3.1.6 Motion Control
In this lesson, we will make a simple motion sensing and controlling device. The MPU6050 is used as a sensor and the stepper motor as a controlled device. With the MPU6050 mounted on the glove, you can control the stepper motor by rotating your wrist.
../_images/3.1.6_motion_list.png
Schematic Diagram
T-Board Name
physical
wiringPi
GPIO18
Pin 12
GPIO23
Pin 16
GPIO24
Pin 18
GPIO25
Pin 22
SDA1
Pin 3
SCL1
Pin 5
../_images/3.1.6_motion_schematic.png
Experimental Procedures
Step 1: Build the circuit.
../_images/3.1.6_motion_control_circuit.png
Step 2: Open the code file.
Step 3: Run.
sudo python3 3.1.6_MotionControl.py
As the code runs, if the tilt angle of mpu6050 on the Y-axis is larger than 45 ℃, the stepper motor rotates anticlockwise; if less than -45 ℃, the stepper motor rotates clockwise.
Warning
You can Modify/Reset/Copy/Run/Stop the code below. But before that, you need to go to source code path like davinci-kit-for-raspberry-pi/python-pi5. After modifying the code, you can run it directly to see the effect.
import smbus
import math
# Initialize power management registers for MPU6050
power_mgmt_1 = 0x6b
power_mgmt_2 = 0x6c
# Set up I2C communication with MPU6050
bus = smbus.SMBus(1)  # Initialize SMBus
address = 0x68        # MPU6050 I2C address
bus.write_byte_data(address, power_mgmt_1, 0)  # Wake up MPU6050
# Initialize motor pins to GPIO pins 18, 23, 24, 25
motorPin = [OutputDevice(pin) for pin in (18, 23, 24, 25)]
# Set motor rotation speed parameters
rolePerMinute = 15
stepsPerRevolution = 2048
# Calculate delay between steps for desired RPM
stepSpeed = (60 / rolePerMinute) / stepsPerRevolution
# Read a single byte from the specified I2C address
def read_byte(adr):
    return bus.read_byte_data(address, adr)
# Read a word (2 bytes) from the specified I2C address
def read_word(adr):
    high = bus.read_byte_data(address, adr)
    low = bus.read_byte_data(address, adr + 1)
    val = (high << 8) + low
    return val
# Read a word in 2's complement form
def read_word_2c(adr):
    val = read_word(adr)
    if val >= 0x8000:
        return -((65535 - val) + 1)
        return val
# Calculate Euclidean distance between two points
def dist(a, b):
    return math.sqrt((a * a) + (b * b))
# Calculate Y-axis rotation
def get_y_rotation(x, y, z):
    radians = math.atan2(x, dist(y, z))
    return -math.degrees(radians)
# Calculate X-axis rotation
def get_x_rotation(x, y, z):
    radians = math.atan2(y, dist(x, z))
    return math.degrees(radians)
# Get tilt angle from MPU6050
def mpu6050():
    accel_xout = read_word_2c(0x3b)
    accel_yout = read_word_2c(0x3d)
    accel_zout = read_word_2c(0x3f)
    accel_xout_scaled = accel_xout / 16384.0
    accel_yout_scaled = accel_yout / 16384.0
    accel_zout_scaled = accel_zout / 16384.0
    angle = get_y_rotation(accel_xout_scaled, accel_yout_scaled, accel_zout_scaled)
    return angle
# Control stepper motor rotation
def rotary(direction):
    if direction == 'c':
        # Clockwise rotation sequence
        for j in range(4):
            for i in range(4):
                if 0x99 >> j & (0x08 >> i):
                    motorPin[i].on()
                    motorPin[i].off()
                time.sleep(stepSpeed)
    elif direction == 'a':
        # Anti-clockwise rotation sequence
        for j in range(4):
            for i in range(4):
                if 0x99 << j & (0x08 >> i):
                    motorPin[i].on()
                    motorPin[i].off()
# Main loop for continuously reading tilt angle and controlling motor
        angle = mpu6050()
        if angle >= 45:
            rotary('a')  # Rotate anti-clockwise for positive tilt
        elif angle <= -45:
            rotary('c')  # Rotate clockwise for negative tilt
    # Turn off all motor pins on keyboard interrupt
    for pin in motorPin:
        pin.off()
Code Explanation
  1. The script begins by importing necessary libraries. gpiozero for controlling the GPIO pins, smbus for I2C communication, math for mathematical operations, and time for delays.
    import smbus
    import math
  2. Sets up I2C communication with the MPU6050 sensor. power_mgmt_1 and power_mgmt_2 are registers for managing the sensor’s power. The sensor is “woken up” by writing to power_mgmt_1.
    power_mgmt_1 = 0x6b
    power_mgmt_2 = 0x6c
  3. Initializes the GPIO pins (18, 23, 24, 25) on the Raspberry Pi to control the stepper motor. Each pin is associated with a coil in the motor.
  4. Sets the motor’s rotations per minute (RPM) and the number of steps per revolution. stepSpeed calculates the delay between steps to achieve the desired RPM, ensuring smooth motor operation.
    rolePerMinute = 15
  5. These functions are used for I2C communication. read_byte reads a single byte from a given address, while read_word reads two bytes (a word), combining them into a single value using bitwise operations (<< and +).
    def read_byte(adr):
    def read_word(adr):
        return val
  6. This function converts the read word into a 2’s complement form, which is useful for interpreting signed values from sensor data. This conversion is necessary for handling negative sensor readings.
        if val >= 0x8000:
            return val
  7. dist calculates the Euclidean distance between two points, used in the rotation calculations. get_y_rotation and get_x_rotation calculate the rotational angles along the Y and X axes, respectively, using the atan2 function from the math library and converting the result to degrees.
    def dist(a, b):
  8. This function reads the accelerometer data from the MPU6050 sensor, scales the readings, and calculates the tilt angle using the get_y_rotation function. The function read_word_2c reads sensor data in 2’s complement form to handle negative values.
    def mpu6050():
        return angle
  9. The rotary function controls the stepper motor rotation. It executes a stepping sequence for either clockwise or anti-clockwise rotation, based on the direction parameter. The sequence involves turning specific motor pins on or off in a pattern.
            for j in range(4):
                for i in range(4):
                        motorPin[i].on()
                        motorPin[i].off()
            for j in range(4):
                for i in range(4):
                        motorPin[i].on()
                        motorPin[i].off()
  10. The main loop continuously reads the tilt angle from the MPU6050 sensor and controls the motor’s rotation direction based on the angle. If the program is interrupted (e.g., through a keyboard interrupt), it turns off all motor pins for safety.
            angle = mpu6050()
            if angle >= 45:
            elif angle <= -45:
            pin.off()
