3.1.5 Battery Indicator(MCP3008)
In this project, we will make a battery indicator device that can visually display the battery level on the LED Bargraph.
Warning
Do not use battery components that exceed 3.3V to avoid overloading, which may damage the chip or Raspberry Pi.
Schematic Diagram
T-Board Name |
physical |
wiringPi |
BCM |
SPICE0 |
Pin 24 |
10 |
8 |
SPIMOSI |
Pin 19 |
12 |
10 |
SPIMISO |
Pin 21 |
13 |
9 |
SPISCLK |
Pin 23 |
14 |
11 |
GPIO25 |
Pin 22 |
25 |
GPIO12 |
Pin 32 |
26 |
12 |
GPIO16 |
Pin 36 |
27 |
16 |
GPIO20 |
Pin 38 |
28 |
20 |
GPIO21 |
Pin 40 |
29 |
21 |
GPIO5 |
Pin 29 |
21 |
GPIO6 |
Pin 31 |
22 |
GPIO13 |
Pin 33 |
23 |
13 |
GPIO19 |
Pin 35 |
24 |
19 |
GPIO26 |
Pin 37 |
25 |
26 |
Experimental Procedures
Step 1: Build the circuit.
Step 2: Set up the SPI interface and install the spidev library (see SPI Configuration for detailed instructions). If you have already completed these steps, you can skip this.
Step 3: Go to the folder of the code.
sudo python3 3.1.5-2_Battery_indicator_zero.py
After the program runs, give the 3rd pin of MCP3008 and the GND a lead-out wire separately and then lead them to the two poles of a battery separately. You can see the corresponding LED on the LED Bargraph is lit up to display the power level (measuring range: 0-5V).
Warning
You can Modify/Reset/Copy/Run/Stop the code below. But before that, you need to go to source code path like davinci-kit-for-raspberry-pi/python-pi5. After modifying the code, you can run it directly to see the effect.
import LCD1602
from gpiozero import LED, Buzzer, Button
import spidev
import math
# Initialize joystick button, buzzer, and LED
Joy_BtnPin = Button(22) # GPIO22, Pin15
buzzPin = Buzzer(23) # GPIO23, Pin16
ledPin = LED(24) # GPIO24, Pin18
# Set initial upper temperature threshold
upperTem = 40
# Initialize SPI for MCP3008 (Bus 0, CE0 -> GPIO8 / Pin24)
spi = spidev.SpiDev()
spi.open(0, 0)
spi.max_speed_hz = 1000000 # 1 MHz
# Initialize LCD (I2C address 0x27, backlight on)
LCD1602.init(0x27, 1)
def read_adc(channel):
Read analog value from MCP3008
return -1
return value
def get_joystick_value():
Reads the joystick values and returns a change value based on the joystick's position.
x_val = read_adc(1)
y_val = read_adc(2)
if x_val > 800:
return 1
elif x_val < 200:
return -1
elif y_val > 800:
return -10
elif y_val < 200:
return 10
return 0
def upper_tem_setting():
Adjusts and displays the upper temperature threshold on the LCD.
global upperTem
LCD1602.write(0, 0, 'Upper Adjust: ')
change = int(get_joystick_value())
upperTem += change
strUpperTem = str(upperTem)
LCD1602.write(0, 1, strUpperTem)
LCD1602.write(len(strUpperTem), 1, ' ')
time.sleep(0.1)
def temperature():
Reads the current temperature from the sensor and returns it in Celsius.
analogVal = read_adc(0)
Vr = 3.3 * analogVal / 1023.0 # Voltage across the fixed resistor
if Vr == 0:
return 0 # Prevent division by zero
Rt = 10000.0 * (3.3 - Vr) / Vr # Adjusted formula: thermistor voltage is (3.3 - Vr)
temp = 1 / (((math.log(Rt / 10000.0)) / 3950.0) + (1 / (273.15 + 25.0)))
Cel = temp - 273.15
return round(Cel, 2)
def monitoring_temp():
Monitors and displays the current temperature and upper temperature threshold.
Activates buzzer and LED if the temperature exceeds the upper limit.
global upperTem
Cel = temperature()
LCD1602.write(0, 0, 'Temp: ')
LCD1602.write(0, 1, 'Upper: ')
LCD1602.write(6, 0, str(Cel))
LCD1602.write(7, 1, str(upperTem))
time.sleep(0.1)
if Cel >= upperTem:
buzzPin.on()
ledPin.on()
buzzPin.off()
ledPin.off()
# Main execution loop
lastState = 1
stage = 0
currentState = Joy_BtnPin.value
stage = (stage + 1) % 2
time.sleep(0.1)
LCD1602.clear()
lastState = currentState
if stage == 1:
upper_tem_setting()
monitoring_temp()
LCD1602.clear()
spi.close()
Code Explanation
This Python program runs on a Raspberry Pi. It uses an MCP3008 analog-to-digital converter to read temperature data from an analog sensor. A joystick is used to adjust the temperature threshold, and an LCD1602 display shows the current temperature and threshold. A buzzer and LED are triggered when the temperature exceeds the threshold.
