.. note:: Hello, welcome to the SunFounder Raspberry Pi & Arduino & ESP32 Enthusiasts Community on Facebook! Dive deeper into Raspberry Pi, Arduino, and ESP32 with fellow enthusiasts. **Why Join?** - **Expert Support**: Solve post-sale issues and technical challenges with help from our community and team. - **Learn & Share**: Exchange tips and tutorials to enhance your skills. - **Exclusive Previews**: Get early access to new product announcements and sneak peeks. - **Special Discounts**: Enjoy exclusive discounts on our newest products. - **Festive Promotions and Giveaways**: Take part in giveaways and holiday promotions. 👉 Ready to explore and create with us? Click [|link_sf_facebook|] and join today! .. _3.1.5_py_pi5_mcp3008: 3.1.5 Battery Indicator(MCP3008) =================================== .. note:: .. image:: ../img/mcp3008_and_adc0834.jpg :width: 25% :align: left Depending on your kit version, please identify whether you have **ADC0834** or **MCP3008** and proceed with the matching section. Introduction -------------- In this project, we will make a battery indicator device that can visually display the battery level on the LED Bargraph. .. warning:: Do not use battery components that exceed 3.3V to avoid overloading, which may damage the chip or Raspberry Pi. Required Components ------------------------------ In this project, we need the following components. .. image:: ../python_pi5/img/list2_Battery_Indicator.png :align: center Schematic Diagram ------------------- ============ ======== ======== === T-Board Name physical wiringPi BCM SPICE0 Pin 24 10 8 SPIMOSI Pin 19 12 10 SPIMISO Pin 21 13 9 SPISCLK Pin 23 14 11 GPIO25 Pin 22 6 25 GPIO12 Pin 32 26 12 GPIO16 Pin 36 27 16 GPIO20 Pin 38 28 20 GPIO21 Pin 40 29 21 GPIO5 Pin 29 21 5 GPIO6 Pin 31 22 6 GPIO13 Pin 33 23 13 GPIO19 Pin 35 24 19 GPIO26 Pin 37 25 26 ============ ======== ======== === .. image:: ../python_pi5/img/schematic_battery_indicator_mcp3008.png :align: center :width: 800 Experimental Procedures ------------------------- **Step 1:** Build the circuit. .. image:: ../python_pi5/img/july24_3.1.5_battery_indicator_mcp3008.png :width: 800 **Step 2:** Set up the SPI interface and install the ``spidev`` library (see :ref:`spi_configuration` for detailed instructions). If you have already completed these steps, you can skip this. **Step 3:** Go to the folder of the code. .. raw:: html .. code-block:: cd ~/davinci-kit-for-raspberry-pi/python-pi5 **Step 4:** Run the executable file. .. raw:: html .. code-block:: sudo python3 3.1.5-2_Battery_indicator_zero.py After the program runs, give the 3rd pin of MCP3008 and the GND a lead-out wire separately and then lead them to the two poles of a battery separately. You can see the corresponding LED on the LED Bargraph is lit up to display the power level (measuring range: 0-5V). .. warning:: If there is an error prompt ``RuntimeError: Cannot determine SOC peripheral base address``, please refer to :ref:`faq_soc` **Code** .. note:: You can **Modify/Reset/Copy/Run/Stop** the code below. But before that, you need to go to source code path like ``davinci-kit-for-raspberry-pi/python-pi5``. After modifying the code, you can run it directly to see the effect. .. raw:: html .. code-block:: python #!/usr/bin/env python3 import LCD1602 from gpiozero import LED, Buzzer, Button import spidev import time import math # Initialize joystick button, buzzer, and LED Joy_BtnPin = Button(22) # GPIO22, Pin15 buzzPin = Buzzer(23) # GPIO23, Pin16 ledPin = LED(24) # GPIO24, Pin18 # Set initial upper temperature threshold upperTem = 40 # Initialize SPI for MCP3008 (Bus 0, CE0 -> GPIO8 / Pin24) spi = spidev.SpiDev() spi.open(0, 0) spi.max_speed_hz = 1000000 # 1 MHz # Initialize LCD (I2C address 0x27, backlight on) LCD1602.init(0x27, 1) def read_adc(channel): """ Read analog value from MCP3008 """ if channel < 0 or channel > 7: return -1 adc = spi.xfer2([1, (8 + channel) << 4, 0]) value = ((adc[1] & 0x03) << 8) | adc[2] return value def get_joystick_value(): """ Reads the joystick values and returns a change value based on the joystick's position. """ x_val = read_adc(1) y_val = read_adc(2) if x_val > 800: return 1 elif x_val < 200: return -1 elif y_val > 800: return -10 elif y_val < 200: return 10 else: return 0 def upper_tem_setting(): """ Adjusts and displays the upper temperature threshold on the LCD. """ global upperTem LCD1602.write(0, 0, 'Upper Adjust: ') change = int(get_joystick_value()) upperTem += change strUpperTem = str(upperTem) LCD1602.write(0, 1, strUpperTem) LCD1602.write(len(strUpperTem), 1, ' ') time.sleep(0.1) def temperature(): """ Reads the current temperature from the sensor and returns it in Celsius. """ analogVal = read_adc(0) Vr = 3.3 * analogVal / 1023.0 # Voltage across the fixed resistor if Vr == 0: return 0 # Prevent division by zero Rt = 10000.0 * (3.3 - Vr) / Vr # Adjusted formula: thermistor voltage is (3.3 - Vr) temp = 1 / (((math.log(Rt / 10000.0)) / 3950.0) + (1 / (273.15 + 25.0))) Cel = temp - 