3.1.11 Morse Code Generator
In this project, we’ll make a Morse code generator, where you type in a series of English letters in the Raspberry Pi to make it appear as Morse code.
../_images/4.1.16_morse_code_generator_list.png
Schematic Diagram
T-Board Name
physical
wiringPi
GPIO17
Pin 11
0
17
GPIO22
Pin 15
../_images/4.1.16_morse_code_generator_schematic.png
Experimental Procedures
Step 1: Build the circuit. (Pay attention to poles of the buzzer: The one with + label is the positive pole and the other is the negative.)
../_images/4.1.16_morse_code_generator_circuit.png
Step 2: Open the code file.
Step 3: Run.
sudo python3 3.1.11_MorseCodeGenerator.py
After the program runs, type a series of characters, and the buzzer and the LED will send the corresponding Morse code signals.
Warning
from gpiozero import Buzzer, LED
# Initialize Buzzer and LED to GPIO pins
BeepPin = Buzzer(22)
ALedPin = LED(17)
# Morse code representation for characters
MORSECODE = {
    'A': '01', 'B': '1000', 'C': '1010', 'D': '100', 'E': '0', 'F': '0010', 'G': '110',
    'H': '0000', 'I': '00', 'J': '0111', 'K': '101', 'L': '0100', 'M': '11', 'N': '10',
    'O': '111', 'P': '0110', 'Q': '1101', 'R': '010', 'S': '000', 'T': '1',
    'U': '001', 'V': '0001', 'W': '011', 'X': '1001', 'Y': '1011', 'Z': '1100',
    '1': '01111', '2': '00111', '3': '00011', '4': '00001', '5': '00000',
    '6': '10000', '7': '11000', '8': '11100', '9': '11110', '0': '11111',
    '?': '001100', '/': '10010', ',': '110011', '.': '010101', ';': '101010',
    '!': '101011', '@': '011010', ':': '111000',
def on():
    """ Turn on the buzzer and LED. """
    BeepPin.on()
    ALedPin.on()
def off():
    """ Turn off the buzzer and LED. """
    BeepPin.off()
    ALedPin.off()
def beep(dt):  # dt for delay time.
    Produce a beep sound and LED flash for the specified duration.
    :param dt: Duration for the beep and flash.
    on()
    time.sleep(dt)
    off()
    time.sleep(dt)
def morsecode(code):
    Convert the input code into Morse code and signal it using the buzzer and LED.
    :param code: The text to be converted to Morse code.
    pause = 0.25
    for letter in code:
        for tap in MORSECODE[letter]:
            if tap == '0':
                beep(pause / 2)  # Short beep for dot
            if tap == '1':
                beep(pause)      # Long beep for dash
        time.sleep(pause)  # Pause between letters
def destroy():
    """ Clean up resources on script termination. """
    print("")
    BeepPin.off()
    ALedPin.off()
        code = input("Please input the messenger:")
        code = code.upper()  # Convert to uppercase for Morse code lookup
        print(code)
        morsecode(code)
    destroy()
Code Explanation
  1. This code imports the Buzzer and LED classes from the gpiozero library. These classes are essential for controlling the corresponding GPIO devices on the Raspberry Pi.
  2. Initializes the buzzer on GPIO pin 22 and the LED on GPIO pin 17, facilitating the control of these components.
    ALedPin = LED(17)
  3. Defines the MORSE structure, a dictionary containing Morse code representations for characters A-Z, numbers 0-9, and symbols like “?”, “/”, “:”, “,”, “.”, “;”, “!”, “@”, with 0 signifying a dot and 1 indicating a dash.
    MORSECODE = {
  4. The function on() starts the buzzer and the LED. The function off() is used to turn off the buzzer and the LED.
    def on():
        BeepPin.on()
        ALedPin.on()
    def off():
        BeepPin.off()
        ALedPin.off()
  5. Define a function beep() to make the buzzer and the LED emit sounds and blink in a certain interval of dt.
        on()
        time.sleep(dt)
        off()
        time.sleep(dt)
  6. The function morsecode() is used to process the Morse code of input characters by making the “1” of the code keep emitting sounds or lights and the “0”shortly emit sounds or lights, ex., input “SOS”, and there will be a signal containing three short three long and then three short segments “ · · · - - - · · · ”.
        pause = 0.25
        for letter in code:
                if tap == '0':
                if tap == '1':
  7. Defines a function named destroy that turns off both the buzzer and the LED. This function is intended to be called when the script is terminated to ensure that the GPIO pins are not left in an active state.
    def destroy():
        print("")
        BeepPin.off()
        ALedPin.off()
  8. When you type the relevant characters with the keyboard, upper() will convert the input letters to their capital form. printf() then prints the clear text on the computer screen, and the morsecod() function causes the buzzer and the LED to emit Morse code.
            print(code)
            morsecode(code)
        destroy()