Import Required Libraries
#!/usr/bin/env python3 import RPi.GPIO as GPIO import spidev import time import math import LCD1602
RPi.GPIOis used for controlling GPIO pins.spidevcommunicates with MCP3008 using SPI.mathis needed for temperature conversion calculations.LCD1602controls the LCD display.
GPIO Setup
JOY_BTN_PIN = 22 BUZZER_PIN = 23 LED_PIN = 24 GPIO.setmode(GPIO.BCM) GPIO.setup(JOY_BTN_PIN, GPIO.IN, pull_up_down=GPIO.PUD_UP) GPIO.setup(BUZZER_PIN, GPIO.OUT) GPIO.setup(LED_PIN, GPIO.OUT)
Assigns pins for joystick button, buzzer, and LED using BCM numbering.
Configures the joystick button with a pull-up resistor and sets output pins LOW initially.
SPI and LCD Initialization
upperTem = 40 # Default temperature threshold spi = spidev.SpiDev() spi.open(0, 0) spi.max_speed_hz = 1000000 # 1 MHz LCD1602.init(0x27, 1)
Initializes SPI communication for the MCP3008.
Sets up the I2C LCD1602 at address
0x27.
Read ADC Channel
def read_adc(channel): if channel < 0 or channel > 7: return -1 adc = spi.xfer2([1, (8 + channel) << 4, 0]) value = ((adc[1] & 0x03) << 8) | adc[2] return value
Sends SPI commands to MCP3008 to read analog voltage from the selected channel (0–7).
Returns a 10-bit result between 0 and 1023.
Joystick Direction Input
def get_joystick_value(): x_val = read_adc(1) y_val = read_adc(2) if x_val > 800: return 1 elif x_val < 200: return -1 elif y_val > 800: return -10 elif y_val < 200: return 10 else: return 0
Reads horizontal (X) and vertical (Y) joystick movement and translates that into a change in threshold:
Up/Down adjusts by 10.
Left/Right adjusts by 1.
Adjust Temperature Threshold
def upper_tem_setting(): global upperTem LCD1602.write(0, 0, 'Upper Adjust: ') change = int(get_joystick_value()) upperTem += change strUpperTem = str(upperTem) LCD1602.write(0, 1, strUpperTem) LCD1602.write(len(strUpperTem), 1, ' ') time.sleep(0.1)
Allows the user to change the
upperTemthreshold via joystick.Updates LCD to display the current threshold value.
Calculate Temperature from Analog Sensor
def temperature(): analogVal = read_adc(0) Vr = 3.3 * analogVal / 1023.0 if Vr == 0: return 0 Rt = 10000.0 * (3.3 - Vr) / Vr tempK = 1.0 / (((math.log(Rt / 10000.0)) / 3950.0) + (1.0 / (273.15 + 25.0))) Cel = tempK - 273.15 return round(Cel, 2)
Converts voltage reading to resistance, then uses the Steinhart-Hart equation to compute the temperature in Celsius.
Monitoring Mode
def monitoring_temp(): global upperTem Cel = temperature() LCD1602.write(0, 0, 'Temp: ') LCD1602.write(0, 1, 'Upper: ') LCD1602.write(6, 0, str(Cel)) LCD1602.write(7, 1, str(upperTem)) time.sleep(0.1) if Cel >= upperTem: GPIO.output(BUZZER_PIN, GPIO.HIGH) GPIO.output(LED_PIN, GPIO.HIGH) else: GPIO.output(BUZZER_PIN, GPIO.LOW) GPIO.output(LED_PIN, GPIO.LOW)
Displays the current temperature and threshold.
Activates buzzer and LED if the current temperature exceeds the threshold.
Main Loop
try: lastState = GPIO.input(JOY_BTN_PIN) stage = 0 while True: currentState = GPIO.input(JOY_BTN_PIN) if currentState == GPIO.HIGH and lastState == GPIO.LOW: stage = (stage + 1) % 2 time.sleep(0.1) LCD1602.clear() lastState = currentState if stage == 1: upper_tem_setting() else: monitoring_temp()
Uses joystick button press to toggle between:
stage 0: temperature monitoringstage 1: threshold adjustment
Cleanup on Exit
except KeyboardInterrupt: pass finally: LCD1602.clear() GPIO.cleanup() spi.close()
Ensures GPIO and LCD are reset on program termination (e.g., Ctrl+C).