273.15 return round(Cel, 2) def monitoring_temp(): """ Monitors and displays the current temperature and upper temperature threshold. Activates buzzer and LED if the temperature exceeds the upper limit. """ global upperTem Cel = temperature() LCD1602.write(0, 0, 'Temp: ') LCD1602.write(0, 1, 'Upper: ') LCD1602.write(6, 0, str(Cel)) LCD1602.write(7, 1, str(upperTem)) time.sleep(0.1) if Cel >= upperTem: buzzPin.on() ledPin.on() else: buzzPin.off() ledPin.off() # Main execution loop try: lastState = 1 stage = 0 while True: currentState = Joy_BtnPin.value if currentState == 1 and lastState == 0: stage = (stage + 1) % 2 time.sleep(0.1) LCD1602.clear() lastState = currentState if stage == 1: upper_tem_setting() else: monitoring_temp() except KeyboardInterrupt: LCD1602.clear() spi.close() **Code Explanation** This Python program runs on a Raspberry Pi. It uses an MCP3008 analog-to-digital converter to read temperature data from an analog sensor. A joystick is used to adjust the temperature threshold, and an LCD1602 display shows the current temperature and threshold. A buzzer and LED are triggered when the temperature exceeds the threshold. 1. **Import Required Libraries** .. code-block:: python #!/usr/bin/env python3 import RPi.GPIO as GPIO import spidev import time import math import LCD1602 * ``RPi.GPIO`` is used for controlling GPIO pins. * ``spidev`` communicates with MCP3008 using SPI. * ``math`` is needed for temperature conversion calculations. * ``LCD1602`` controls the LCD display. 2. **GPIO Setup** .. code-block:: python JOY_BTN_PIN = 22 BUZZER_PIN = 23 LED_PIN = 24 GPIO.setmode(GPIO.BCM) GPIO.setup(JOY_BTN_PIN, GPIO.IN, pull_up_down=GPIO.PUD_UP) GPIO.setup(BUZZER_PIN, GPIO.OUT) GPIO.setup(LED_PIN, GPIO.OUT) * Assigns pins for joystick button, buzzer, and LED using BCM numbering. * Configures the joystick button with a pull-up resistor and sets output pins LOW initially. 3. **SPI and LCD Initialization** .. code-block:: python upperTem = 40 # Default temperature threshold spi = spidev.SpiDev() spi.open(0, 0) spi.max_speed_hz = 1000000 # 1 MHz LCD1602.init(0x27, 1) * Initializes SPI communication for the MCP3008. * Sets up the I2C LCD1602 at address ``0x27``. 4. **Read ADC Channel** .. code-block:: python def read_adc(channel): if channel < 0 or channel > 7: return -1 adc = spi.xfer2([1, (8 + channel) << 4, 0]) value = ((adc[1] & 0x03) << 8) | adc[2] return value * Sends SPI commands to MCP3008 to read analog voltage from the selected channel (0–7). * Returns a 10-bit result between 0 and 1023. 5. **Joystick Direction Input** .. code-block:: python def get_joystick_value(): x_val = read_adc(1) y_val = read_adc(2) if x_val > 800: return 1 elif x_val < 200: return -1 elif y_val > 800: return -10 elif y_val < 200: return 10 else: return 0 * Reads horizontal (X) and vertical (Y) joystick movement and translates that into a change in threshold: * Up/Down adjusts by 10. * Left/Right adjusts by 1. 6. **Adjust Temperature Threshold** .. code-block:: python def upper_tem_setting(): global upperTem LCD1602.write(0, 0, 'Upper Adjust: ') change = int(get_joystick_value()) upperTem += change strUpperTem = str(upperTem) LCD1602.write(0, 1, strUpperTem) LCD1602.write(len(strUpperTem), 1, ' ') time.sleep(0.1) * Allows the user to change the ``upperTem`` threshold via joystick. * Updates LCD to display the current threshold value. 7. **Calculate Temperature from Analog Sensor** .. code-block:: python def temperature(): analogVal = read_adc(0) Vr = 3.3 * analogVal / 1023.0 if Vr == 0: return 0 Rt = 10000.0 * (3.3 - Vr) / Vr tempK = 1.0 / (((math.log(Rt / 10000.0)) / 3950.0) + (1.0 / (273.15 + 25.0))) Cel = tempK - 273.15 return round(Cel, 2) * Converts voltage reading to resistance, then uses the Steinhart-Hart equation to compute the temperature in Celsius. 8. **Monitoring Mode** .. code-block:: python def monitoring_temp(): global upperTem Cel = temperature() LCD1602.write(0, 0, 'Temp: ') LCD1602.write(0, 1, 'Upper: ') LCD1602.write(6, 0, str(Cel)) LCD1602.write(7, 1, str(upperTem)) time.sleep(0.1) if Cel >= upperTem: GPIO.output(BUZZER_PIN, GPIO.HIGH) GPIO.output(LED_PIN, GPIO.HIGH) else: GPIO.output(BUZZER_PIN, GPIO.LOW) GPIO.output(LED_PIN, GPIO.LOW) * Displays the current temperature and threshold. * Activates buzzer and LED if the current temperature exceeds the threshold. 9. **Main Loop** .. code-block:: python try: lastState = GPIO.input(JOY_BTN_PIN) stage = 0 while True: currentState = GPIO.input(JOY_BTN_PIN) if currentState == GPIO.HIGH and lastState == GPIO.LOW: stage = (stage + 1) % 2 time.sleep(0.1) LCD1602.clear() lastState = currentState if stage == 1: upper_tem_setting() else: monitoring_temp() * Uses joystick button press to toggle between: * ``stage 0``: temperature monitoring * ``stage 1``: threshold adjustment 10. **Cleanup on Exit** .. code-block:: python except KeyboardInterrupt: pass finally: LCD1602.clear() GPIO.cleanup() spi.close() * Ensures GPIO and LCD are reset on program termination (e.g., Ctrl+C).
