3.1.3 Reversing Alarm
In this project, we will use LCD, buzzer and ultrasonic sensors to make a reverse assist system. We can put it on the remote control vehicle to simulate the actual process of reversing the car into the garage.
../_images/4.1.9_reversing_alarm_list.png
Schematic Diagram
Ultrasonic sensor detects the distance between itself and the obstacle that will be displayed on the LCD in the form of code. At the same time, the ultrasonic sensor let the buzzer issue prompt sound of different frequency according to different distance value.
T-Board Name
physical
wiringPi
GPIO23
Pin 16
GPIO24
Pin 18
GPIO17
Pin 11
0
17
SDA1
Pin 3
SCL1
Pin 5
../_images/4.1.9_reversing_alarm_schematic.png
Experimental Procedures
Step 1: Build the circuit.
../_images/4.1.9_reversing_alarm_circuit.png
Step 2: Change directory.
Step 3: Run.
sudo python3 3.1.3_ReversingAlarm.py
As the code runs, ultrasonic sensor module detects the distance to the obstacle and then displays the information about the distance on LCD1602; besides, buzzer emits warning tone whose frequency changes with the distance.
  • If you get the error FileNotFoundError: [Errno 2] No such file or directory: '/dev/i2c-1', you need to refer to I²C Configuration to enable the I2C.
  • If you get ModuleNotFoundError: No module named 'smbus2' error, please run sudo apt install python3-smbus2.
  • If the error OSError: [Errno 121] Remote I/O error appears, it means the module is miswired or the module is broken.
  • If the code and wiring are fine, but the LCD still does not display content, you can turn the potentiometer on the back to increase the contrast.
Warning
You can Modify/Reset/Copy/Run/Stop the code below. But before that, you need to go to source code path like davinci-kit-for-raspberry-pi/python-pi5. After modifying the code, you can run it directly to see the effect.
import LCD1602
from gpiozero import DistanceSensor, Buzzer
# Initialize the ultrasonic sensor with GPIO pins
sensor = DistanceSensor(echo=24, trigger=23)  # Echo pin is GPIO 24, Trigger pin is GPIO 23
# Initialize the buzzer connected to GPIO pin 17
buzzer = Buzzer(17)
def lcdsetup():
    # Initialize the LCD with I2C address and enable backlight
    LCD1602.init(0x27, 1)  # 0x27 is the I2C address of the LCD
    LCD1602.clear()  # Clear the LCD display
    # Display startup messages on LCD
    LCD1602.write(0, 0, 'Ultrasonic Starting')
    LCD1602.write(1, 1, 'By SunFounder')
    time.sleep(2)  # Wait for 2 seconds
def distance():
    # Calculate and return the distance measured by the sensor
    dis = sensor.distance * 100  # Convert distance to centimeters
    print('Distance: {:.2f} cm'.format(dis))  # Print distance with two decimal places
    time.sleep(0.3)  # Wait for 0.3 seconds before next measurement
    return dis
def loop():
    # Continuously measure distance and update LCD and buzzer
        dis = distance()  # Get the current distance
        # Display distance and handle alerts based on distance
        if dis > 400:  # Check if distance is out of range
            LCD1602.clear()
            LCD1602.write(0, 0, 'Error')
            LCD1602.write(3, 1, 'Out of range')
            time.sleep(0.5)
            # Display current distance on LCD
            LCD1602.clear()
            LCD1602.write(0, 0, 'Distance is')
            LCD1602.write(5, 1, str(round(dis, 2)) + ' cm')
            # Adjust buzzer frequency based on distance
            if dis >= 50:
                time.sleep(0.5)
            elif 20 < dis < 50:
                # Medium distance: medium buzzer frequency
                for _ in range(2):
                    buzzer.on()
                    time.sleep(0.05)
                    buzzer.off()
                    time.sleep(0.2)
            elif dis <= 20:
                # Close distance: high buzzer frequency
                for _ in range(5):
                    buzzer.on()
                    time.sleep(0.05)
                    buzzer.off()
                    time.sleep(0.05)
    lcdsetup()  # Setup the LCD display
    loop()      # Start the measurement loop
    # Turn off buzzer and clear LCD on user interrupt (e.g., Ctrl+C)
    buzzer.off()
LCD1602.clear()
Code Explanation
  1. This script utilizes several libraries for its functionality. The LCD1602 library manages the LCD display, while time provides time-related functions. The gpiozero library is essential for Raspberry Pi GPIO pin interactions, particularly for operating the DistanceSensor and Buzzer.
    import LCD1602
  2. The ultrasonic sensor is set up with its echo and trigger pins connected to GPIO pins 24 and 23, respectively. Additionally, a buzzer is connected to GPIO pin 17.
    buzzer = Buzzer(17)
  3. The initialization of the LCD display involves clearing it and displaying a startup message.
    def lcdsetup():
  4. The distance function calculates the distance measured by the ultrasonic sensor and outputs it, returning the value in centimeters.
    def distance():
        return dis
  5. The main loop continually measures the distance, updating both the LCD and the buzzer. It handles different distance ranges with specific actions, like displaying error messages or varying buzzer frequencies based on the measured distance.
    def loop():
                LCD1602.clear()
                time.sleep(0.5)
                LCD1602.clear()
                if dis >= 50:
                    time.sleep(0.5)
                elif 20 < dis < 50:
                    for _ in range(2):
                        buzzer.on()
                        time.sleep(0.05)
                        buzzer.off()
                        time.sleep(0.2)
                elif dis <= 20:
                    for _ in range(5):
                        buzzer.on()
                        time.sleep(0.05)
                        buzzer.off()
                        time.sleep(0.05)
  6. Upon execution, the script sets up the LCD and enters the main loop. It can be interrupted with a keyboard command (Ctrl+C), which turns off the buzzer and clears the LCD.
        buzzer.off()
        LCD1602.clear()
