3.1.1 Counting Device
Here we will make a number-displaying counter system, consisting of a PIR sensor and a 4-digit segment display. When the PIR detects that someone is passing by, the number on the 4-digit segment display will add 1. You can use this counter to count the number of people walking through the passageway.
../_images/4.1.7_counting_device_list_1.png ../_images/4.1.7_counting_device_list_2.png
Schematic Diagram
T-Board Name
physical
wiringPi
GPIO17
Pin 11
0
17
GPIO27
Pin 13
GPIO22
Pin 15
SPIMOSI
Pin 19
12
10
GPIO18
Pin 12
GPIO23
Pin 16
GPIO24
Pin 18
GPIO26
Pin 37
25
26
../_images/4.1.7_counting_device_schematic.png
Experimental Procedures
Step 1: Build the circuit.
../_images/4.1.7_counting_device_circuit.png
Step 3: Run the executable file.
sudo python3 3.1.1_CountingDevice.py
After the code runs, when the PIR detects that someone is passing by, the number on the 4-digit segment display will add 1.
There are two potentiometers on the PIR module: one is to adjust sensitivity and the other is to adjust the detection distance. To make the PIR module work better, you You need to turn both of them counterclockwise to the end.
../_images/4.1.7_PIR_TTE.png
Warning
You can Modify/Reset/Copy/Run/Stop the code below. But before that, you need to go to source code path like davinci-kit-for-raspberry-pi/python-pi5. After modifying the code, you can run it directly to see the effect.
from gpiozero import OutputDevice, MotionSensor
# Initialize PIR motion sensor on GPIO 26
pir = MotionSensor(26)
# Initialize shift register pins
SDI = OutputDevice(24)    # Serial Data Input
RCLK = OutputDevice(23)   # Register Clock Input
SRCLK = OutputDevice(18)  # Shift Register Clock Input
# Initialize 7-segment display pins
placePin = [OutputDevice(pin) for pin in (10, 22, 27, 17)]
# Define digit codes for 7-segment display
# Counter for the displayed number
counter = 0
def clearDisplay():
    # Clears the display by setting all segments off
    for _ in range(8):
        SDI.on()
        SRCLK.on()
        SRCLK.off()
    RCLK.on()
    RCLK.off()
def hc595_shift(data):
    # Shifts data into the 74HC595 shift register
    for i in range(8):
        SDI.value = 0x80 & (data << i)
        SRCLK.on()
        SRCLK.off()
    RCLK.on()
    RCLK.off()
def pickDigit(digit):
    # Activates a specific digit of the 7-segment display
    for pin in placePin:
        pin.off()
    placePin[digit].on()
def display():
    # Updates the display with the current counter value
    global counter
    clearDisplay()
    pickDigit(0)
    clearDisplay()
    pickDigit(1)
    hc595_shift(number[counter % 100//10])
    clearDisplay()
    pickDigit(2)
    hc595_shift(number[counter % 1000//100])
    clearDisplay()
    pickDigit(3)
    hc595_shift(number[counter % 10000//1000])
def loop():
    # Main loop to update display and check for motion
    global counter
    currentState = 0
    lastState = 0
        display()
        currentState = 1 if pir.motion_detected else 0
            counter += 1
        lastState = currentState
    loop()
    # Turn off all pins when the script is interrupted
    SDI.off()
    SRCLK.off()
    RCLK.off()
Code Explanation
  1. This line imports the OutputDevice and MotionSensor classes from the gpiozero library. OutputDevice can be an LED, motor, or any device that you want to control as an output. The MotionSensor is typically a PIR (Passive Infrared) sensor used to detect motion.
  2. Initializes the PIR motion sensor connected to GPIO pin 26.
  3. Initializes GPIO pins connected to the shift register’s Serial Data Input (SDI), Register Clock Input (RCLK), and Shift Register Clock Input (SRCLK).
  4. Initializes the pins for each digit of the 7-segment display and defines the binary codes for displaying numbers 0-9.
  5. Clears the 7-segment display by setting all segments off before displaying the next digit.
    def clearDisplay():
        for _ in range(8):
            SDI.on()
            SRCLK.on()
            SRCLK.off()
        RCLK.on()
        RCLK.off()
  6. Shifts a byte of data into the 74HC595 shift register, controlling the display segments.
        for i in range(8):
            SRCLK.on()
            SRCLK.off()
        RCLK.on()
        RCLK.off()
  7. Selects which digit of the 7-segment display to activate. Each digit is controlled by a separate GPIO pin.
            pin.off()
  8. Initiate the display for the unit digit first, followed by activating the display for the tens digit. Subsequently, engage the displays for the hundreds and thousands digits in order. This rapid succession of activations creates the illusion of a continuous four-digit display.
    def display():
        global counter
        clearDisplay()
        pickDigit(0)
        clearDisplay()
        pickDigit(1)
        clearDisplay()
        pickDigit(2)
        clearDisplay()
        pickDigit(3)
  9. Defines the main loop where the display is continuously updated, and the PIR sensor’s state is checked. If motion is detected, the counter is incremented.
    def loop():
        global counter
        currentState = 0
        lastState = 0
            display()
                counter += 1
  10. Runs the main loop and ensures that the script can be interrupted with a keyboard command (Ctrl+C), turning off all pins for a clean exit.
        loop()
        SDI.off()
        SRCLK.off()
        RCLK.off()
