3.1.14 GAME– Not Not
In this lesson, we will make an interesting game device, and we call it "Not Not".
During the game, the dot matrix will refresh an arrow randomly. What you need to do is to press the button in the opposite direction of the arrow within a limited time. If the time is up, or if the button in the same direction as the arrow is pressed, you are out.
This game can really practice your reverse thinking, and now shall we have a try?
../_images/3.1.14_game_not_not_list.png
Schematic Diagram
T-Board Name
physical
wiringPi
GPIO17
Pin 11
0
17
GPIO18
Pin 12
GPIO27
Pin 13
GPIO20
Pin 38
28
20
GPIO26
Pin 37
25
26
../_images/3.1.14_game_not_not_schematic.png
Experimental Procedures
Step 1: Build the circuit.
../_images/3.1.14_game_not_not_circuit.png
Step 2: Open the code file.
Step 3: Run.
sudo python3 3.1.14_MotionControl.py
After starting the program, on the dot matrix appears an arrow pointing to the right or the left. What you need to do is to press the button in the opposite direction of the arrow within a limited time. Then "" appears on the dot matrix. If the time is up, or if the button in the same direction as the arrow is pressed, you are out and the dot matrix displays "x". You can also add 2 new buttons or replace them with Joystick keys for up, down, left and right— 4 directions to increase the difficulty of the game.
Warning
You can Modify/Reset/Copy/Run/Stop the code below. But before that, you need to go to source code path like davinci-kit-for-raspberry-pi/python-pi5. After modifying the code, you can run it directly to see the effect.
from gpiozero import OutputDevice, Button
import threading
import random
# GPIO pins for the 74HC595 shift register
SDI = OutputDevice(17)   # Serial Data Input
RCLK = OutputDevice(18)  # Register Clock
SRCLK = OutputDevice(27) # Shift Register Clock
# GPIO pins for buttons
AButtonPin = Button(20)  # Button A
BButtonPin = Button(26)  # Button B
# Game variables initialization
timerPlay = 0
timerCheck = 0
waypoint = "NULL"
stage = "NULL"
# Arrow glyphs for LED matrix display
arrow = {
    "right": [0xFF, 0xEF, 0xDF, 0x81, 0xDF, 0xEF, 0xFF, 0xFF],
    "left": [0xFF, 0xF7, 0xFB, 0x81, 0xFB, 0xF7, 0xFF, 0xFF]
# Feedback glyphs for correct/wrong answers
check = {
    "wrong": [0xFF, 0xBB, 0xD7, 0xEF, 0xD7, 0xBB, 0xFF, 0xFF],
    "right": [0xFF, 0xFF, 0xF7, 0xEB, 0xDF, 0xBF, 0xFF, 0xFF]
def hc595_shift(dat):
    """ Shift data to the 74HC595 shift register. """
    for i in range(8):
        SDI.value = 0x80 & (dat << i)
        SRCLK.on()
        SRCLK.off()
def display(glyphCode):
    """ Display a glyph on the LED matrix. """
    for i in range(0, 8):
        hc595_shift(glyphCode[i])
        hc595_shift(0x80 >> i)
        RCLK.on()
        RCLK.off()
def creatGlyph():
    """ Create a new glyph for the game and start the play timer. """
    global waypoint, stage, timerPlay
    waypoint = random.choice(list(arrow.keys()))
    stage = "PLAY"
    timerPlay = threading.Timer(2.0, timeOut)
    timerPlay.start()
def checkPoint(inputKey):
    """ Check player's input and update game state. """
    global waypoint, stage, timerCheck
    if inputKey == "empty" or inputKey == waypoint:
        waypoint = "wrong"
        waypoint = "right"
    timerPlay.cancel()
    stage = "CHECK"
    timerCheck = threading.Timer(1.0, creatGlyph)
    timerCheck.start()
def timeOut():
    """ Handle game timeout scenario. """
    checkPoint("empty")
def getKey():
    """ Detect button press and trigger checkpoint. """
    if AButtonPin.is_pressed and not BButtonPin.is_pressed:
        checkPoint("right")
    elif not AButtonPin.is_pressed and BButtonPin.is_pressed:
        checkPoint("left")
def main():
    """ Main game loop. """
    creatGlyph()
        if stage == "PLAY":
            display(arrow[waypoint])
            getKey()
        elif stage == "CHECK":
            display(check[waypoint])
def destroy():
    """ Clean up resources on program exit. """
    global timerPlay, timerCheck
    timerPlay.cancel()  # Cancel the play timer
    timerCheck.cancel()  # Cancel the checkpoint timer
# Run the game, handle KeyboardInterrupt for clean exit
    main()
    destroy()
Code Explanation
Based on 1.1.6 LED Dot Matrix, this lesson adds 2 buttons to make an amusing game device. So, if you are not very familiar with the dot matrix, please refer to 1.1.6 LED Dot Matrix.
