and temperature calculations.
import LCD1602
import spidev
import math
#. Initializes hardware components connected to GPIO pins:
* ``Button(22)`` connects to the joystick button.
* ``Buzzer(23)`` and ``LED(24)`` serve as output indicators for high temperature.
#. Sets the default upper temperature threshold and initializes both SPI for MCP3008 and the LCD1602 display.
upperTem = 40
spi.open(0, 0)
#. This function reads the analog value from a specified channel (0–7) on the MCP3008 using SPI protocol and returns a 10-bit value.
return -1
return value
#. The joystick’s position is evaluated by reading channels 1 and 2 of the MCP3008. Depending on X or Y direction, different values are returned for threshold adjustments.
x_val = read_adc(1)
y_val = read_adc(2)
if x_val > 800:
return 1
elif x_val < 200:
return -1
elif y_val > 800:
return -10
elif y_val < 200:
return 10
return 0
#. Adjusts the upper temperature threshold using the joystick. Displays the current threshold on the LCD and ensures clean formatting.
global upperTem
upperTem += change
time.sleep(0.1)
#. This function reads the analog value from MCP3008 channel 0 (connected to a thermistor), calculates voltage, resistance, and ultimately the temperature in Celsius using the Steinhart–Hart approximation.
def temperature():
if Vr == 0:
Cel = temp - 273.15
#. Continuously reads the current temperature, compares it with the upper threshold, and displays both on the LCD. If the temperature exceeds the threshold, the buzzer and LED are turned on.
global upperTem
Cel = temperature()
time.sleep(0.1)
if Cel >= upperTem:
buzzPin.on()
ledPin.on()
buzzPin.off()
ledPin.off()
#. The main execution loop alternates between setting mode and monitoring mode using a joystick button. A press toggles the mode. In setting mode, the upper threshold is adjusted; in monitoring mode, temperature is continuously checked.
lastState = 1
stage = 0
time.sleep(0.1)
LCD1602.clear()
if stage == 1:
upper_tem_setting()
monitoring_temp()
#. Ensures that the LCD is cleared and SPI communication is properly closed when the program exits via keyboard interruption.
LCD1602.clear()
spi.close()