  1. The code begins by importing necessary libraries. gpiozero is used for interacting with GPIO pins like buttons and output devices. time allows for adding delays, threading enables running multiple tasks concurrently, and random is useful for introducing randomness in the project.
    import threading
    import random
  2. Initializes GPIO pins for the shift register (SDI, RCLK, SRCLK) and buttons (AButtonPin, BButtonPin). The shift register is used to control multiple LEDs with fewer GPIO pins, which is crucial for the LED matrix display.
  3. Initializes variables used in the game logic, such as timers and game state indicators.
    timerPlay = 0
    timerCheck = 0
    waypoint = "NULL"
    stage = "NULL"
  4. Defines binary patterns for displaying arrows and feedback (right/wrong) on the LED matrix. Each array element represents a row of the LED matrix, where 1 and 0 correspond to an LED being on or off, respectively.
    arrow = {
    check = {
  5. This function shifts a byte of data to the 74HC595 shift register. It iterates over each bit of the dat byte, setting the SDI pin high or low accordingly, and toggles the SRCLK pin to shift the bit into the register.
        for i in range(8):
            SRCLK.on()
            SRCLK.off()
  6. This function displays a glyph on the LED matrix. It sends each row of the glyph (represented by glyphCode) and the row’s address to the shift register using hc595_shift, then toggles the RCLK pin to update the display.
            RCLK.on()
            RCLK.off()
  7. This function randomly selects a glyph from the arrow dictionary, starts the play timer, and sets the game stage to “PLAY”. The threading.Timer is used for timing control in the game.
    def creatGlyph():
        stage = "PLAY"
        timerPlay.start()
  8. This function checks the player’s input against the current glyph. If the input is correct, it sets the waypoint to “right”, otherwise to “wrong”. It then cancels the current play timer and starts a new timer for the next glyph.
            waypoint = "wrong"
            waypoint = "right"
        timerPlay.cancel()
        stage = "CHECK"
        timerCheck.start()
  9. This function is called when the game times out. It invokes checkPoint with “empty” to indicate no button was pressed in time.
    def timeOut():
        checkPoint("empty")
  10. This function checks the state of the buttons. If AButtonPin is pressed (and BButtonPin is not), it calls checkPoint with “right”. If BButtonPin is pressed (and AButtonPin is not), it calls checkPoint with “left”.
    def getKey():
            checkPoint("right")
            checkPoint("left")
  11. The main function controls the game flow. It starts by creating a glyph, then continuously checks the game stage. If in “PLAY” stage, it displays the current glyph and checks for button presses. In “CHECK” stage, it displays the feedback based on the player’s action.
    def main():
        creatGlyph()
            if stage == "PLAY":
                getKey()
  12. This function cancels any running timers when the program exits, ensuring a clean shutdown.
    def destroy():
  13. The game is run in a try block. If a KeyboardInterrupt (like pressing Ctrl+C) occurs, it catches the exception and calls destroy to clean up before exiting.
        main()
        destroy()
